Overview Specs In the Box
★★★★★ 4.1 (87 reviews)
Galaxy / 16GB
€89.00
In a world built to keep you scrolling,
choose an experience made to keep you listening.
Less distraction. More music.
  Music doesn’t need a feed.
  It needs a moment.
Fosi Audio EUFosi Audio EU
  Turn with Feel.
A tactile wheel makes every turn feel precise and satisfying.
  Control, Right at Hand.
Side buttons keep essential controls within reach.
 Less to Learn. More to Listen.
A minimalist UI keeps things simple.
 Refined to the Touch.
Micron-etched AG glass keeps the surface smooth and clean.
 Hear Every Detail. Feel More.
Powered by the CS43198 DAC, high-resolution
lossless audio brings your music to life with clarity, depth, and detail.
  Your Music Library, In Your Pocket.
16GB or 64GB Memory Card Included.
Expand storage up to 256GB and keep more of your favorite music with you.
Fosi Audio EU
Transform Your Listening Experience
Fosi Audio EU
Supports MP3, FLAC, WAV, APE, M4A, DSD, and more. Play your music in the format you love.
Bluetooth with SBC and a 3.5mm jack let you choose how to listen.
Product Specification
Audio DAC Chip1× CS43198
Output Power129 mW
Output Interface3.5mm Single-Ended
SNR127 dB
Display2-inch TFT LCD, 320×240 Resolution
MaterialFull-metal Housing, 5-Axis CNC Precision Machining
Weight≤75g
Dimensions97 × 47 × 10.6 mm
Bluetooth CodecSBC
MEMORY CARD16GB / 64GB Options
Audio Formats SupportedMP3, FLAC, WAV, APE, M4A, DSD
 Does DAP Neo support streaming apps such as Spotify and Apple Music?
DAP Neo is designed for local music playback. It does not support Wi-Fi, online music services, or the installation of streaming apps. Download the files to your memory card to enjoy the music.
 Can I connect Bluetooth headphones or speakers?
Yes. DAP Neo supports SBC encoding and can send audio to Bluetooth headphones or speakers, but it cannot receive Bluetooth audio from a phone or other device.
 Can DAP Neo play DRM-protected files?
DRM-protected songs require copyright verification for playback. Playback will fail without successful verification, and this is a standard limitation for all DAPs.
 How long does the battery last?
According to tests, the DAP Neo has a maximum battery life of 12 hours. Actual battery life varies depending on settings and playback conditions.
 Does DAP Neo support gapless playback?
Gapless playback is not available on DAP Neo.
 How do I skip tracks?
DAP Neo is operated using physical buttons and a click wheel; It does not support touch input. When the screen is locked, use the center button to control playback:
  • Press once: Play/pause.
  • Press twice: Next track.
  • Press three times: Previous track.
  What's in the Box?
 MP3 Player × 1
 Screen Protectors × 2
USB Charging & Data Cable ×1
 Instruction Manual × 1
  • 5 stars: 42 (48%)
  • 4 stars: 30 (34%)
  • 3 stars: 2 (2%)
  • 2 stars: 7 (8%)
  • 1 star: 6 (7%)
DAVID
Delivers a lot for its price
Simplicity, retro-aimed, great-quality construction.
Greatest of all:
- Extremely responsive to the wheel; navigation is flawless; the mechanical wheel feels great.
- Great-quality build, made of aluminum, lightweight, and nice to hold.
- Did not expect such nice sound. It delivers.
What it lacks, and what I would love to see — hoping the Fosi Audio team will be able to provide it with a firmware update:
- USB audio out: Would be amazing to pair with a high-end DAC dongle.
- Music genre selection: On the go, I prefer to shuffle music by genre, not always have a playlist for everything.
My use case:
I love the retro vibe; thus, I’m using only lossy files, specifically Apple’s AAC VBR Q 109 profile. For me, it’s near CD quality — no difference I can hear — of course, always using wired headphones.
It might not be for you if you are looking for a fully featured DAP with SPDIF output and high-res wireless codecs.
n
nix
Decepcionante.
1- La distancia entre la bahía micro sd y el cuerpo del dispositivo es tan grande que mi micro sd ha acabado dentro del cuerpo del dispositivo y no en la bahía micro sd en los primeros segundos. Tuve que usar una pistola caliente para abrir el Neo y recuperar mi tarjeta micro sd :(
2- La rueda venía con un desgaste extraño.
