{"product_id":"fosi-audio-sk02-desktop-dac-headphone-amp","title":"Fosi Audio SK02 Desktop DAC Headphone Amplifier","description":"\u003cul\u003e\n\u003cli class=\"a-spacing-mini\"\u003e\u003cspan class=\"a-list-item\"\u003eCompact Yet Powerful: The SK02 employs a minimalist and stylish design language. Despite its small size, it boasts mighty features. It supports DSD256 and PCM 32bit\/384kHz high-resolution decoding, along with 3.5mm single-ended and 4.4mm balanced headphone outputs. Its robust power can easily drive a wide range of headphones and IEMs with an impedance range of 16-300 ohms.\u003cbr\u003e\u003cbr\u003e\u003c\/span\u003e\u003c\/li\u003e\n\u003cli class=\"a-spacing-mini\"\u003e\u003cspan class=\"a-list-item\"\u003eStunning Performance: It features a high-end ESS SABRE ES9038Q2M DAC and SGM8262 op-amps. Its excellent circuit design ensures superior parameters with a SNR as high as 120dB, a low noise floor of only 3.7μV, and an incredibly low THD of 0.001%. The 4.4mm balanced output power reaches an impressive 1100mW at 32 ohms. The exceptional high-resolution capability and pure sound quality make every listening experience an extraordinary sensory journey.\u003cbr\u003e\u003cbr\u003e\u003c\/span\u003e\u003c\/li\u003e\n\u003cli class=\"a-spacing-mini\"\u003e\u003cspan class=\"a-list-item\"\u003eUser-Friendly Design: The SK02 requires no drivers and offers plug-and-play convenience. It integrates a big multi-functional control knob, allowing easy access to power on\/off, play\/pause, and volume adjustments. The unit features quick-switch buttons for high\/low gain and input modes. Additionally, its colorful indicator lights enable effortless identification of the current working mode and the song's sampling rate.\u003cbr\u003e\u003cbr\u003e\u003c\/span\u003e\u003c\/li\u003e\n\u003cli class=\"a-spacing-mini\"\u003e\u003cspan class=\"a-list-item\"\u003eRemarkable Versatility: Supports USB and optical input, widely applicable for decoding with computers, laptops, CD players, TVs, and projectors. Not only can it function as a headphone amplifier, but it can also serve as a preamp, pairing with active speakers or an amplifier like Fosi Audio V3, ZA3, TB10D amp, and passive speakers to form a desktop listening or home audio system.\u003cbr\u003e\u003cbr\u003e\u003c\/span\u003e\u003c\/li\u003e\n\u003cli class=\"a-spacing-mini\"\u003e\u003cspan class=\"a-list-item\"\u003eExquisite and Durable: The SK02 is crafted from a single piece of aluminum alloy using CNC machining and a delicate sandblasting process. This not only gives it an exquisite appearance but also ensures lasting durability. In addition, Fosi Audio pledges to provide a 24-month worry-free warranty and responsive customer service to all users.\u003cbr\u003e\u003cbr\u003e\u003c\/span\u003e\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cdiv style=\"text-align: start;\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/2251\/7913\/files\/2_66a5a374-20a7-4afc-9282-28619b05d214.jpg?v=1708918180\" alt=\"SK02 headphone amplifier\"\u003e\u003c\/div\u003e\n\u003cdiv style=\"text-align: start;\"\u003e\n\u003cimg alt=\"3.5mm Single-End and 4.4mm Balanced\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/2251\/7913\/files\/5_7c01d691-b202-4498-9c4e-25dca23e5e49.jpg?v=1708918361\"\u003e\u003cimg alt=\"SABRE ES9038Q2M DAC \u0026amp; SGM8262 Op-Amps\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/2251\/7913\/files\/6_ad0b0757-e892-4d20-a713-2898ab31d6f9.jpg?v=1708918382\"\u003e\u003cimg alt=\"Supports High-Res PCM384kHz \u0026amp; DSD256\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/2251\/7913\/files\/8_13a3adcd-15c3-42be-8207-7499d2ef2235.jpg?v=1708918453\"\u003e\n\u003c\/div\u003e\n\u003cdiv style=\"text-align: start;\"\u003e\n\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/2251\/7913\/files\/9_2048x2048.png?v=1708916866\" alt=\"Gain and