{"product_id":"fosi-audio-phono-preamp-for-turntable-preamplifier-mm-phonograph-preamplifier-with-gain-gear-mini-stereo-audio-hi-fi-pre-amplifier-for-record-player-with-dc-12v-power-box-x2","title":"Fosi Audio Box X2 MM Turntable Phono Preamplifier","description":"\u003cul class=\"a-unordered-list a-vertical a-spacing-none\"\u003e\n\u003cli\u003e\n\u003cp\u003eTube MM Phono Preamplifier: This Fosi Audio phono preamplifier removes low-frequency noise and ensures clear sound quality by converting phono signals to line-level signals using high-quality components and low-noise integrated circuits. It is designed to safeguard your turntable thanks to its grounding post\u003c\/p\u003e\n\u003c\/li\u003e\n\u003cli\u003e\n\u003cp\u003e3 Switchable Gain Modes: You can switch between 3 modes: 39, 42, or 45 dB. High compatibility and customizable control are provided by the adjustable gain levels. Also, it has very good circuitry and entry-level, high-end analog sound\u003c\/p\u003e\n\u003c\/li\u003e\n\u003cli\u003e\n\u003cp\u003eTube Preamplifier: With a 3.5mm AUX input, it's also a tube preamp. Fosi Audio used high-quality component parts for the design and assemblage of this phono preamplifier. You can enjoy a very warm and smooth sound\u003c\/p\u003e\n\u003c\/li\u003e\n\u003cli\u003e\n\u003cp\u003eApplicable Vacuum Tube Model: The compatible vacuum tube models are 6K4, 6J1, 6J4, GE5654, 6AK5, 66, etc. To make changes to your stereo system yourself, simply swap out the vacuum tubes. Consider that distinct tubes produce various sounds\u003c\/p\u003e\n\u003c\/li\u003e\n\u003cli\u003e\n\u003cp\u003ePackage Content: You will get 1 x Box X2 phono preamp, 2 x vacuum tubes, 1 x RCA cable, 1 x power adaptor, and 1 x user manual\u003c\/p\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch4\u003e\n\u003cbr\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/2251\/7913\/files\/001_4ecf75d1-9bda-492b-b892-53865c633b41.jpg?v=1745569020\" alt=\"\"\u003e\n\u003c\/h4\u003e\n\u003ch4\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/2251\/7913\/files\/003_1_6420f50f-f632-480c-8d8a-0c8d4afb8470.jpg?v=1745569020\" alt=\"\"\u003e\u003c\/h4\u003e\n\u003ch4\u003e\n\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/2251\/7913\/files\/005_3_5e01bde1-b876-40f0-a5b2-4ea7bfefef33.jpg?v=1745569020\" alt=\"\"\u003e\u003cbr\u003eSpecifications\u003c\/h4\u003e\n\u003ctable style=\"width: 100%; max-width: 800px; table-layout: fixed;\"\u003e\n\u003ccolgroup\u003e \u003ccol style=\"width: 50%;\"\u003e \u003ccol style=\"width: 50%;\"\u003e \u003c\/colgroup\u003e\n\u003cthead\u003e\n\u003ctr\u003e\n\u003cth\u003eSpecifications\u003c\/th\u003e\n\u003cth\u003eDetails\u003c\/th\u003e\n\u003c\/tr\u003e\n\u003c\/thead\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003eModel\u003c\/td\u003e\n\u003ctd\u003eBOX X2\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eInput Mode\u003c\/td\u003e\n\u003ctd\u003eRCA+3.5mm AUX\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eOutput Mode\u003c\/td\u003e\n\u003ctd\u003eActive Speakers\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eFrequency Response\u003c\/td\u003e\n\u003ctd\u003eStandard RIAA\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eTHD\u003c\/td\u003e\n\u003ctd\u003e≤ 0.1%\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eSNR\u003c\/td\u003e\n\u003ctd\u003e≥ 98dB\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eProduct Weight\u003c\/td\u003e\n\u003ctd\u003e0.66 lb\/300g\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDevice Dimension\u003c\/td\u003e\n\u003ctd\u003e4.66 inch\/3.85 inch\/1.29 inch\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDC Input Range\u003c\/td\u003e\n\u003ctd\u003e12V\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eInput Voltage Range\u003c\/td\u003e\n\u003ctd\u003eAC 110V - 240V\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eOutput Voltage Level\u003c\/td\u003e\n\u003ctd\u003e600 Mv @3mV 1kHz\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003ePower Supply\u003c\/td\u003e\n\u003ctd\u003e12V 1.5A\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch4\u003e\n\u003cbr\u003eWhat‘s in the box？