Seamless System Integration
With optical and line outputs, it connects easily to DACs, amplifiers, or active speakers.
The included remote control allows convenient input/output switching and track selection.
A 12V Trigger output enables synchronized power with Fosi devices like ZD3 and ZA3.
Input: USB-A (USB flash drives), CD
Output: 3.5mm Headphones Jack, LINE, OPT, 12V Trigger
Precision CD Transport: Optimized servo system ensures accurate disc reading, smooth playback, and reduced wear, supporting stable long-term performance and consistent audio output.
All-in-One Audio Design: Combines CD player, DAC, and headphone amplifier in one unit, simplifying setup while maintaining low distortion and clear signal reproduction.
CD Ripping & USB Playback: Supports CD ripping to USB and direct playback, enabling easy conversion to digital files and convenient access without additional devices.
Flexible Output Connectivity: Multiple outputs support headphones, amplifiers, and active speakers, allowing seamless integration into desktop systems or larger audio setups.
ESP Anti-Skip Protection: 60-second buffering reduces interruptions from vibration, maintaining stable playback and improving reliability in movement or less controlled environments.
Chipset: SC6137D + CS43131 + TPA6120
Max Sampling Rate
  • CD: PCM 16bit / 96kHz
  • USB (USB flash drives): PCM 16bit / 96kHz
Headphone Impedance: 16–300Ω
CD Formats: CDDA, CD-R / CD-RW (partially readable). Original pressed discs are recommended
CD-R Formats: FLAC / WAV / WMA / AAC / MP3
SACD Playback: Only SACDs with a CD layer are supported
Formats for USB Drive Playback: MP3 / WAV / FLAC / AAC / APE / WMA
IR Remote Control: Supports a maximum operating distance of up to 7 meters
Input Voltage: DC 5V / 2A
Firmware Upgrade: Firmware can be updated online via a USB-A port using a USB flash drive
3.5mm Output Performance (CD)
Rated Output Power: L+R ≥ 210mW + 210mW (32Ω / THD+N < 1%)
SNR: 121 dB (A-weighted)
THD+N: 0.002% (A-weighted)
Dynamic Range: 121 dB
Noise Floor: ≤ 3µV (A-weighted)
LINE Output Performance (CD)
Output Level: ≥ 2Vrms
SNR: 124 dB (A-weighted)
THD+N: 0.0009% (A-weighted)
Dynamic Range: 124 dB
  • Merak
  • USB-A to USB-C Cable
  • IR Remote Control
  • 5 stars: 156 (78%)
  • 4 stars: 43 (21%)
  • 2 stars: 2 (1%)
Dario Moretti
My cd collection is starting a new life, thanks to Merak, good quality product.
Can' t compare sound quality with cd instead of streaming.....
Just wondering if bt 20 max can perform better with bluetooth, and if yes how much ?
Guilherme Lima
​I paired this CD player with a Fosi Audio T3 tube amp and a TP-02 subwoofer amp. The sound delivery is clean, punchy, and dynamic with zero playback issues so far.
​Its biggest strengths are the compact footprint—it fits easily onto a tight desktop setup without taking over the space—and the overall build quality, which feels notably sturdy and well-engineered. While it does lean a bit on the pricier side for a compact player, the reliability and clean audio output make it an easy recommendation.
Guilherme Lima
Stéphane Théus
I hesitated for a long time before buying this player, given the sheer number of competing products available. My main criteria were gapless playback, broad file format compatibility (especially FLAC), and the ability to play high-resolution (24-bit) audio from CDs burned in that format. To my delight, the Fosi Audio Merak handles all of this effortlessly.
Upon unboxing, the exemplary build quality and solid metal casing are immediately apparent. It is easy to use, and setting up the connections is straightforward.
CD ripping is possible via a dedicated function using a USB drive (FAT32).
I paired the Merak with the Fosi Audio ZD3 DAC using an optical connection. For my first listening session, I played the original Japanese pressing of Dire Straits’ *Brothers in Arms*. The Merak and ZD3 pairing works wonders; the sound reproduction is thrilling.