3- La pantalla no enciende pero escucho un ruido de ganancia al conectar y desconectar mis auriculares. Es una lástima que solo pudiera usar el dispositivo 10 minutos después del terror que me causó la micro sd.
Estaba muy emocionado por este producto. Una lástima que la primera impresión haya sido terrorífica. Me gustaría devolverlo pero he tenido que dañar un poco el cuerpo del dispositivo para recuperar mi micro sd.
n
nixburemi
En los primeros 5 minutos tuve problemas con el dispositivo. Removí la tarjeta SD que viene incluida para insertar la mía pero, al intentar insertar la mía, me di cuenta demasiado tarde que la tolerancia de la construcción entre el cuerpo del dispositivo y la bahía con la ranura micro sd era enorme! Mi micro SD estaba ahora DENTRO DEL CUERPO del dispositivo y entre la bahía micro SD y la placa de vidrio del Neo. Tuve que utilizar una pistola de aire caliente para despegar el vidrio del dispositivo y conseguir sacar mi micro sd, dañando el cuerpo del Neo en el proceso :(
Después de ese drama que ya me ha hecho dudar seriamente de la calidad de este producto, me encuentro con que no enciende después de usarlo 1 sola vez y teniendo la carga entera de batería. He tenido que encenderlo con un cargador para móvil tras dejarlo conectado dos horas.
Compré sin chistar este producto porque es exactamente lo que llevaba esperando desde hace mucho tiempo pero, este par de malas experiencias me hacen pensar que el experto equilibrio de Fosi en cuanto a calidad y precio ha fallado aquí.
Wade
Great Hardware with just a few software tweaks needed
I am really happy with the player. I think the simplicity is really what sets it apart. Fast to turn on and auto off.
Hardware - Zero comments. Its perfect. So happy.
Software - 2 small changes would make it incredible. 1 The lock screen should display the title of the song playing. I often want to check and need to unlock the device to do so. 2 - It would be great if there was a visual way to browse the albums on the player. Like the original iPod. But instead of horizontally, maybe vertical.Like this mockup I made: https://imgur.com/a/e1V5HBo
I think for a lot of people, the player allows us to physically experience our music.
Thanks
Wade
Chris
Great stand-alone DAP
Exactly want I wanted - a stand alone DAP to use on flights to listen to my lossless files. Nice build quality, UI is great with teh click wheel - Audio through my Bose QuietComfort Ultra 2 headphoes (wired) is excellent
Peter
Great price, great sound.
Really pleased with my new dap, I was sick of adverts from a streaming service interrupting my listening. It’s so simple to load up a memory card from your own source and insert it in the dap.
I’ve owned Fosi ear buds for around a year now which I used with my phone.
The dap is so lightweight it’s brilliant for running.
For the price alone I would highly recommend.
Sanjay
First Impressions and Suggestions for the Fosi DAP Neo
Dear Fosi Audio Team,
I’m happy to let you know that I’ve received my Fosi DAP Neo Modern Classic, and I’m really enjoying it so far. The build, design, and overall first impression are excellent. Thank you for creating such a nice music player!
After using it for the first time, I wanted to share a few suggestions:
1. **Headphone connection indicator:** When headphones are plugged in, it would be helpful to have a small headphone icon or indicator on the screen so users can easily tell that the headphones are connected.
2. **Protective case:** Please consider launching a dedicated hard plastic protective case for this player. It would be great to have a durable case that protects it while maintaining its compact design.
3. **Charging specifications:** Could you please confirm the recommended charger specifications for this device? Specifically, what voltage and maximum current (V/A) should I use to charge it safely?
These are just a few suggestions based on my first impression. I’m looking forward to using the player more and sharing my experience.
Thank you again for the great product and support!
Best regards,
A happy Fosi customer
C. Wandrille
Good DAP for the price and build. Aluminium frame and glass back is really nice and generally feels good in hand. The software is not customizable, battery life is a bit less than average. No gapless playback (bit disappointing at that price). Overall it’s a perfect cheap ipod alternative, but falls behind on audio quality and software.
Sebastian Lopez
Producto increíble, simplemente recomendado 10/10
Wolfgang
love it
even made a Youtube Video about it.
look for my Channel - Wolfgang Kern
m
marko
GOOD LITTLE MP3 PLAYER
Got my Dap Neo today and I'm very pleased with it. My SD card loaded without issues, I upgraded the firmware and the device works flawlessly. I read in some reviews that the sound quality is trash but it sounds pretty good to me, my entire library is in M4A and I'm listening through bluetooth on JLab epic lab edition earbuds. I can see that the battery drains fairly quickly and my music library takes a few minutes to update (over 4200 songs) these are the only quirks that I've noticed so far, hopefully with future updates this will improve. For what I'll use it, which is, walking the dog and exercising, it's more than enough and punches above its price point.
Mark
Brilliantly made little player.
Big fan of Fosi, their ZH3 is the single best bit of audio kit I’ve bought over the last 20 years, so the Neo was an instant buy.
The build and feel are great, and it’s super fun to use.
I’m a massive bass head, and for me it is sadly lacking in raw bottom end for sub bass. But other than that it’s a great little player.
I’d love to see a V2 of this with 4.4 output and more power for a better sound.
If you’re considering getting one, I’d go for it. And checkout the custom firmware by Polorsk as it adds custom eq, dac modes and even coverflow which makes the Neo even better!
Datfard69
sweet
i enjoy the dap neo very much just disappointed that some of my "hi-res" files aren't "compatible" but other than that it's awesome
Beautiful product, the quality is there, good experience with fast delivery.
Alex
Amazing product and customer support
I'm extremely happy with my Fosi Audio DAP Neo! I own several MP3 players with Bluetooth capability, including the older SanDisk Sansa Clip Sport Plus, Innioasis Y1, and Shanling M0, but the Fosi Neo has quickly become my favorite.
Pairing it with my JBL Bluetooth headphones and speakers works like a charm. Once paired, the connection remains stable, and the audio quality is excellent. The battery easily lasts through at least two hours of walking while using Bluetooth headphones, which is more than enough for my everyday use.
I also really like the easy-to-use navigation and physical controls. The size is just right — not too big and not too small. It's comfortable to carry and makes a great companion for walking, working out at the gym, or spending time outdoors.
What makes the overall experience even better is Fosi Audio's amazing customer support. The team is very responsive, communication is excellent, and they are genuinely willing to help — even with delivery-related issues. They stayed attentive throughout the delivery process and made sure everything was resolved. That level of customer care really deserves recognition.
Both the product and the customer service exceeded my expectations. I highly recommend the Fosi Audio DAP Neo. It's a great product backed by a company that truly cares about its customers!
Harry
Love the Retro Look
I was looking for something different from the usual smartphone listening experience. The retro styling and dedicated-player concept make this an interesting addition to my everyday routine.
Ricardo
Buen producto, bonito y funcional!
Es un muy buen producto, el acabado y materiales son de muy buena calidad, se siente muy bien al tacto, ligero y cómodo. La interfase es sencilla, la pantalla hace su función y la rueda si se siente un poco frágil pero responde bien. El sonido es muy bueno para ser un DAP de entrada y con iem´s con cable se escucha muy bien, no así con audifonos inalámbricos ya que solo cuenta con el codec SBC bluetooth y pues si tus archivos son mp3 no hay problema pero si tus archivos son tipo flac no se van a escuchar tan bien. En general es un muy buen aparato, espero que con las actualizaciones de firmware mejoren algunas cosas como el tipo de fuente que tiene por default.
Le doy solo 4 estrellas ya que el producto que me llegó venía con la tarjeta sd incluida dañada y fosi me hizó una devolución parcial de $10usd.
Eric
Excellent inexpensive unit. My only knock is it doesn’t play AIFF which the majority of my CD rips. If you use FlAC or MP3 you’ll enjoy this
Richard
Shuffle?
Still haven’t figured out how to shuffle songs. Any ideas?
Neo Retro, one inconvenience, one flaw
The scroll wheel was the main attraction here. I'm excited to see what happens with future firmware upgrades. The player has pretty good audio comparable or better to similar units on the market. The inconvenience is the lack of a 4.4mm output but this is truly not necessary.
It's biggest, most meaningfull, shortcoming is lack of LDAC support, which an aspirational hifi oriented brand should have included here if it was going to have Bluetooth.
