Operation Guide
  • 5 stars: 25 (86%)
  • 4 stars: 1 (3%)
  • 3 stars: 2 (7%)
  • 1 star: 1 (3%)
Marcelo Di Iorio
Good quality and stability. Perfect for the V3 Mono and others of similar size.
Yashar S.
Fosi Audio 3-Layer Acrylic Rack
Absolutely love it.
Yashiko
Absolutely love it.
Roberto A.
Great size and fit with fans
works very well with the fans attached above the Fosi monos, very quiet operation and esthetically pleasing, compared to fans sitting on top or below the monos
Roberto A
Nikolai Lyraan
Good quality
I got this off of a friend and I liked the quality alot
Nikolai Lyraan
Good quality
Cesar
Ajuste perfecto
El ajuste es Perfecto y se ve genial. Les muestro mi escritorio. Recomendado
Cesar
Ajuste perfecto
Wesley Van Nurden
Fosi Audio 3-Layer Acrylic Rack for Audio Components
James Mc Laughlin
Acrylic rack
Havent recieved it yet
SORIN PETRE
Excellent. Solid. Love it!
Ivan Puccinelli
Ivans great buy!!
It so fittingly perfect one of the best deal of my life well spent money!!
Ivan Puccinelli
Ivans great buy!!
f
federico faidutti
ok
tutto ok
f
fede fez
ok
tutto ok
David P.
Good idea poor execution
I really wanted to like this rack. My main issue is my ZP3 can only set on top. The ZP3 is too wide to fit between the support posts on the bottom or second level. This needs to be addressed by making the rack wider by 10mm (3/8") between the post locations.
A.B.
Space saving
Rack is sturdy and well made the cooling fans fit well and help cool my V3’s. I will not be worried about over heating them in the summer months. I may need to but another when I start adding to my collection of Fosi products.
Andrew Blacklaws
Space saving
Rack is sturdy and well made the cooling fans fit well and help cool my V3��s. I will not be worried about over heating them in the summer months. I may need to but another when I start adding to my collection of Fosi products.
Alfonso R.
Rack per mini Hi-Fi concreto e ben costruito ma costoso.
E' un'ottima soluzione, che nelle misure è pensata bene per contenere e mantenere in ordine la componentistica "Fosi Audio". Il prezzo è tuttavia eccessivo per quanto offerto: pur se gradevole esteticamente, si tratta pur sempre di un mobiletto largo solamente 28cm, alto 23 cm e profondo 18.
Graham M.
Audio rack
Beautifully engineered and finished, and needless to say, perfect for the job!
Graham Mead
Audio rack
Soureysen
Lovely little Rack for my Stack of Fosi Products
This is really a neat product, easy to assemble, fairly stable, the price looks about just right for me to have placed the order. It allows me to stack my ZD3, ZP3, 2x V3 Mono and LC30 in a much lower footprint
Soureysen
Leonidas Karantzas
Nice little rack for Fosi components. Easy to assemble, no tools needed.
Material seems to have no issue at all handling the heat of two V3 mono amps.
A bit marginal size, for the bigger components, like the ZP3 preamp, that was a tight fit.
I did end up buying two of these, so I can eventually fit all the components I plan to get.
Leonidas K
Stephen Kincaid
Fantastic bit of kit
This hi-fi stand compliments all of the range of fosi audio components that they sell
