80W Toroidal Transformer
Nippon Chemi-Con Capacitors
High-Reliability Rectifier
4-Core Regulation
  • Upgraded Design: Add Bluetooth to a subwoofer amplifier. M01-BT support Bluetooth and RCA input can drive most home passive speakers, passive subwoofers, and powered subwoofers. (Note: M01-BT is not suitable for active speakers). Easy to build a simple sound system with M01-BT.
  • Mini compact Class D Audio Amplifier. M01-BT SUB amp adopts ST Microelectronics TDA7498E high-performance chip, MAX power output up to 300Watts.
  • Switch to PBTL(As a full frequency mono amp): You can use the banana plugs or bare wires to connect the passive subwoofer to the M01-BT, use the RCA cable to connect the powered subwoofer to the M01-BT.
  • Switch to SUB(As a subwoofer amp): You can use the banana plugs or bare wires to connect the passive subwoofer to the M01-BT, use the RCA cable to connect the powered subwoofer to the M01-BT.
  • What you Get: M01-BT amplifier x1, Bluetooth antenna x1, User Manual x1, 24V/4.5A Power Adapter x1, AC Cord x1, 18-month worry-free warranty, and friendly customer service.
Model M01-BT
MAX Power Output 300W
RMS Power Output RMS220W@4Ω, RMS 110W@8Ω
Terminating Impedance 2-8Ω
Input Mode Bluetooth + RCA
Output Mode Passive Speaker + Powered Subwoofer
Frequency Range 20Hz - 20kHz (±3 dB)
Bass Frequency Range 20-200Hz
THD ≤0.05%
SNR ≥ 102dB
Input Sensitivity ≤ 0.2mV
Chip Set TDA7498E
DC Input Range 24-32V
Power Supply 24V 4.5A
M01-BT Amplifier x 1
Bluetooth Antenna x 1
32V 5A Power Adapter x 1
Compare with similar items:
Power Input
AC: 115V / 230V
Note:
Power Output
Operating Temperature
-20 ~ 40°C (-4°F ~ 104°F)
Temperature Rise Test
  • Fosi Audio PSU20*1
  • User Manual*1
  • AC Power Cord*1
