Fosi Audio ZH1 Smart-Tuned Fully Balanced Desktop DAC Amp
- AI Smart PEQ Tuning
- 2300mW Fully Balanced Power
- HiFi & Gaming Versatility
- Dynamic Display & RGB Control
Generate personalized PEQ settings with one tap using AI presets, Harman Target matching, and web-based visual EQ control. - 2300mW Fully Balanced Power
ES9039Q2M DAC, XMOS XU316, and dual-power balanced architecture deliver up to 2300mW @ 32Ω with ultra-low 1.9μV noise. - HiFi & Gaming Versatility
6.35mm and 4.4mm outputs, 3-level gain, and UAC 1.0 support make it compatible with IEMs, headphones, PCs, CD transports, PS5, and Nintendo Switch. - Dynamic Display & RGB Control
1.2" HD LCD, aluminum knob, touch controls, and 9 customizable RGB lighting modes provide intuitive control and visual feedback.
Product Specification
DACESS ES9039Q2M
USB ProcessorXMOS XU316
AmplifierTI TPA6120 x2
Amplifier CircuitFully Balanced Class AB
Balanced Output Power (32Ω/THD+N<1%)2300mW x2
Single-Ended Output Power(32Ω/THD+N<1%)589mW×2
InputsCoaxial, Optical, USB
Outputs3.5mm, 4.4mm, 6.35mm, RCA
Remote Control——
Headphone Impedance8-300Ω
MAX Sampling RatePCM 32bit/768kHz, DSD512
SNR≥ 124dB
Dynamic Range≥ 124dB
THD+N≤ 0.0002%
Noise Floor≤1.7μV
Power InputDC 12V-15V