I am very pleasantly surprised by this player; it far exceeds my expectations regarding quality, and the value for money is remarkable. Listening to my CD collection with this device is a sheer pleasure. However, I do have three complaints: the remote control is ineffective beyond a range of 3 meters. Within that range, you have to be positioned directly in front of the unit for it to work properly—yet you have to be so close that the remote becomes redundant. I am expecting a replacement unit that should be free of this defect. A coaxial output would have been appreciated. Finally, the display doesn't show the song title, only the track number and duration; this is quite surprising, and I hope a future firmware update will add this feature (my old 2001 player had it, so I see no reason why it couldn't be done in 2026). I am deducting one star for these minor flaws. Important: Be sure to check the installed firmware version when you receive the Merak and update it immediately if necessary (mine arrived with version V14). I updated to version V19, which fixed—among other things—the issue where the beginning of tracks was cut off during playback. The update process is simple and well-documented in the user manual and in the video on the official Fosi website (support.fosiaudio.com/products/merak). A quick reminder: the USB drive used must contain no files and must be formatted as FAT32.
WILKINSON John
Awesome!! 👌👌👌
Stéphane Théus
I hesitated for a long time before buying this player, given the sheer number of competing products available. My main criteria were gapless playback, broad file format compatibility (especially FLAC), and the ability to play high-resolution (24-bit) CDs burned in that format. To my delight, the Fosi Audio Merak handles this effortlessly.
Upon unboxing, the exemplary build quality is immediately apparent, and the solid metal casing is impressive. It is easy to use, and setup is straightforward.
I paired the Merak with the Fosi Audio ZD3 DAC using an optical connection. My first listening session involved the original Japanese pressing of Dire Straits' *Brothers in Arms*. The Merak and ZD3 pairing works wonders; the sound reproduction is thrilling.
I am very pleasantly surprised by this player; it far exceeds my expectations regarding quality, and the value for money is remarkable. Listening to my CD collection on this device is a sheer pleasure. However, I have three complaints: the remote control requires a direct line of sight and close proximity to the unit; there is no coaxial output; and—most frustratingly, costing it a star in my rating—the first track loses a fraction of a second when playback starts. The same issue occurs when skipping forward or backward between tracks, whether using the buttons on the player or the remote. I updated the firmware, but the bug remains. I hope this will be fixed soon to earn the fifth star.
Christian Schumann
A realy good product. I am using it as a CD Transport for my Wiim Amp Pro. It sounds great for the price, it looks good and is mostly well built, and it fits the Wiim Amp Pro very well visually (sorry for the cross advertisement). But I have some points which make me lean towards 4 instead of 5 points:
- there should be some dampening when closing the unit. The lid simply falls down resulting in a plasticy sound
- A slight dent for easier opening would also be nice
- Yes, the display is small and hard to read, but it could make bettter use of the space by allowing to switch to a mode which only shows the track number in a bigger font
- Finding a suitable power supply was a bit problematic. I first used one which allowed for variable voltage between 3,6V and 6V with enough Watts, whiche sometimes worked, but the unit often would not come to life
- The remote control is a bit fuzzy sometimes with respect to connectivity
Federico Pellegrino
Ce petit lecteur cd est vraiment genial!!!
La qualite de construction est la, tout l’appareil est en aluminium (sauf la palque du dessous qui est en plastique, et le dessus en acrylique transparent), de plus il est très compacte.
Pour ce qui est du son, il est vraiment bon! Le DAC a l’interieur fait tres bien son job, le son est tres detaillé tout en restant neutre et non aggressif. Il est tres plaisant à écouter.
L’ampli casque aussi est plutot bon et puissant, j’ai pus tester plusieurs casques dessus et tous sonnent bien et assez fort (le max que j’ai testé c’est un casque a 120ohms).
Petit plus pour la telecommande vraiment pratique, qui est plutot rare pour les lecteurs cd de cette gamme!
Seul petit point négatif, la fonction pour ripper les CD sur clé USB ne fonctionne pas... J'ai essayé une bonne quinzaine de fois, avec plusieurs clés usb différentes et de capacité différentes.
En somme, si vous cherchez un lecteur cd pour chez vous, ne cherchez pas plus loin, ce lecteur possede toutes les fonctionnalités essentielles tout en etant joli est en ayant des performances vraiemnt excellentes pour le prix!
Joana Jacob
Great device, absolutely love it
Ian Jackson
What a great little unit! Looks smart and cool,sounds sweet and a bargain at the price.Thank you!
Ez
Great quality and value
WARREN BROWN
Great little cd player, using it as a transport on my main system and I can’t fault it, great build for the money and it’s got a remote.
Aleksandr Marmeljuk
I am really happy with a sound and quality!
Dave Bausher
Great Player
Luis Daniel Diaz
Andrew Tucker
Love my Merak CD Player
Anyway to the review.
AndrewT
Michael B
The CD Player I was missing
DanR2C
Great product!
