Small in Size. Big on Music.
All the fun of playing real CDs, without the bulky setup. Just 102mm across, with Bluetooth listening through your favorite headphones or speakers.
Fosi Audio EUFosi Audio EU
See Your Music Spin.
The spinning CD takes center stage again. Every press of Play
becomes something you can see and feel.
Music That Fits Your Space.
Magnetic placement lets the player fit naturally on your desk, in the kitchen, or in
your music corner. Keep your music close without giving up extra space.
Less Skipping. More Listening.
A little movement shouldn't interrupt your favorite track. ESP electronic anti-shock
helps reduce skipping for a smoother listening experience.
Everything at a Glance.
See the ports,controls,and box contents in one place.
Product Specification
Audio DAC Chip Cirrus Logic CS43198
Output Interface 3.5mm Headphone/Optical Combo, 4.4mm Headphone
Compatible Headphone Impedance 16–300Ω
Max. Headphone Output Power L+R ≥86mW+86mW (32Ω, THD+N <1%)
Signal-to-Noise Ratio ≥100dB
Supported CD Formats CDDA, CD-R/CD-RW (partially readable), SACD with CD layer
Battery Capacity 800mAh
Charging Port USB-C
Input Voltage 5V/1A
Dimensions 102 × 102 × 29mm
Weight 210g
 Does DISC Nano support MagSafe wireless charging?
No. DISC Nano features a MagSafe-compatible magnetic design for mounting only. It does not support wireless charging. Charging is handled through the USB-C port.
 How do I connect DISC Nano to Bluetooth headphones or speakers?
Play a CD, then press the Mode button to enter Bluetooth mode. Set your headphones or speaker to pairing mode and keep it close; DISC Nano will try to connect automatically. If it connects to another device, press and hold Mode to clear the pairing. DISC Nano sends audio to Bluetooth devices but cannot receive audio from a phone.
 Can I connect DISC Nano to an external DAC?
Yes. DISC Nano features a 3.5mm headphone/optical combo output. Using a compatible 3.5mm optical (Mini-TOSLINK) cable, you can send digital CD audio to an external DAC with an optical input. The same jack also supports regular 3.5mm wired headphones.
 What types of CDs does DISC Nano support?
DISC Nano supports standard audio CDs (CDDA), selected CD-R/CD-RW discs, and the CD layer of hybrid SACDs. CD-R/CD-RW compatibility may vary depending on the disc and recording conditions. Original pressed audio CDs are recommended for the most reliable playback.
 Does DISC Nano support USB music playback or CD ripping?
No. The USB-C port on DISC Nano is for power and charging only. It does not support USB music playback, data transfer, or CD ripping. If you need USB playback or CD ripping, the Fosi Audio Merak CD Player supports both features.
  • 5 stars: 16 (80%)
  • 4 stars: 3 (15%)
  • 2 stars: 1 (5%)
Ethan McFenton
Beautiful. Small. Perfect sound. Optical out. Can’t ask for more!
Adorei a versatilidade, praticidade, design, a conectividade e principalmente a qualidade do som, recomendo 🙌
Hans-Joachim Rüblinger
Steven Gray
Hi Guys.
Let me first thank you for brining the Nano CD player to market. I am old enough to remember the original Sony D-88 although I did not own one at the time, the Nano makes up for this!
Here's my quick review:
The good: Sounds great, especially paired with good headphones. It's small and portable- ideal for travel. The MagSafe is perfect for mounting on a standard phone mount - great idea. Resume function works well - resumes a disc where you left off.
The bad: The default BT volume is way too loud! It hurts my BT speaker whenever I connect! Battery life seems poor compared to a vintage portable running on AAs.
The ugly: Track skip only shows the selected track on the display after playback commences. No shuffle or repeat disc/track option - the disc by default just repeats from the start. This could be added to the menu button (long press to get to playback mode?).
Overall a great little player, but some attention needed to the quality-of-life elements would make it perfect.
Holger Rathjen
Tinyest CD-Player on the planet - consider its size, it’s really great in its values and functions - A unique and very special product ! - Well done Fosi !!!
Søren Møller
Very nice product, works good. Love to go on.
MARCO ROSA
ottimo prodotto
Á
Ángel Hernández Camarzana
Gran producto.
Pero es bastante mejorable en cuanto a la posición del display y las características, y aún se puede hacer más pequeño, y el sistema de lectura (una lente laser en movimiento) ya va siendo hora de mejorarla, y cambiar el sistema de lectura a uno estático.
Dan-Horia Frunza
its perfect at this price
shipping ,a little long,in rest everything its ok,thanx !
John Ambrose
Great product, does everything I need for playing cd's in a compact package .
It is excellent, but I can't write in Chinese! I can't fault it, especially given what it cost and that it has an optical feed. I did have to touch it to my Bluetooth receiver to pair it first time, but not a huge issue
Michael Foley
Pros: Well built, good connectivity, sounds excellent for little money.
Looks cool. Perfect for desktop, sofa, lounging around listening to,
Cons: Not really very portable, due to half exposed disc.
Short battery life ( only 2 hours before it needs charging).
I love it!
Tomáš
Supér zvuk za dané peníze, jen na baterií zahraje tak maximální 2 CD.
Marcus
Ein verrücktes Ding
Profi Ausgänge.
Top Sound.
Und ja, es hält am Kühlschrank
a
andrea enrico corbetta
Aesthetically, the player is attractive, but that’s not enough! The audio quality through headphones would be acceptable in itself were it not for the constant background noise caused by the motor and the laser mechanism. It becomes even more annoying during the silent gaps between tracks. Personally, I don't think I'll be buying your products again if this is the level of quality. Thanks.
Solo falta mando a distancia para 5 estrellas
Steffen Jütting
Top fun!!
Π
Παναγιώτης Χρονόπουλος
Perfect
It could be better with better display details, better shape and better sensation of luxury. Too much plastic parts, poor design. I have not the sensation of something precious, but in any case the idea to have a small player is top
e
egidia
ottimo
