  • Connector Material: Zinc alloy with chrome plating
  • Compatible with: ZA3, ZD3
  • Not compatible with: AES/EBU connectors
  • Premium Construction: Made with nylon braiding, PVC coating, copper foil shielding, anti-pull threads, and oxygen-free copper braiding shielding for superior durability and performance.
  • High-Quality Connectors: Features zinc alloy connectors with chrome plating, ensuring excellent conductivity and corrosion resistance for long-lasting use.
  • Balanced Audio Transmission: Designed for balanced audio signal transfer, it effectively reduces noise and interference, delivering high-fidelity sound over long distances.
  • Versatile Compatibility: Compatible with ZA3 stereo amplifier and ZD3 DAC Preamp, good for professional audio setups like microphones, mixers, and audio interfaces.
  • Compact and Space-Saving: The 0.3M (1ft) length is perfect for tight spaces, ensuring a neat and organized setup without excess cable clutter. Ideal for desktop microphones and compact audio interfaces.
  • XLR Cable*2
  • 5 stars: 43 (93%)
  • 4 stars: 3 (7%)
Ž
Željko Pavičić
I connected the V3 mono and ZD3 with cables.
The complete system
now sounds excellent.
Andr��s C.
High-quality XLR cables with a perfect fit
I purchased these XLR cables to connect my Fosi ZD3 DAC to the ZA3 amplifier, and they work perfectly.
The connectors fit securely without being overly tight, and the cable itself feels durable and well made. There is no audible noise or interference, and the balanced connection performs exactly as expected.
Kendi
Fosi Audio XLR
Great XLR cable from Fosi Audio. The build quality is excellent with sturdy connectors and a flexible, durable jacket. Signal transmission is crystal clear with absolutely zero hum or interference. Highly recommended for the price!"
Pavel Zabuty
bar code
Hi,
I bought these cables from a local supplier but they were just in a regular white bag. Could you tell me the bar code for this product please?
Thank you
Sanjay Jairathh
Fosi XLR Cable - Solid Built
Built quality of the cable is very good. Don't waste money on sponsored or mentioned by YouTube influncers.
DGJ
Great
Great
Ralph Parker
XLR cables.
The XLR cables are good. I should have just bought the longer ones. My bad. ??
George
No 1 product in
I would say, its an amazing product
S.G.
Excelente construcci��n
Terminaci��n de lujo. Muy recomendables.
Great
Denis ONFROY
Bon cable
Igor Mihaliska
Great product.
Ivano Sarra
Fosi Audio XLR Cable
Good quality cables. Connectors are fine, nice colours.
However I didn't find difference with respect to the RCA cables I was using. But I should say that my RCA cables have great quality, so the noise rejection is negligible in my case.
Skvěle zpracované kabely, které jsou navíc dělané na míru k Fosi komponentům. Naprosto geniální.
Ahmet YAL?IN
Thank you. Perfect
Tripp Morris
Fosi XLR cables.
Well made cables that work great with the ZD3 + dual ZA3 in mono. Will be purchasing again as I add more components.
KEITH DAVID ROBERTS
Fosi Audio XLR cables
Sound great right out of the box! Ordering some more!
Jay
Works Great
What more can you really ask for that a cable that looks nice and works well? That's really all ya need.
Ali Ma
Great cables
Good to use for any set up!
Thomas CH
Bonne finition et bon son
Tr��s content
Sigurd Skarsv?g
Luca Trinh
Pretty good
Very good quality I would recommend for price
Andres Cifuentes
Petar Sosic
Great value
Nice length, just to connect my ZD3 to ZP3. Fast delivery. Fosi audio making a name in Hi-Fi industry.
Viktor C
Feels like quality
I dont know mutch about audio equipment but this cabels feels and looks like quality
Tom��? Miniberger
Octavian Dumitrescu
Excellent quality cables
This cables are no brainer. Good quality, great build. Buy 0,3m variant if you want to stack ZH3/ZD3 with 1xZA3 in stereo mode and buy the 1,2m variant if you want to stack ZH3/ZD3 with 2xZA3 in monoblock. Great option for every scenario.
Ian L
Work perfectly
Great build quality for the price. No issues found.
Mark Ramsey
Excellent cable , well constructed does it��s job
Minh Son Xa
It a nice cable.
Just a very nice cable. Kinda smell, like that out of the factory smell. Metal is nice. Length is nice. Come in pair so don��t buy 2, you��ll get 4. Hard enough, but flexible too. Not thick.