\u003c\/h4\u003e\n\u003ctable style=\"width: 100%; max-width: 800px; table-layout: fixed;\"\u003e\n\u003ccolgroup\u003e \u003ccol style=\"width: 50%;\"\u003e \u003ccol style=\"width: 50%;\"\u003e \u003c\/colgroup\u003e\n\u003cthead\u003e\n\u003ctr\u003e\n\u003cth\u003eItem\u003c\/th\u003e\n\u003cth\u003eQuantity\u003c\/th\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eBox X2 Phono Preamp\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eVacuum Tubes\u003c\/td\u003e\n\u003ctd\u003ex 2\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e12V 1.5A Power Adapter\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eRCA Cable\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eUser’s Manual\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/thead\u003e\n\u003c\/table\u003e\n\u003cdiv style=\"display: flex; align-items: center; height: 20px;\"\u003e\u003cbr\u003e\u003c\/div\u003e\n\u003cdiv style=\"display: flex; align-items: center; height: 20px;\"\u003e\n\u003cimg style=\"width: 30px; height: 30px;\" alt=\"Download\" src=\"https:\/\/cdn.shopifycdn.net\/s\/files\/1\/2251\/7913\/files\/7.jpg?v=1638263331\"\u003e \u003ca href=\"https:\/\/cdn.shopifycdn.net\/s\/files\/1\/2251\/7913\/files\/BOX_X2_0916.pdf?v=1638177867\"\u003eBOX X2 User Manual\u003c\/a\u003e\n\u003c\/div\u003e\n\u003cdiv style=\"text-align: left;\"\u003e\u003cbr\u003e\u003c\/div\u003e\n\u003cdiv style=\"text-align: left;\"\u003e\u003ciframe width=\"480\" height=\"300\" src=\"https:\/\/www.youtube.com\/embed\/Rx3-dG4PQIE\" title=\"YouTube video player\"\u003e\u003c\/iframe\u003e\u003c\/div\u003e\n\u003cdiv style=\"text-align: left;\"\u003e\n\u003ch3\u003eCompare with similar items:\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003e\u003ca href=\"https:\/\/fosiaudio.com\/products\/fosi-audio-box-x1-phono-preamp-mm-turntable-preamplifer-with-3-5mm-aux-rca-output?_pos=2\u0026amp;_sid=d6baad285\u0026amp;_ss=r\" title=\"BOX X1-MM Phono Preamp\" target=\"_blank\"\u003eBOX X1-MM Phono Pream\u003c\/a\u003e\u003c\/li\u003e\n\u003cli\u003e\u003ca href=\"https:\/\/fosiaudio.com\/products\/fosi-audio-bluetooth-phono-preamp-for-turntable-phonograph-preamplifier-with-ge5654-vacuum-tube-amplifier-audio-hifi-box-x3-diy?_pos=1\u0026amp;_sid=11e8574bd\u0026amp;_ss=r\" title=\"Box X3 Bluetooth Phono Preamp\" target=\"_blank\"\u003eBox X3 Bluetooth Phono Preamp\u003c\/a\u003e\u003c\/li\u003e\n\u003cli\u003e\u003ca title=\"Box X4 Phono Preamp with treble and bass control\" href=\"https:\/\/fosiaudio.com\/products\/phono-preamp-headphone-amplifier-with-jan-5654w-vacuum-tubes-for-mm-turntable-phonograph-preamplifier-for-record-player-with-volume-bass-treble-control-hi-fi-pre-amp-fosi-audio-box-x4?_pos=3\u0026amp;_sid=2bd1180e5\u0026amp;_ss=r\" target=\"_blank\"\u003eBox X4 Phono Preamp with treble and bass control\u003c\/a\u003e\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003c\/div\u003e","brand":"Fosi Audio","offers":[{"title":"Default Title","offer_id":47773277978842,"sku":"BOX X2+12V","price":69.99,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0818\/9706\/2618\/files\/B07XNTHHBP.MAIN.jpg?v=1776428574","url":"https:\/\/eu.fosiaudio.com\/es\/products\/fosi-audio-phono-preamp-for-turntable-preamplifier-mm-phonograph-preamplifier-with-gain-gear-mini-stereo-audio-hi-fi-pre-amplifier-for-record-player-with-dc-12v-power-box-x2","provider":"Fosi Audio EU","version":"1.0","type":"link"}
