Fosi Audio BOX X1 MM Turntable Phono Preamp
Black Friday Exclusive Offer
- Converts Phono Signals: Compact ultra-low noise phono turntable preamp that converts phono signals to line-level signals with Low-noise integrated circuits and high-quality components to remove low-frequency noise to ensure clear sound quality. Designed with a grounding post to protect your turntable.
- Features Power Switch & 3.5MM Headphone Output: The unique power switch button design is very convenient to use. You can enjoy high-quality music with headphones through the 3.5 mm headphone output. Note: RCA line output and AUX headphone output can be output simultaneously.
- 3.5MM / RCA Output: BOX X1 supports MM turntable input, 3.5MM headphone output, and RCA line output for powered speakers. Note: You can connect a power amplifier through the 3.5MM or RCA output, then connect the passive speakers.
- MM Phono Preamplifier & DC12V Power Adapter: Output Voltage Level: 2V max (P-P) at 10K Ohms, SNR: 70dB, THD: ≤0.08% @ 1kHz and 3mV, Frequency Response: Standard RIAA. Equipped with DC12V high-quality power supply.
- Easy quick setup for all MM (moving magnet) cartridges, Metal Aluminum case protects the unit from vibrations and electromagnetic interference.
| Model | BOX X1 |
| Output Mode | 3.5MM headphone output + RCA output |
| Input Mode | MM turntable input, Grounding post input, 12V DC input |
| Output | Active(powered) speakers, Headphone, Amplifier |
| THD | ≤0.08% @ 1kHz and 3mV |
| SNR | 70dB |
| Product Weight | 0.35lb/161g |
| Device Dimension | 3.94×0.98×2.17 inch |
| DC Input Range | 12V |
| Input Voltage Range | AC 100V - 240V |
| Output Voltage Level | 2V max (P-P) at 10K Ohms |
| Power Supply | 12V 1.5A |
What's in the box?
| Box X1 Phono Preamp | x 1 |
| User’s Manual | x 1 |
Compare with similar items:
