1.5m Dual 3.5mm to 4.4mm Upgraded Audiophile Headphone Cable.
Crafted with 48-strand super copper wire, featuring a twisted-braid design combined with an upgraded anti-vibration weave, and gold-plated pure copper connectors, this cable ensures high-fidelity audio transmission and exceptional durability.
  • 5 stars: 26 (100%)
  • 4 stars: 0 (0%)
Ethan McFenton
A beautiful cable for beautiful headphones. Quality feels great. Nice and flexible. Solid connectors. Zero issues.
Peter Zimmerli
Gamechanger
Fosi ZH3 mit diesem Kabel und den Planar 5 tönt hervorragend. Habt Ihr da Feenstaub drin?
David M.
Super high quality and very well packaged.
Very pleased with Fosi. They make superb Hi Fi products.
David McManus
Antonio Burguera Burguera
Muy buena compra
Muy buena compra
Jörg Beschmann
Great cable - well crafted
I have purchased the 4.4mm Upgraded Cable for i5 Planar Magnetic Headphones to use it with my Cayin R6. It's a real upgrade :-)
J?rg Beschmann
Alain Desroches
Bravo
Alain Desroches
Bravo
Laurent Schauls
Good quality cable
The cable feels well built and seems worth the price
LS
Good quality cable
Zbigniew Widenka
Soft and light cable. Good quality connectors.
Zbiwid
Sauro Turchi
A balanced cable that brings more musicality and involvement
I decided to invest in the balanced cable as an optional upgrade and I have no regrets.
Compared to the stock cable, the sound is significantly better: the instrument timbres are more beautiful, more separated, and more distinguishable; the various sound layers are more intelligible, refined, and well-structured; there is greater overall resolution, more harmonics, more micro-detail, and more ambient noise (based on recordings of live classical music performances); greater spatial depth and ambient reverberations; better, more precise, and better controlled low-frequency response; greater dynamics; and greater background silence, which therefore allows for more accurate overall focus.
Overall, this balanced cable represents a valid upgrade that allows these headphones to achieve superior performance.
Sauro Turchi
Christian Concepcion
Nice clarity very smooth on the bass .
G.B.
Excellent hesdphone cable and really good service from fosi audio.
Glenn Bryson
i
ismael gasca zavala
Me gusto
Creo que es un buen cable, se siente de buen material. solo que en la pagina no encontré descripción mas detallada del cable y me hubiera gustado saber un poco mas de sus características, el servicio muy bueno!!!
i
ismael gasca zavala
Me gusto
Creo que es un buen cable, se siente de buen material. solo que en la pagina no encontr�� descripci��n mas detallada del cable y me hubiera gustado saber un poco mas de sus caracter��sticas, el servicio muy bueno!!!
R. van Hoevelaken
Must have cable for the I5
I received my Fosi I5 with the standard cables and the upgraded cable.
I looked at and felt the standard cables and then the upgraded cable. To be honest, I haven't even tried the standard ones. They are really stiff and... uncomfortable.
The upgraded cable looks and feels much nicer. Best thing about it is it's flexibility.
You can fold the cable however you like or tuck it in your trouser pocket for example. Can't really do that with the standard cables.
Overall, a very high quality cable which is great to use. Expensive but worth it.
Ruud
Keith Robertson
Cable upgrading
The upgraded care cable has more give and manoeuvrability much more improved than the basic cable
Keith Robertson
Cable upgrading
