{"product_id":"fosi-audio-ds1-headphone-amps-supports-dsd512-with-3-5mm-4-4mm-outputs","title":"Fosi Audio DS1 Dongle DAC Headphone Amplifier","description":"\u003cul class=\"a-unordered-list a-vertical a-spacing-mini\" data-mce-fragment=\"1\"\u003e\n\u003cli class=\"a-spacing-mini\"\u003e\u003cspan class=\"a-list-item\"\u003eSmall USB DAC headphone amplifier with optimized HiFi audio architecture ensures High-Resolution sound quality. The portable USB DAC DS1 is compatible with various systems like Android\/iOS\/Windows\/Mac, compatible with the latest devices: phones\/computers\/tablets\/laptops\/audio players, etc. Wonderfully versatile when commuting in the home, office, or gaming.\u003cbr\u003e\u003cbr\u003e\u003c\/span\u003e\u003c\/li\u003e\n\u003cli class=\"a-spacing-mini\"\u003e\u003cspan class=\"a-list-item\"\u003eDS1 adopts ESS Technology ES9038Q2M DAC Chips supporting DSD 512 and 32Bit\/768kHz PCM, features best-in-class specifications, and high-power outputs capable of supporting the most demanding of headphones with impedance above 200Ω.\u003cbr\u003e\u003cbr\u003e\u003c\/span\u003e\u003c\/li\u003e\n\u003cli class=\"a-spacing-mini\"\u003e\u003cspan class=\"a-list-item\"\u003eLow Noise Floor Clean Sound for True High-Fidelity. DS1 features abundant power with a high signal-to-noise ratio, low distortion, and almost 0 noise.\u003cbr\u003e\u003cbr\u003e\u003c\/span\u003e\u003c\/li\u003e\n\u003cli class=\"a-spacing-mini\"\u003e\u003cspan class=\"a-list-item\"\u003e3.5MM+4.4MM Dual Headphone Outputs are both Powerful enough to easily drive most headphones. The traditional 3.5mm single-ended headphone output is widely compatible with most headphones, and a 4.4mm balanced headphone output for a more detailed audio experience. Specifications: THD+N\u0026lt;0.0006%, output power up to 220mw, SNR\u0026gt;120dB, Noise\u0026lt;1.6UV.\u003cbr\u003e\u003cbr\u003e\u003c\/span\u003e\u003c\/li\u003e\n\u003cli class=\"a-spacing-mini\"\u003e\u003cspan class=\"a-list-item\"\u003eWhat You Get: DS1 USB DAC Headphone Amp x1, Type-C to Type-C cable x1, USB-A to USB-C Converter x1, user manual x1, our worry-free 24-month warranty, and friendly customer service. NOTE: The new version of the DS1 headphone amp optimized the volume control which is independently controlled from the audio source device.\u003c\/span\u003e\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cdiv style=\"text-align: start;\" data-mce-fragment=\"1\" data-mce-style=\"text-align: start;\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/2251\/7913\/files\/DS1_84fc7f2d-469d-4b22-9e10-4203eab49a33_1024x1024.jpg?v=1698650424\" alt=\"DS1\" style=\"float: none;\" data-mce-fragment=\"1\" data-mce-style=\"float: none;\" data-mce-src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/2251\/7913\/files\/DS1_84fc7f2d-469d-4b22-9e10-4203eab49a33_1024x1024.jpg?v=1698650424\"\u003e\u003c\/div\u003e\n\u003cdiv style=\"text-align: start;\"\u003e\u003cimg style=\"margin-bottom: 16px; float: none;\" alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/2251\/7913\/files\/DS1-1_1024x1024.jpg?v=1698650456\"\u003e\u003c\/div\u003e\n\u003ch4\u003e\n\u003cbr\u003eSpecifications\u003c\/h4\u003e\n\u003ctable style=\"width: 100%; max-width: 800px; table-layout: fixed;\" data-mce-style=\"width: 100%; max-width: 800px; table-layout: fixed;\"\u003e\n\u003ccolgroup\u003e \u003ccol style=\"width: 50%;\" data-mce-style=\"width: 50%;\"\u003e \u003ccol style=\"width: 