{"product_id":"bt30d-bluetooth-5-0-2-1-channel-power-amplifier-with-bass-and-treble-control","title":"Fosi Audio BT30D Bluetooth 2.1 CH Power Amplifier","description":"\u003cul style=\"width: 95%; margin: 0 auto;\"\u003e\n\u003cli\u003e\n\u003cp\u003eThe Bluetooth Stereo Amplifier adopts performance 2pcs texas instrument TPA3116D2 amp chip, dual-channel max output power 50W x2 +100W to get clear audio sound, no pop, no audible noise, dead silent when nothing is playing through it;\u003c\/p\u003e\n\u003c\/li\u003e\n\u003cli\u003e\n\u003cp\u003eSpeakers full frequency output, By using the custom treble bass knob and adjustable 40-300Hz cutoff frequency for the subwoofer, you'll be able to get the best sound;\u003c\/p\u003e\n\u003c\/li\u003e\n\u003cli\u003e\n\u003cp\u003eSupports wireless playback from Bluetooth devices, Bluetooth 5.0 wireless music streaming technology with external antenna make a transmission distance of more than 15m\/49ft;\u003c\/p\u003e\n\u003c\/li\u003e\n\u003cli\u003e\n\u003cp\u003eFull metallic shell to ensure high quality and durable, advanced circuitry design, built-in speakers protection circuit to ensure Hi-Fi clear and clean sound; With unrivaled sound for the customers who pursue HiFi sound;\u003c\/p\u003e\n\u003c\/li\u003e\n\u003cli\u003e\n\u003cp\u003eUpgraded DC power outlet for safe use without sparks, included high quality 24V\/4.5A power supply (The plug of the power adapter will match the country of your delivery address) enough to drive most passive speakers and powered\/passive subwoofer.\u003c\/p\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cdiv style=\"text-align: start;\"\u003e\u003cimg style=\"width: 80%;\" src=\"https:\/\/cdn.shopifycdn.net\/s\/files\/1\/2251\/7913\/files\/a__01_dce4b1a5-746d-470b-8e2f-1bbcbd3ca4a5.jpg?v=1637570486\" alt=\"BT30D Bluetooth 5.0 2.1 Channel Power Amplifier with Bass and Treble Control\"\u003e\u003c\/div\u003e\n\u003cdiv style=\"text-align: start;\"\u003e\u003cimg style=\"width: 80%;\" src=\"https:\/\/cdn.shopifycdn.net\/s\/files\/1\/2251\/7913\/files\/a__02_db8c189d-f210-405f-af4d-8474362aaebd.jpg?v=1637570504\" alt=\"2.1 Channel Power Amplifier\"\u003e\u003c\/div\u003e\n\u003ch3\u003e\u003cimg style=\"width: 80%;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/2251\/7913\/files\/B3A659_1.jpg?v=1680864634\" alt=\"Detailed description\"\u003e\u003c\/h3\u003e\n\u003ch4\u003eSpecifications\u003c\/h4\u003e\n\u003ctable style=\"width: 100%; max-width: 750px; table-layout: fixed;\"\u003e\n\u003ccolgroup\u003e \u003ccol style=\"width: 50%;\"\u003e \u003ccol style=\"width: 50%;\"\u003e \u003c\/colgroup\u003e\n\u003cthead\u003e\n\u003ctr\u003e\n\u003cth\u003eSpecifications\u003c\/th\u003e\n\u003cth\u003eDetails\u003c\/th\u003e\n\u003c\/tr\u003e\n\u003c\/thead\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003eModel\u003c\/td\u003e\n\u003ctd\u003eBT30D\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eChippest\u003c\/td\u003e\n\u003ctd\u003eTPA3116D2\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eMaxpower Output\u003c\/td\u003e\n\u003ctd\u003e50W*2+100W\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eTHD\u003c\/td\u003e\n\u003ctd\u003e0.05%(@1W)\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eSNR\u003c\/td\u003e\n\u003ctd\u003e≥98dB\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eWorking Voltage\u003c\/td\u003e\n\u003ctd\u003e12-24V\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eSpeakers Frequency Response\u003c\/td\u003e\n\u003ctd\u003e20Hz-20kHz(±3dB)m\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eBass Cutoff Frequency Range Adjustment\u003c\/td\u003e\n\u003ctd\u003e20-200Hz\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eImpedance\u003c\/td\u003e\n\u003ctd\u003e2-8 Ohms\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDevice Dimension\u003c\/td\u003e\n\u003ctd\u003eL118 x W132 x H35 mm\/4.72 x 5.2 x 1.38inch\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eInput mode\u003c\/td\u003e\n\u003ctd\u003eBluetooth\/RCA\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eOutput mode\u003c\/td\u003e\n\u003ctd\u003ePassive Speakers + Passive\/Active Subwoofer\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eBluetooth\u003c\/td\u003e\n\u003ctd\u003eBluetooth 5.0, up to 15m\/49ft wireless range without hindrance\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eWireless Range\u003c\/td\u003e\n\u003ctd\u003eUp to 15m\/49ft\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch4\u003e\n\u003cbr\u003eWhat‘s in the box？