{"product_id":"headphone-amplifier-vacuum-tube-headphone-amp-mini-hi-fi-stereo-audio-with-low-ground-noise-output-protection-for-headphones-fosi-audio-p2","title":"Fosi Audio P2 Headphone Amplifier","description":"\u003cul class=\"a-unordered-list a-vertical a-spacing-none\"\u003e\n\u003cli\u003e\n\u003cp\u003eExcellent sound performance: Low ground noise, built-in output protect the circuit, no buzzing or ringing noise, Audiophile-level sound quality, exclusively designed for the customers who pursue HiFi sound; and safe for your expensive headphones.\u003c\/p\u003e\n\u003c\/li\u003e\n\u003cli\u003e\n\u003cp\u003eStereo and Preamplify: Headphones amp also can be used as a stereo preamp, Parallel 3.5mm and RCA stereo inputs, 6.35mm headphone output, include a 6.35mm to 3.5mm adapter;\u003c\/p\u003e\n\u003c\/li\u003e\n\u003cli\u003e\n\u003cp\u003eHigh-performance: P2 is a Hi-Fi tube headphone amp, 2 X 5725 tubes can easily power high-performance headphones including the HD580, HD600, HD650, K701, K702, Q701, and many more, recommend 32-300ohm headphones\u003c\/p\u003e\n\u003c\/li\u003e\n\u003cli\u003e\n\u003cp\u003eEasy replace tube: Tubes can be replaced by \u003ca href=\"https:\/\/fosiaudioshop.com\/collections\/other\/products\/tested-matched-pair-2-tubes-7-pin-ge-jan-5654w-fully-tested-vacuum-tubes-upgrade-for-6ak5-6j1-6j1p-ef95-ge-5654w-platinum-grade-pair\" title=\"JAN 5654W\"\u003eJAN\u003c\/a\u003e \u003cspan\u003e\u003ca href=\"https:\/\/fosiaudioshop.com\/collections\/other\/products\/tested-matched-pair-2-tubes-7-pin-ge-jan-5654w-fully-tested-vacuum-tubes-upgrade-for-6ak5-6j1-6j1p-ef95-ge-5654w-platinum-grade-pair\" title=\"JAN 5654W\"\u003e5654W\u003c\/a\u003e\/\u003c\/span\u003e6j1\/6J4\/GE5654\/6AK5\/6*1n\/ E180F\/6ж9П\/EF861\/6688 tubes etc\u003c\/p\u003e\n\u003c\/li\u003e\n\u003cli\u003e\n\u003cp\u003eExquisite appearance: Small Compact Size, All aluminum alloy shell and come with an 18-month manufacturer's warranty.\u003c\/p\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cdiv style=\"text-align: left;\"\u003e\u003cimg src=\"https:\/\/cdn.shopifycdn.net\/s\/files\/1\/2251\/7913\/files\/a_1_321e0c35-e50d-4838-95f2-cfd7305d6c5f.jpg?v=1637637718\" alt=\"Headphone Amplifier Vacuum Tube Headphone Amp Mini Hi-Fi Stereo Audio with Low Ground Noise Output Protection for Headphones Fosi Audio P2\" style=\"float: none;\"\u003e\u003c\/div\u003e\n\u003ch4\u003e\n\u003cbr\u003e\u003cbr\u003eSpecifications\u003c\/h4\u003e\n\u003ctable style=\"width: 100%; max-width: 800px; table-layout: fixed;\"\u003e\n\u003ccolgroup\u003e \u003ccol style=\"width: 50%;\"\u003e \u003ccol style=\"width: 50%;\"\u003e \u003c\/colgroup\u003e\n\u003cthead\u003e\n\u003ctr\u003e\n\u003cth\u003eSpecifications\u003c\/th\u003e\n\u003cth\u003eDetails\u003c\/th\u003e\n\u003c\/tr\u003e\n\u003c\/thead\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003eModel\u003c\/td\u003e\n\u003ctd\u003eP2\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eOP-Amp\u003c\/td\u003e\n\u003ctd\u003eNE5532\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eHeadphones Output\u003c\/td\u003e\n\u003ctd\u003e16-64Ohm\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eHeadphone