{"product_id":"da2120c-bluetooth-5-0-stereo-2-1-channel-amplifier-receiver-dac-remote-control","title":"Fosi Audio DA2120C 2.1 Ch Integrated Amplifier","description":"\u003cul class=\"a-unordered-list a-vertical a-spacing-none\"\u003e\n\u003cli\u003e\n\u003cp\u003e2.1 CH Wireless DAC Hifi Amplifier with EQ Control. MAX Power Output up to 120Watts x2@4ohm. DA2120C can drive most home bookshelf\/desktop\/outdoor(passive) speakers and powered subwoofers, offering low distortion and acoustically accurate audio reproduction. The bright digital LED display lets you see the settings you change easily and remote control for hassle-free adjust the inputs mode\/volume\/bass\/treble.\u003c\/p\u003e\n\u003c\/li\u003e\n\u003cli\u003e\n\u003cp\u003eDA2120C high-performance integrated stereo digital amplifier adopts Texas Instruments TAS5352A chip, designed to drive a 4-Ω bridge-tied load (BTL) at up to 120 W per channel with low harmonic distortion, low integrated noise, and low idle current. The TAS5352A has a complete protection system integrated into the chip, safeguarding the device against a wide range of fault conditions that could damage the system.\u003c\/p\u003e\n\u003c\/li\u003e\n\u003cli\u003e\n\u003cp\u003e2-in-1 High-Performance DAC Power Amplifier with Multiple Input Modes. DA2120C installed in a quality aluminum enclosure supports Bluetooth\/RCA\/PC-USB\/Coaxial\/Optical Input, easy installation to build a stereo sound system.\u003c\/p\u003e\n\u003c\/li\u003e\n\u003cli\u003e\n\u003cp\u003eDA2120C Bluetooth 5.0 amplifier delivers sound in sync, so you can enjoy the freedom of wireless and high-fidelity streaming music. It reduces delay and improves the end-to-end speed of the audio transmission, resulting in high-quality, synchronized sound, so you never miss a beat. With a 6dBi high gain antenna for long-range streaming up to 65 ft(20m).\u003c\/p\u003e\n\u003c\/li\u003e\n\u003cli\u003e\n\u003cp\u003eWhat You Get: DA2120C stereo amplifier x1, Bluetooth antenna x1, 32V\/5A power supply x1, remote control x1, PC-USB Cable x1, Optical Cable x1, user manual x1, our worry-free 24-month warranty, and friendly customer service.\u003c\/p\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cul class=\"a-unordered-list a-vertical a-spacing-mini\" dir=\"ltr\"\u003e\u003c\/ul\u003e\n\u003cdiv style=\"text-align: left;\"\u003e\u003cimg src=\"https:\/\/cdn.shopifycdn.net\/s\/files\/1\/2251\/7913\/files\/2120c_01.jpg?v=1637142552\" alt=\"multiple input of Bluetooth amp\" style=\"float: none;\"\u003e\u003c\/div\u003e\n\u003cdiv style=\"text-align: left;\"\u003e\u003cimg src=\"https:\/\/cdn.shopifycdn.net\/s\/files\/1\/2251\/7913\/files\/2120c_02.jpg?v=1637142552\" alt=\"Bluetooth 2.1 Channel Amplifier\" style=\"float: none;\"\u003e\u003c\/div\u003e\n\u003ch4\u003e\n\u003cbr\u003e\u003cbr\u003eSpecifications\u003c\/h4\u003e\n\u003ctable style=\"width: 100%; max-width: 800px; table-layout: fixed;\" data-mce-style=\"width: 100%; max-width: 800px; table-layout: fixed;\"\u003e\n\u003ccolgroup\u003e \u003ccol style=\"width: 50%;\" data-mce-style=\"width: 50%;\"\u003e \u003ccol style=\"width: 50%;\" data-mce-style=\"width: 50%;\"\u003e \u003c\/colgroup\u003e\n\u003cthead\u003e\n\u003ctr\u003e\n\u003cth\u003eSpecifications\u003c\/th\u003e\n\u003cth\u003eDetails\u003c\/th\u003e\n\u003c\/tr\u003e\n\u003c\/thead\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003eModel\u003c\/td\u003e\n\u003ctd\u003eDA2120C\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eOutput Power\u003c\/td\u003e\n\u003ctd\u003e2 × 125W at 10% THD+N Into 4 Ω \u003cbr\u003e2 × 100W at 10% THD+N Into 6 Ω \u003cbr\u003e2 × 80W at 10% THD+N Into 8 Ω\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eFrequency Range\u003c\/td\u003e\n\u003ctd\u003e20Hz - 20kHz (±1 dB)\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eBass frequency\u003c\/td\u003e\n\u003ctd\u003e20Hz-200Hz\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eTHD\u003c\/td\u003e\n\u003ctd\u003e≤ 0.01%\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eSNR\u003c\/td\u003e\n\u003ctd\u003e≥ 105dB\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eUSB Chip\u003c\/td\u003e\n\u003ctd\u003eCmedia CM6642 SUPPORT 24bit\/192Khz\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eAmplifier Chip\u003c\/td\u003e\n\u003ctd\u003eAmerican TI TAS5352A\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eBluetooth Chip\u003c\/td\u003e\n\u003ctd\u003eQualcomm QCC3031 Bluetooth 5.0 chip supports aptX, aptX-HD, SBC, AAC\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDAC Chip\u003c\/td\u003e\n\u003ctd\u003eAmerican Cirrus CS8422 chip USB, coaxial optical fiber Supported sampling rate 24bit\/192Khz\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDevice Dimension\u003c\/td\u003e\n\u003ctd\u003eL180*W130*H38mm (7*5*1.5in)\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eSystem Supported\u003c\/td\u003e\n\u003ctd\u003eXP\/W7\/W8\/W10\/MAC\/Linux\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003ePower Supply\u003c\/td\u003e\n\u003ctd\u003e32V 5A\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch4\u003e\n\u003cbr\u003eWhat‘s in the box？