\u003c\/h4\u003e\n\u003ctable style=\"width: 100%; max-width: 750px; table-layout: fixed;\"\u003e\n\u003ccolgroup\u003e \u003ccol style=\"width: 50%;\"\u003e \u003ccol style=\"width: 50%;\"\u003e \u003c\/colgroup\u003e\n\u003cthead\u003e\n\u003ctr\u003e\n\u003cth\u003eItem\u003c\/th\u003e\n\u003cth\u003eQuantity\u003c\/th\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eFosi Audio BT30D Amplifier\u003c\/td\u003e\n\u003ctd\u003e1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e24V 4.5A Power Supply\u003c\/td\u003e\n\u003ctd\u003e1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eUser’s Manual\u003c\/td\u003e\n\u003ctd\u003e1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/thead\u003e\n\u003c\/table\u003e\n\u003cp\u003e\u003cstrong\u003eTips: The plug of the power adapter will match the country of your delivery address.\u003c\/strong\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cdiv style=\"display: flex; align-items: center; height: 10px;\"\u003e\n\u003cbr\u003e\n\u003cdiv style=\"display: flex; align-items: center; height: 20px;\"\u003e\u003cbr\u003e\u003c\/div\u003e\n\u003cdiv style=\"display: flex; align-items: center; height: 20px;\"\u003e\u003cbr\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv style=\"display: flex; align-items: center; height: 20px;\"\u003e\n\u003cstrong\u003e\u003c\/strong\u003e\u003cbr\u003e\n\u003c\/div\u003e\n\u003cdiv style=\"display: flex; align-items: center; height: 20px;\"\u003e\n\u003cimg style=\"width: 30px; height: 30px;\" alt=\"Download\" src=\"https:\/\/cdn.shopifycdn.net\/s\/files\/1\/2251\/7913\/files\/7.jpg?v=1638263331\"\u003e \u003ca style=\"color: #f48f00;\" href=\"https:\/\/cdn.shopifycdn.net\/s\/files\/1\/2251\/7913\/files\/BT30D_User_Manual.pdf?v=1627640046\"\u003eBT30D User Manual\u003c\/a\u003e\n\u003c\/div\u003e\n\u003cdiv style=\"display: flex; align-items: center; height: 20px;\"\u003e\u003cbr\u003e\u003c\/div\u003e\n\u003ch4 style=\"display: flex; align-items: center; height: 20px;\"\u003eVideo\u003c\/h4\u003e\n\u003cp\u003e\u003cspan style=\"color: #316f81;\"\u003e\u003ciframe width=\"750\" height=\"480\" src=\"https:\/\/www.youtube.com\/embed\/1gbSs2crQDo\" title=\"YouTube video player\"\u003e\u003c\/iframe\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003ch4\u003eCompare with similar items\u003c\/h4\u003e\n\u003cul style=\"width: 95%; margin: 0 auto;\"\u003e\n\u003cul style=\"width: 95%; margin: 0 auto;\"\u003e\n\u003cli\u003e\n\u003cp\u003e\u003ca title=\"Fosi Audio Bt30E 2.1 Channel Bluetooth Amplifier with U-disk and Remote Control\" href=\"https:\/\/fosiaudioshop.com\/products\/fosi-audio-2-1-channel-bluetooth-5-0-amplifier-bt30e-subwoofer-50w-x2-100w?_pos=1\u0026amp;_sid=7156bf828\u0026amp;_ss=r\" target=\"_blank\"\u003eFosi Audio BT30E 2.1 Channel Bluetooth Amplifier with Remote Control\u003c\/a\u003e\u003c\/p\u003e\n\u003c\/li\u003e\n\u003cli\u003e\n\u003cp\u003e\u003ca title=\"Fosi Audio BT30A 2.1 channel stereo home audio amplifier 200watts\" href=\"https:\/\/fosiaudioshop.com\/products\/bluetooth-amp-bt30a?_pos=1\u0026amp;_sid=bc3956fe0\u0026amp;_ss=r\" target=\"_blank\"\u003eFosi Audio BT30A 2.1 Channel Bluetooth Amplifier 50watts x2 + 100watts\u003c\/a\u003e\u003c\/p\u003e\n\u003c\/li\u003e\n\u003cli\u003e\n\u003cp\u003e\u003ca title=\"Fosi Audio BT30D PRO 2.1 Channel Bluetooth 5.0 Amplifier with SUB control\" href=\"https:\/\/fosiaudioshop.com\/products\/fosi-audio-bt30d-pro-bluetooth-5-0-2-1-channel-540w-power-amplifier\" target=\"_blank\"\u003eFosi Audio BT30D PRO 2.1 Channel Bluetooth Amplifier 120W x2 + 300W\u003c\/a\u003e\u003c\/p\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003c\/ul\u003e","brand":"Fosi Audio","offers":[{"title":"Default Title","offer_id":47773277323482,"sku":"BT30D-B+24V","price":89.99,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0818\/9706\/2618\/files\/BT30D_6b086081-5d21-4e57-8090-f89712bf4f44.jpg?v=1776428579","url":"https:\/\/eu.fosiaudio.com\/es\/products\/bt30d-bluetooth-5-0-2-1-channel-power-amplifier-with-bass-and-treble-control","provider":"Fosi Audio EU","version":"1.0","type":"link"}
