80W Toroidal Transformer
Nippon Chemi-Con Capacitors
High-Reliability Rectifier
4-Core Regulation
  • Exceptional Sound Quality exclusively designed for the audiophiles who pursue HiFi sound. 5-inch powerful unpressed woofers provide a rigid structure to improve bass response, treble from high-performance silk dome tweeter are well defined.
  • Equipped with 0.75-inch silk/polymer composite dynamic balance dome tweeter and 5.25-inch diameter bi-laminate organic fiber cone woofers. 20-160 Watt per channel power handling, nominal impedance 6 ohms, frequency response 20-20KHz.
  • Unique woofer horn design reduces artificial reverb and filtering, gives you the best clarity, dynamics, and detail sound. A great choice for your home stereo surround system.
  • Solid built classic MDF enclosure with a nice appearance. Hand-built thick wooden cabinets minimize resonance and reduce distortion, making the sound incredibly immersive and fills your room with incredible acoustics.
  • What You Get: 2 speakers, 24-Month global warranty, and 24-Hour quick after-sale customer service. Note: The DK560-N is a passive speaker. An external amplifier or receiver is required. Recommend amplifiers model: Fosi Audio BT20A, TB10A, HD-A1, TDA7498E etc.
Power Input
AC: 115V / 230V
Note:
Power Output
Operating Temperature
-20 ~ 40°C (-4°F ~ 104°F)
Temperature Rise Test
  • Fosi Audio PSU20*1
  • User Manual*1
  • AC Power Cord*1
