80W Toroidal Transformer
Nippon Chemi-Con Capacitors
High-Reliability Rectifier
4-Core Regulation
IM4 IEM Accessories include 4.4mm balanced cable, 3.5mm cable with microphone, and D2 DAC.
High-purity wire, low signal loss, enhance sound quality—clear treble, full bass, wide sound field.
Gold-plated plug, anti-oxidation, stable transmission; soft wire, anti-tangle, comfortable to use.
Plug and play, no modification needed. Suitable for daily commute, Hi-Fi listening, calls, games.
Specs: Fit IM4 IEM, 4.4mm balanced + 3.5mm with mic + D2 USB-C to 3.5mm DAC.
Power Input
AC: 115V / 230V
Note:
Power Output
Operating Temperature
-20 ~ 40°C (-4°F ~ 104°F)
Temperature Rise Test
  • Fosi Audio PSU20*1
  • User Manual*1
  • AC Power Cord*1