Input\" style=\"margin-bottom: 16px; float: none;\"\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/div\u003e\n\u003ctable style=\"width: 100%; max-width: 800px; table-layout: fixed;\"\u003e\n\u003ccolgroup\u003e \u003ccol style=\"width: 50%;\"\u003e \u003ccol style=\"width: 50%;\"\u003e \u003c\/colgroup\u003e\n\u003cthead\u003e\n\u003ctr\u003e\n\u003cth\u003eSpecifications\u003c\/th\u003e\n\u003cth\u003eDetails\u003c\/th\u003e\n\u003c\/tr\u003e\n\u003c\/thead\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003eModel\u003c\/td\u003e\n\u003ctd\u003eSK02\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eInput\u003c\/td\u003e\n\u003ctd\u003e\u003cspan\u003eUSB\/OPT\u003c\/span\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eOutput\u003c\/td\u003e\n\u003ctd\u003e\n\u003cp\u003e3.5mm Headphone,\u003cbr\u003e4.4mm Headphone,\u003cbr\u003e3.5MM line out\/OPT\u003c\/p\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eMax Power Output\u003c\/td\u003e\n\u003ctd\u003e\n\u003cp\u003e3.5mm: 190mW@32Ω\u003cbr\u003e4.4mm: 755mW@32Ω\u003c\/p\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eFrequency Range\u003c\/td\u003e\n\u003ctd\u003e20Hz-20kHz (±0.02dB)\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eTHD\u003c\/td\u003e\n\u003ctd\u003e≤0.001% @ 1kHz \u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eSNR\u003c\/td\u003e\n\u003ctd\u003e3.5mm Headphone: \u003cbr\u003eLow Gain:116dB \u003cbr\u003eHigh Gain:120dB \u003cbr\u003e\u003cbr\u003e4.4mm Headphone: \u003cbr\u003eLow Gain:110dB \u003cbr\u003eHigh Gain:115dB\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eHeadphone matching impedance\u003c\/td\u003e\n\u003ctd\u003e16-300Ω\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003ePC-USB Sampling Rate\u003c\/td\u003e\n\u003ctd\u003e32Bit\/384KHz DSD256\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eOPT Sampling Rate\u003c\/td\u003e\n\u003ctd\u003e24Bit\/192KHz\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDAC Chip\u003c\/td\u003e\n\u003ctd\u003eES9038Q2M\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDevice Dimension\u003c\/td\u003e\n\u003ctd\u003e4.76*2*1.69inch\u003cbr\u003e(121*51*43mm)\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eNet Weight\u003c\/td\u003e\n\u003ctd\u003e0.84lb\/380g\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003ePower Supply\u003c\/td\u003e\n\u003ctd\u003e5V, USB Type-C\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch4\u003e\n\u003cbr\u003eWhat‘s in the box？\u003c\/h4\u003e\n\u003cp\u003eItem Quantity Fosi Audio Sk02 Headphone Amp x 1, \u003cbr\u003e2-in-1 USB-A\/C to C Cable x 1, \u003cbr\u003eUser’s Manual x 1\u003cbr\u003e\u003cbr\u003e\u003cspan style=\"color: #51a1ba;\"\u003e\u003ca style=\"color: #51a1ba;\" href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/2251\/7913\/files\/SK02_User_Manual.pdf\"\u003eSK02 User Manual\u003c\/a\u003e \u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan style=\"color: #51a1ba;\"\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/2251\/7913\/files\/SK02.zip?v=1709168833\" style=\"color: #51a1ba;\"\u003eSK02 Windows 7 Drivers\u003c\/a\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003ctable style=\"width: 100%; max-width: 800px; table-layout: fixed;\"\u003e\u003ccolgroup\u003e \u003ccol style=\"width: 50%;\"\u003e \u003ccol style=\"width: 50%;\"\u003e \u003c\/colgroup\u003e\u003c\/table\u003e","brand":"Fosi Audio","offers":[{"title":"Obsidian","offer_id":47773279912154,"sku":"SK02","price":109.99,"currency_code":"EUR","in_stock":true},{"title":"Orange","offer_id":47773279944922,"sku":"SK02-O","price":109.99,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0818\/9706\/2618\/files\/SK02_b05d080d-15a5-4d58-9637-4ef3ed0df291.jpg?v=1776428562","url":"https:\/\/eu.fosiaudio.com\/es\/products\/fosi-audio-sk02-desktop-dac-headphone-amp","provider":"Fosi Audio EU","version":"1.0","type":"link"}