Impedance\u003c\/td\u003e\n\u003ctd\u003e32-600 Ω\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eInput Mode\u003c\/td\u003e\n\u003ctd\u003e3.5mm Audio jack, Stereo L \/ R RCA\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eFrequency Range\u003c\/td\u003e\n\u003ctd\u003e20Hz-20 kHz (± 3dB)\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eTHD\u003c\/td\u003e\n\u003ctd\u003e≤0, 03%\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eSNR\u003c\/td\u003e\n\u003ctd\u003e≥ 95db\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eInput Sensitivity\u003c\/td\u003e\n\u003ctd\u003e0.2mV\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDevice Dimension\u003c\/td\u003e\n\u003ctd\u003eL99 * W98 * H33 mm\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDevice Weight\u003c\/td\u003e\n\u003ctd\u003e0.25 kg\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eOperating Voltage\u003c\/td\u003e\n\u003ctd\u003eDC12V\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch4\u003e\n\u003cbr\u003eWhat‘s in the box？\u003c\/h4\u003e\n\u003ctable style=\"width: 100%; max-width: 800px; table-layout: fixed;\"\u003e\n\u003ccolgroup\u003e \u003ccol style=\"width: 50%;\"\u003e \u003ccol style=\"width: 50%;\"\u003e \u003c\/colgroup\u003e\n\u003cthead\u003e\n\u003ctr\u003e\n\u003cth\u003eItem\u003c\/th\u003e\n\u003cth\u003eQuantity\u003c\/th\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eP2 Headphone Amplifier\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e5725 Vacuum Tubes\u003c\/td\u003e\n\u003ctd\u003ex 2\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDC 12V Power Supply\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e6.35mm to 3.5mm Adapter\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eUser’s Manual\u003c\/td\u003e\n\u003ctd\u003ex 1\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/thead\u003e\n\u003c\/table\u003e\n\u003ch3\u003eCompare with similar items:\u003c\/h3\u003e\n\u003cp\u003e\u003cspan class=\"a-list-item\"\u003e\u003ca href=\"https:\/\/fosiaudioshop.com\/products\/fosi-audio-p1-pro-bluetooth-5-0-tube-pre-amplifier-mini-hi-fi-stereo-buffer-preamplifier-6j5-vacuum-tube-preamp-with-treble-bass-volume-control-for-home-theater-audio-system-with-power-adapter?_pos=3\u0026amp;_sid=252df3f88\u0026amp;_ss=r\" title=\"P1 Pro Bluetooth 5.0 Tube Preamplifier\" target=\"_blank\"\u003eP1 Pro Bluetooth 5.0 Tube Preamplifier\u003c\/a\u003e\u003cbr\u003e\u003ca href=\"https:\/\/fosiaudioshop.com\/products\/vacuum-tube-pre-amplifier-p1?_pos=1\u0026amp;_sid=252df3f88\u0026amp;_ss=r\" title=\"P1 Vacuum Tube Pre-Amplifier\" target=\"_blank\"\u003eP1 Vacuum Tube Pre-Amplifier\u003c\/a\u003e\u003cbr\u003e\u003c\/span\u003e\u003c\/p\u003e","brand":"Fosi Audio","offers":[{"title":"Default Title","offer_id":47773278142682,"sku":"P2+12V","price":49.99,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0818\/9706\/2618\/files\/001_82f9a1df-4daf-47b0-8052-a9c4989e5348.jpg?v=1776428574","url":"https:\/\/eu.fosiaudio.com\/es\/products\/headphone-amplifier-vacuum-tube-headphone-amp-mini-hi-fi-stereo-audio-with-low-ground-noise-output-protection-for-headphones-fosi-audio-p2","provider":"Fosi Audio EU","version":"1.0","type":"link"}
