{"product_id":"fosi-audio-m01-bt-bluetooth-one-channel-mono-amplifier-for-home-speakers","title":"Fosi Audio M01-BT Bluetooth Subwoofer Mono Amp","description":"\u003cul\u003e\n\u003cli\u003eUpgraded Design: Add Bluetooth to a subwoofer amplifier. M01-BT support Bluetooth and RCA input can drive most home passive speakers, passive subwoofers, and powered subwoofers. (Note： M01-BT is not suitable for active speakers). Easy to build a simple sound system with M01-BT.\u003cbr\u003e\u003cbr\u003e\n\u003c\/li\u003e\n\u003cli\u003eMini compact Class D Audio Amplifier. M01-BT SUB amp adopts ST Microelectronics TDA7498E high-performance chip, MAX power output up to 300Watts.\u003cbr\u003e\u003cbr\u003e\n\u003c\/li\u003e\n\u003cli\u003eSwitch to PBTL(As a full frequency mono amp): You can use the banana plugs or bare wires to connect the passive subwoofer to the M01-BT, use the RCA cable to connect the powered subwoofer to the M01-BT.\u003cbr\u003e\u003cbr\u003e\n\u003c\/li\u003e\n\u003cli\u003eSwitch to SUB(As a subwoofer amp): You can use the banana plugs or bare wires to connect the passive subwoofer to the M01-BT, use the RCA cable to connect the powered subwoofer to the M01-BT.\u003cbr\u003e\u003cbr\u003e\n\u003c\/li\u003e\n\u003cli\u003eWhat you Get: M01-BT amplifier x1, Bluetooth antenna x1, User Manual x1, 24V\/4.5A Power Adapter x1, AC Cord x1, 18-month worry-free warranty, and friendly customer service.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch4\u003e\n\u003cbr\u003eSpecifications\u003c\/h4\u003e\n\u003ctable style=\"width: 100%; max-width: 800px; table-layout: fixed;\" data-mce-style=\"width: 100%; max-width: 800px; table-layout: fixed;\"\u003e\n\u003ccolgroup\u003e \u003ccol style=\"width: 50%;\" data-mce-style=\"width: 50%;\"\u003e \u003ccol style=\"width: 50%;\" data-mce-style=\"width: 50%;\"\u003e \u003c\/colgroup\u003e\n\u003cthead\u003e\n\u003ctr\u003e\n\u003cth\u003eSpecifications\u003c\/th\u003e\n\u003cth\u003eDetails\u003c\/th\u003e\n\u003c\/tr\u003e\n\u003c\/thead\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003eModel\u003c\/td\u003e\n\u003ctd\u003eM01-BT\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eMAX Power Output\u003c\/td\u003e\n\u003ctd\u003e300W\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eRMS Power Output\u003c\/td\u003e\n\u003ctd\u003eRMS220W@4Ω, RMS 110W@8Ω\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eTerminating Impedance\u003c\/td\u003e\n\u003ctd\u003e2-8Ω\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eInput Mode\u003c\/td\u003e\n\u003ctd\u003eBluetooth + RCA\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eOutput Mode\u003c\/td\u003e\n\u003ctd\u003ePassive Speaker + Powered Subwoofer\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eFrequency Range\u003c\/td\u003e\n\u003ctd\u003e20Hz - 20kHz (±3 dB)\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eBass Frequency Range\u003c\/td\u003e\n\u003ctd\u003e20-200Hz\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eTHD\u003c\/td\u003e\n\u003ctd\u003e≤0.05%\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eSNR\u003c\/td\u003e\n\u003ctd\u003e≥ 102dB\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eInput Sensitivity\u003c\/td\u003e\n\u003ctd\u003e≤ 0.2mV\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eChip Set\u003c\/td\u003e\n\u003ctd\u003eTDA7498E\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDC Input Range\u003c\/td\u003e\n\u003ctd\u003e24-32V\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003ePower Supply\u003c\/td\u003e\n\u003ctd\u003e24V 4.5A\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch4\u003e\n\u003cbr\u003eWhat‘s in the box？