\u003c\/h4\u003e\n\u003ctable style=\"width: 100%; max-width: 800px; table-layout: fixed;\" data-mce-style=\"width: 100%; max-width: 800px; table-layout: fixed;\"\u003e\n\u003ccolgroup\u003e \u003ccol style=\"width: 50%;\" data-mce-style=\"width: 50%;\"\u003e \u003ccol style=\"width: 50%;\" data-mce-style=\"width: 50%;\"\u003e \u003c\/colgroup\u003e\n\u003cthead\u003e\n\u003ctr\u003e\n\u003cth\u003eItem\u003c\/th\u003e\n\u003cth\u003eQuantity\u003c\/th\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDA2120C Amplifier\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e32V 5A Power Supply\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eRemote Control\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eUSB Cable\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eOptical Cable\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eAC Cord\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eUser’s Manual\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/thead\u003e\n\u003c\/table\u003e\n\u003cdiv style=\"display: flex; align-items: center; height: 20px;\"\u003e\n\u003cimg style=\"width: 30px; height: 30px;\" alt=\"Download\" src=\"https:\/\/cdn.shopifycdn.net\/s\/files\/1\/2251\/7913\/files\/7.jpg?v=1638263331\"\u003e\u003ca href=\"https:\/\/cdn.shopifycdn.net\/s\/files\/1\/2251\/7913\/files\/DA-2120C_-0518_1100100b-b264-4624-80e3-1424f5420b16.pdf?v=1638177867\"\u003eDA2120C User Manual\u003c\/a\u003e\n\u003c\/div\u003e\n\u003cp\u003e \u003c\/p\u003e\n\u003cp\u003e\u003ciframe title=\"YouTube video player\" src=\"https:\/\/www.youtube.com\/embed\/7qBTE6nzaQU\" height=\"640\" width=\"480\" allowfullscreen=\"\" allow=\"accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture\" frameborder=\"0\"\u003e\u003c\/iframe\u003e\u003c\/p\u003e\n\u003cp\u003eYou can also view other models:\u003c\/p\u003e\n\u003cp\u003e\u003ca href=\"https:\/\/fosiaudio.com\/products\/fosi-audio-da2120a-bluetooth-amplifier-stereo-receiver-2-channel-audio-wireless-amp-dac-spdif-hi-fi-compact-mini-integrated-class-d-power-amp-for-home-speakers-active-subwoofer-with-remote-control?_pos=2\u0026amp;_sid=6c5e66a5d\u0026amp;_ss=r\" title=\"DA2120A+24V Bluetooth Amplifier 2CH 50WX2\" target=\"_blank\" data-mce-href=\"https:\/\/fosiaudio.com\/products\/fosi-audio-da2120a-bluetooth-amplifier-stereo-receiver-2-channel-audio-wireless-amp-dac-spdif-hi-fi-compact-mini-integrated-class-d-power-amp-for-home-speakers-active-subwoofer-with-remote-control?_pos=2\u0026amp;_sid=6c5e66a5d\u0026amp;_ss=r\"\u003eDA2120A+24V Bluetooth Amplifier 2CH 50WX2\u003c\/a\u003e\u003c\/p\u003e\n\u003cp\u003e\u003ca href=\"https:\/\/fosiaudioshop.com\/products\/fosi-audio-da2120b-bluetooth-amplifier-stereo-audio-wireless-amp-hifi-class-d-power-amp-100w-x2-passive-speakers-remote-control\" title=\"DA2120B+24V Bluetooth Amplifier 2CH 100W x2\" target=\"_blank\"\u003eDA2120B+24V Bluetooth Amplifier 2CH 100W x2\u003c\/a\u003e\u003c\/p\u003e\n\u003cp\u003e\u003ca href=\"https:\/\/fosiaudio.com\/products\/da-2120d-bluetooth-audio-amplifiers-2-1-channel-stereo-100w-power-amp-usb-coaxial-optical-aux-remote-control-for-home-speaker?_pos=1\u0026amp;_sid=6d5a595bb\u0026amp;_ss=r\" title=\"DA2120D+24V Bluetooth Amplifier 2.1CH 100W x2\" target=\"_blank\" data-mce-href=\"https:\/\/fosiaudio.com\/products\/da-2120d-bluetooth-audio-amplifiers-2-1-channel-stereo-100w-power-amp-usb-coaxial-optical-aux-remote-control-for-home-speaker?_pos=1\u0026amp;_sid=6d5a595bb\u0026amp;_ss=r\"\u003eDA2120D+24V Bluetooth Amplifier 2.1CH 100W x2\u003c\/a\u003e\u003c\/p\u003e\n\u003cul class=\"a-unordered-list a-vertical a-spacing-none\"\u003e\u003c\/ul\u003e","brand":"Fosi Audio","offers":[{"title":"Default Title","offer_id":47773276438746,"sku":"DA2120C+32V","price":149.99,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0818\/9706\/2618\/files\/products_1_786b67b6-5e62-426f-9835-4d7e625adc19.jpg?v=1776428570","url":"https:\/\/eu.fosiaudio.com\/es\/products\/da2120c-bluetooth-5-0-stereo-2-1-channel-amplifier-receiver-dac-remote-control","provider":"Fosi Audio EU","version":"1.0","type":"link"}
