{"product_id":"fosi-audio-box-x1-phono-preamp-mm-turntable-preamplifer-with-3-5mm-aux-rca-output","title":"Fosi Audio BOX X1 MM Turntable Phono Preamp","description":"\u003cul\u003e\n\u003cli\u003eConverts Phono Signals: Compact ultra-low noise phono turntable preamp that converts phono signals to line-level signals with Low-noise integrated circuits and high-quality components to remove low-frequency noise to ensure clear sound quality. Designed with a grounding post to protect your turntable.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cul\u003e\n\u003cli\u003eFeatures Power Switch \u0026amp; 3.5MM Headphone Output: The unique power switch button design is very convenient to use. You can enjoy high-quality music with headphones through the 3.5 mm headphone output. Note: RCA line output and AUX headphone output can be output simultaneously.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cul\u003e\n\u003cli\u003e3.5MM \/ RCA Output: BOX X1 supports MM turntable input, 3.5MM headphone output, and RCA line output for powered speakers. Note: You can connect a power amplifier through the 3.5MM or RCA output, then connect the passive speakers.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cul\u003e\n\u003cli\u003eMM Phono Preamplifier \u0026amp; DC12V Power Adapter: Output Voltage Level: 2V max (P-P) at 10K Ohms, SNR: 70dB, THD: ≤0.08% @ 1kHz and 3mV, Frequency Response: Standard RIAA. Equipped with DC12V high-quality power supply.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cul\u003e\n\u003cli\u003eEasy quick setup for all MM (moving magnet) cartridges, Metal Aluminum case protects the unit from vibrations and electromagnetic interference.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cdiv data-mce-fragment=\"1\"\u003e\u003cimg data-mce-fragment=\"1\" alt=\"Phono Preamp for Turntable with Volume Control Box X1\" src=\"https:\/\/cdn.shopifycdn.net\/s\/files\/1\/2251\/7913\/files\/1_9e4799a0-f8ad-43d7-87ae-a5695566ec0a.jpg?v=1637654966\" data-mce-src=\"https:\/\/cdn.shopifycdn.net\/s\/files\/1\/2251\/7913\/files\/1_9e4799a0-f8ad-43d7-87ae-a5695566ec0a.jpg?v=1637654966\"\u003e\u003c\/div\u003e\n\u003cdiv data-mce-fragment=\"1\"\u003e\u003cimg data-mce-fragment=\"1\" alt=\"Phono Preamp for Turntable with Volume Control Box X1\" src=\"https:\/\/cdn.shopifycdn.net\/s\/files\/1\/2251\/7913\/files\/2_737f42b9-b357-4c70-a42c-a28ecc6ebe33.jpg?v=1637654980\" data-mce-src=\"https:\/\/cdn.shopifycdn.net\/s\/files\/1\/2251\/7913\/files\/2_737f42b9-b357-4c70-a42c-a28ecc6ebe33.jpg?v=1637654980\"\u003e\u003c\/div\u003e\n\u003ch4\u003e\n\u003cbr\u003e\u003cbr\u003eSpecifications\u003c\/h4\u003e\n\u003ctable style=\"width: 100%; max-width: 800px; table-layout: fixed;\" data-mce-style=\"width: 100%; max-width: 800px; table-layout: fixed;\"\u003e\n\u003ccolgroup\u003e \u003ccol style=\"width: 50%;\" data-mce-style=\"width: 50%;\"\u003e \u003ccol style=\"width: 50%;\" data-mce-style=\"width: 50%;\"\u003e \u003c\/colgroup\u003e\n\u003cthead\u003e\n\u003ctr\u003e\n\u003cth\u003eSpecifications\u003c\/th\u003e\n\u003cth\u003eDetails\u003c\/th\u003e\n\u003c\/tr\u003e\n\u003c\/thead\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003eModel\u003c\/td\u003e\n\u003ctd\u003eBOX X1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eOutput Mode\u003c\/td\u003e\n\u003ctd\u003e3.5MM headphone output + RCA output\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eInput Mode\u003c\/td\u003e\n\u003ctd\u003eMM turntable input, Grounding post input, 12V DC input\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eOutput\u003c\/td\u003e\n\u003ctd\u003eActive(powered) speakers, Headphone, Amplifier\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eFrequency Response\u003c\/td\u003e\n\u003ctd\u003eStandard RIAA\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eTHD\u003c\/td\u003e\n\u003ctd\u003e≤0.08% @ 