\u003c\/h4\u003e\n\u003ctable style=\"width: 100%; max-width: 800px; table-layout: fixed;\" data-mce-style=\"width: 100%; max-width: 800px; table-layout: fixed;\"\u003e\n\u003ccolgroup\u003e \u003ccol style=\"width: 50%;\" data-mce-style=\"width: 50%;\"\u003e \u003ccol style=\"width: 50%;\" data-mce-style=\"width: 50%;\"\u003e \u003c\/colgroup\u003e\n\u003cthead\u003e\n\u003ctr\u003e\n\u003cth\u003eItem\u003c\/th\u003e\n\u003cth\u003eQuantity\u003c\/th\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eM01-BT Amplifier\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eBluetooth Antenna\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e32V 5A Power Adapter\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eUser’s Manual\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/thead\u003e\n\u003c\/table\u003e\n\u003cdiv style=\"display: flex; align-items: center; height: 20px;\"\u003e\n\u003cimg style=\"width: 30px; height: 30px;\" alt=\"Download\" src=\"https:\/\/cdn.shopifycdn.net\/s\/files\/1\/2251\/7913\/files\/7.jpg?v=1638263331\"\u003e \u003ca href=\"https:\/\/cdn.shopifycdn.net\/s\/files\/1\/2251\/7913\/files\/M01_0225.pdf?v=1638177867\"\u003eM01 User Manual\u003c\/a\u003e\n\u003c\/div\u003e\n\u003cdiv style=\"display: flex; align-items: center; height: 20px;\"\u003e\u003cbr\u003e\u003c\/div\u003e\n\u003ch3 style=\"display: flex; align-items: center; height: 20px;\"\u003eCompare with similar items:\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003cp\u003e\u003ca href=\"https:\/\/fosiaudioshop.com\/products\/subwoofer-amplifier-m02\" title=\"Fosi Audio M02 Subwoofer Amplifier 100W adopt TI TPA3116D2 Chip\" target=\"_blank\"\u003eM02 Subwoofer Amp 100W\u003c\/a\u003e\u003c\/p\u003e\n\u003c\/li\u003e\n\u003cli\u003e\n\u003cp\u003e\u003ca href=\"https:\/\/fosiaudioshop.com\/products\/subwoofer-amplifier-m03-300watts-mono-amp-full-frequency-and-sub-bass-switchable-amplifier\" title=\"Fosi Audio M03 Subwoofer Amplifier adopt TI TPA3255 Chip 300W\" target=\"_blank\"\u003eM03 Subwoofer Amplifier 200W\u003c\/a\u003e\u003c\/p\u003e\n\u003c\/li\u003e\n\u003cli\u003e\n\u003cp\u003e\u003ca title=\"M04 Amplifier Subwoofer Amp 100W\" href=\"https:\/\/fosiaudioshop.com\/products\/fosi-audio-mono-amplifier-subwoofer-amp-100w-with-bass-power-amplifier-for-home-passive-speaker?_pos=1\u0026amp;_sid=365b3180f\u0026amp;_ss=r\" target=\"_blank\"\u003eM04 Amplifier Subwoofer Amp 100W\u003c\/a\u003e\u003c\/p\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e","brand":"Fosi Audio","offers":[{"title":"Default Title","offer_id":47773278109914,"sku":"M01-BT+32V","price":89.99,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0818\/9706\/2618\/files\/products_1_5b0fc0a7-ff6a-4573-a373-c521a9e02b9c.jpg?v=1776428583","url":"https:\/\/eu.fosiaudio.com\/es\/products\/fosi-audio-m01-bt-bluetooth-one-channel-mono-amplifier-for-home-speakers","provider":"Fosi Audio EU","version":"1.0","type":"link"}