50%;\" data-mce-style=\"width: 50%;\"\u003e \u003c\/colgroup\u003e\n\u003cthead\u003e\n\u003ctr\u003e\n\u003cth\u003eSpecifications\u003c\/th\u003e\n\u003cth\u003eDetails\u003c\/th\u003e\n\u003c\/tr\u003e\n\u003c\/thead\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003eModel\u003c\/td\u003e\n\u003ctd\u003eDS1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eOutput Power\u003c\/td\u003e\n\u003ctd\u003e120mW(SE); 220mW(BAL)\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eTerminating Impedance\u003c\/td\u003e\n\u003ctd\u003e16-300Ω\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eInput Mode\u003c\/td\u003e\n\u003ctd\u003eUSB Type C\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eOutput Mode\u003c\/td\u003e\n\u003ctd\u003e3.5MM + 4.4MM Headphone\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eFrequency Range\u003c\/td\u003e\n\u003ctd\u003e20Hz-20kHz (±0.5dB)\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eTHD\u003c\/td\u003e\n\u003ctd\u003e0.0006%(32Ω SE); 0.001%(32Ω BAL)\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eSNR\u003c\/td\u003e\n\u003ctd\u003e≥120 dB\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eSampling Rate\u003c\/td\u003e\n\u003ctd\u003e32bit\/768kHz\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDSD\u003c\/td\u003e\n\u003ctd\u003eDSD64\/128\/256\/512\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDAC Chipset\u003c\/td\u003e\n\u003ctd\u003eES9038Q2M\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eMaterial\u003c\/td\u003e\n\u003ctd\u003eTin Alloy\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDevice Weight\u003c\/td\u003e\n\u003ctd\u003e38g\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch4\u003e\n\u003cbr\u003eWhat‘s in the box？\u003c\/h4\u003e\n\u003ctable style=\"width: 100%; max-width: 800px; table-layout: fixed;\" data-mce-style=\"width: 100%; max-width: 800px; table-layout: fixed;\"\u003e\n\u003ccolgroup\u003e \u003ccol style=\"width: 50%;\" data-mce-style=\"width: 50%;\"\u003e \u003ccol style=\"width: 50%;\" data-mce-style=\"width: 50%;\"\u003e \u003c\/colgroup\u003e\n\u003cthead\u003e\n\u003ctr\u003e\n\u003cth\u003eItem\u003c\/th\u003e\n\u003cth\u003eQuantity\u003c\/th\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eFosi Audio DS1\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eType-C to Type-C cable\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eUSB-A to USB-C Converter\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eUser Manual\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/thead\u003e\n\u003c\/table\u003e\n\u003cbr\u003e\n\u003cdiv style=\"display: flex; align-items: center; height: 20px;\"\u003e\n\u003cimg src=\"https:\/\/cdn.shopifycdn.net\/s\/files\/1\/2251\/7913\/files\/7.jpg?v=1638263331\" alt=\"Download\" style=\"width: 30px; height: 30px;\"\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/2251\/7913\/files\/DS1_User_Manual.pdf?v=1714989770\" style=\"color: #0189ff;\"\u003eDS1 User Manual \u003c\/a\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\u003c\/div\u003e","brand":"Fosi Audio","offers":[{"title":"Default Title","offer_id":47773279355098,"sku":"DS1","price":79.99,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0818\/9706\/2618\/files\/001_495a18c8-6559-4481-85ff-262a03460771.jpg?v=1776428586","url":"https:\/\/eu.fosiaudio.com\/es\/products\/fosi-audio-ds1-headphone-amps-supports-dsd512-with-3-5mm-4-4mm-outputs","provider":"Fosi Audio EU","version":"1.0","type":"link"}