1kHz and 3mV\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eSNR\u003c\/td\u003e\n\u003ctd\u003e70dB\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eProduct Weight\u003c\/td\u003e\n\u003ctd\u003e0.35lb\/161g\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDevice Dimension\u003c\/td\u003e\n\u003ctd\u003e3.94×0.98×2.17 inch\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDC Input Range\u003c\/td\u003e\n\u003ctd\u003e12V\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eInput Voltage Range\u003c\/td\u003e\n\u003ctd\u003eAC 100V - 240V\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eOutput Voltage Level\u003c\/td\u003e\n\u003ctd\u003e2V max (P-P) at 10K Ohms\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003ePower Supply\u003c\/td\u003e\n\u003ctd\u003e12V 1.5A\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch4\u003e\n\u003cbr\u003eWhat's in the box？\u003c\/h4\u003e\n\u003ctable style=\"width: 100%; max-width: 800px; table-layout: fixed;\" data-mce-style=\"width: 100%; max-width: 800px; table-layout: fixed;\"\u003e\n\u003ccolgroup\u003e \u003ccol style=\"width: 50%;\" data-mce-style=\"width: 50%;\"\u003e \u003ccol style=\"width: 50%;\" data-mce-style=\"width: 50%;\"\u003e \u003c\/colgroup\u003e\n\u003cthead\u003e\n\u003ctr\u003e\n\u003cth\u003eItem\u003c\/th\u003e\n\u003cth\u003eQuantity\u003c\/th\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eBox X1 Phono Preamp\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e12V 1.5A Power Adapter\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eUser’s Manual\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/thead\u003e\n\u003c\/table\u003e\n\u003cp\u003e\u003ciframe width=\"480\" height=\"300\" src=\"https:\/\/www.youtube.com\/embed\/HTRZAD1WACE\" title=\"YouTube video player\" frameborder=\"0\" allow=\"accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture\" allowfullscreen=\"\"\u003e\u003c\/iframe\u003e\u003c\/p\u003e\n\u003ch3\u003eCompare with similar items:\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003e\u003ca href=\"https:\/\/fosiaudio.com\/products\/fosi-audio-phono-preamp-for-turntable-preamplifier-mm-phonograph-preamplifier-with-gain-gear-mini-stereo-audio-hi-fi-pre-amplifier-for-record-player-with-dc-12v-power-box-x2?_pos=3\u0026amp;_sid=d6baad285\u0026amp;_ss=r\" title=\"Box X2 HiFi MM Phonograph Preamplifier\" data-mce-href=\"https:\/\/fosiaudio.com\/products\/fosi-audio-phono-preamp-for-turntable-preamplifier-mm-phonograph-preamplifier-with-gain-gear-mini-stereo-audio-hi-fi-pre-amplifier-for-record-player-with-dc-12v-power-box-x2?_pos=3\u0026amp;_sid=d6baad285\u0026amp;_ss=r\" target=\"_blank\"\u003eBox X2 HiFi MM Phonograph Preamplifier\u003c\/a\u003e\u003c\/li\u003e\n\u003cli\u003e\u003ca href=\"https:\/\/fosiaudio.com\/products\/fosi-audio-bluetooth-phono-preamp-for-turntable-phonograph-preamplifier-with-ge5654-vacuum-tube-amplifier-audio-hifi-box-x3-diy?_pos=1\u0026amp;_sid=11e8574bd\u0026amp;_ss=r\" title=\"Box X3 Bluetooth Phono Preamp\" data-mce-href=\"https:\/\/fosiaudio.com\/products\/fosi-audio-bluetooth-phono-preamp-for-turntable-phonograph-preamplifier-with-ge5654-vacuum-tube-amplifier-audio-hifi-box-x3-diy?_pos=1\u0026amp;_sid=11e8574bd\u0026amp;_ss=r\" target=\"_blank\"\u003eBox X3 Bluetooth Phono Preamp\u003c\/a\u003e\u003c\/li\u003e\n\u003c\/ul\u003e","brand":"Fosi Audio","offers":[{"title":"Default Title","offer_id":47773278437594,"sku":"BOXX1-MM","price":39.99,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0818\/9706\/2618\/files\/products_2_53266c06-03b8-4b31-baa5-887e8f77b279.jpg?v=1776428583","url":"https:\/\/eu.fosiaudio.com\/es\/products\/fosi-audio-box-x1-phono-preamp-mm-turntable-preamplifer-with-3-5mm-aux-rca-output","provider":"Fosi Audio EU","version":"1.0","type":"link"}
