- World's Smallest Portable CD Player
- Half-Exposed Disc Design
- MagSafe-Compatible Design & Bluetooth
- Flagship CS43198 DAC + 4.4mm Balanced
At just 102mm across, DISC Nano is the smallest portable CD player you can buy — real CD listening that fits in your pocket, not on a shelf. An 800mAh battery recharges over USB-C, so your albums go wherever you go.
The disc spins half in the open, so every press of Play becomes something you can see and feel. A snap-lock mount keeps the disc firmly seated while it spins.
A MagSafe-Compatible Design with an N52 magnet ring lets DISC Nano snap onto a mount, your fridge, or a desk stand (magnetic mounting only, no wireless charging). Pair over Bluetooth to send the disc straight to your headphones or speakers.
A Cirrus Logic CS43198 flagship DAC delivers 90mW through 3.5mm single-ended and 4.4mm balanced outputs — portable sound without the compromise. A 3.5mm optical out also turns DISC Nano into a CD transport for your desktop DAC.
Fast,Free Delivery
Free Shipping In 3-10 business days On Orders.
Global support
Our support team can help with product setup, order questions, and after-sales service.
Small in Size. Big on Music.
All the fun of playing real CDs, without the bulky setup. Just 102mm across, with Bluetooth listening through your favorite headphones or speakers.
See Your Music Spin.
Music That Fits Your Space.
Magnetic placement lets the player fit naturally on your desk, in the kitchen, or in
your music corner. Keep your music close without giving up extra space.
Less Skipping. More Listening.
A little movement shouldn't interrupt your favorite track. ESP electronic anti-shock
helps reduce skipping for a smoother listening experience.
Everything at a Glance.
See the ports,controls,and box contents in one place.
Product Specification
Audio DAC Chip Cirrus Logic CS43198
Output Interface 3.5mm Headphone/Optical Combo, 4.4mm Headphone
Compatible Headphone Impedance 16–300Ω
Max. Headphone Output Power L+R ≥86mW+86mW (32Ω, THD+N <1%)
Signal-to-Noise Ratio ≥100dB
Supported CD Formats CDDA, CD-R/CD-RW (partially readable), SACD with CD layer
Battery Capacity 800mAh
Charging Port USB-C
Input Voltage 5V/1A
Dimensions 102 × 102 × 29mm
Weight 210g
Does DISC Nano support MagSafe wireless charging?
No. DISC Nano features a MagSafe-compatible magnetic design for mounting only. It does not support wireless charging. Charging is handled through the USB-C port.
How do I connect DISC Nano to Bluetooth headphones or speakers?
Play a CD, then press the Mode button to enter Bluetooth mode. Set your headphones or speaker to pairing mode and keep it close; DISC Nano will try to connect automatically. If it connects to another device, press and hold Mode to clear the pairing. DISC Nano sends audio to Bluetooth devices but cannot receive audio from a phone.
Can I connect DISC Nano to an external DAC?
Yes. DISC Nano features a 3.5mm headphone/optical combo output. Using a compatible 3.5mm optical (Mini-TOSLINK) cable, you can send digital CD audio to an external DAC with an optical input. The same jack also supports regular 3.5mm wired headphones.
What types of CDs does DISC Nano support?
DISC Nano supports standard audio CDs (CDDA), selected CD-R/CD-RW discs, and the CD layer of hybrid SACDs. CD-R/CD-RW compatibility may vary depending on the disc and recording conditions. Original pressed audio CDs are recommended for the most reliable playback.
Does DISC Nano support USB music playback or CD ripping?
No. The USB-C port on DISC Nano is for power and charging only. It does not support USB music playback, data transfer, or CD ripping. If you need USB playback or CD ripping, the Fosi Audio Merak CD Player supports both features.
