  • 24V 4.5A Power Adapter Description:
    AC110V-230V input;
    DC 24V 4.5A output;
    Connector size: 5.5*2.5mm
    Power adapter for class d amplifier;
  • BOX X5 16V 1A Power Adapter Description:
    Input: AC 110V or 230V, 50-60Hz
    Output: AC 16V 1A (Only for BOX X5, do not use with DC-type amplifiers)
    Cable Length: 1.2 meters
    Plug Type: Matches the country of your delivery address
    Important Note: This power adapter supplies AC (alternating current) output, not DC. It is exclusively designed for BOX X5 and should never be used with other amplifiers requiring DC power to avoid damage.
  • 5 stars: 12 (100%)
  • 4 stars: 0 (0%)
Michael Gould
Excellent Inexpensive Gear!!
Took a bit to get the exact power supply made by Fosi but my little amp does not shut down when I push it like it did with a generic power supply.
Alex
good power supply
Works as advertised
This drives my little Nobsound Q10 amplifier just fine.
r
robin moulang
Power supply
I bought a pre amp from Amazon in America and it was for 110 volt only so I needed to get one for 220 and the fosi website had them. Shipping was painless. Wish I just bought there first. Amazon really should warn people that the voltage won��t work when they see it going to a different region. Usually these power supplies are 110-220 range but not these ones.
Michele Cati
Great!!!
I love your products!!
g
gerard Mir�� Jou
Todo perfecto
Bien empaquetado. buen estado y buena calidad y el enchufe adecuado
Matthew A Taylor
Just got it today
Sounds great. Got it hooked up to a fosi bt20a and a pair of jvc cherry wood speakers with ceramic cones and they sound almost as good as my Klipsch speakers.
T.J. Galiardo
Fosi Audio 24V 4.5A Power supply for TDA7498E TPA3116 TAS5613 Amplifier
Mr David Girdlestone
Fosi Audio Review
I got in touch with Fosi to explain that the power supply for my amp had failed.
``although it took over 20 days to arrive, it��s here now and it works.
Assen Tzanov
Recommended
As described and working great.
Vincent Sedlmeyer
Fosi Audio 24V 4.5A 6A 8A Power supply for TDA7498E TPA3116 TAS5613 Amplifier
William Coar
Best products, prices and customer service!
I ordered a 24v 8a power supply to increase the wattage of my Fosi TP-02 mini amp. The first unit arrived with shipping damage, a cracked case, so I notified Fosi customer service. They immediately shipped out a replacement and it arrived today in perfect condition. Thank you!
