{"product_id":"fosi-audio-zd3-fully-balanced-desktop-dac","title":"Fosi Audio ZD3 Fully Balanced Desktop DAC","description":"\u003cp\u003e\u003cstrong\u003eFlagship Desktop DAC\u003c\/strong\u003e: A fully balanced digital-to-analog converter preamp with multiple inputs and outputs. Fosi Audio's first DAC to support HDMI ARC input and comes equipped with a high-performance ES9039Q2M chip to deliver rich and superior sound.\u003cbr\u003e\u003cbr\u003e\u003cstrong\u003ePremium Chipset\u003c\/strong\u003e: The ZD3 features the chipset consisting of XMOS XU316+ES9039Q2M+QCC3031+LME49720. It supports high audio resolution, with a maximum capability of DSD512 and PCM 32bit\/768kHz sampling rates, providing unparalleled clarity and depth.\u003cbr\u003e\u003cbr\u003e\u003cstrong\u003eVersatile \u0026amp; Flexible\u003c\/strong\u003e: The ZD3 offers comprehensive connectivity, supporting inputs like Bluetooth, USB, OPT, COAX, HDMI ARC, and balanced XLR\/RCA outputs. This flexibility allows you to customize your audio system to suit various setups and scenarios\u003cbr\u003e\u003cbr\u003e\u003cstrong\u003eEase of Use\u003c\/strong\u003e: The ZD3 adopts a 1.5-inch OLED display, remote control, preamp bypass switch, and 12V trigger in\/out interfaces, allowing synchronized power on\/off with other home audio devices, all for a good user experience.\u003cbr\u003e\u003cbr\u003e\u003cstrong\u003eFamily Design\u003c\/strong\u003e: Featuring the same design language as the ZA3 amplifier: compact and exquisite appearance and audiophile-grade components for high performance and excellent sound quality. Pair it with the ZA3 to create a robust home audio system.\u003cbr\u003e\u003c\/p\u003e","brand":"Fosi Audio","offers":[{"title":"Default Title","offer_id":47773285122266,"sku":"C.03.ZD3.05","price":189.99,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0818\/9706\/2618\/files\/ZD3_a4fc9b35-911f-490d-930e-0cb8e1109e13.jpg?v=1776428566","url":"https:\/\/eu.fosiaudio.com\/pl\/products\/fosi-audio-zd3-fully-balanced-desktop-dac","provider":"Fosi Audio EU","version":"1.0","type":"link"}
