The Fosi Audio BOX X3 is a state-of-the-art phono preamp that uses Bluetooth 5.0 5725W tube technology for superior audio quality. This 2-in-1 preamp serves as both an MM turntable preamplifier and a Bluetooth 5.0 preamp, making it an essential component for the modern audiophile
The tube phono preamp improves the audio quality of your MM turntable by converting the phono signal to a more manageable line level, resulting in better sound and increased volume levels for your home audio system
Upgrade your home audio setup with the BOX X3 Bluetooth 5.0 tube preamplifier. With a 3.5mm line input, easily connect your latest devices for wireless Hi-Fi music streaming to powered speakers. Please note that an amplifier is required for passive speakers
- Experience exceptional sound quality with the BOX X3 phono preamp's ultra-low noise performance. Featuring 5725W vacuum tubes, this preamp produces a clean and warmer sound, allowing for perfect replication of your vinyl records' music. The built-in phono preamp circuitry is designed with high accuracy and conforms precisely to the RIAA standard, so you can enjoy a flawless listening experience every time
- What You Get: BOX X3 mm phono preamp x1, 5725W Vacuum tubes x2, Bluetooth Antenna x1, power adaptor x1, user manual x1. Please note that the BOX X3 preamplifier is a Bluetooth receiver only
| Model | BOX X3 |
| Input Interface | RCA + 3.5MM AUX + Bluetooth |
| Output Interface | RCA output |
| Output | Active(powered) speakers, Amplifier |
| THD | ≤ 0.1% |
| SNR | ≥ 98dB |
| Product Weight | 0.71 lb/320g |
| Device Dimension | 4.66 inch/3.85 inch/1.29 inch |
| DC Input Range | 12V |
| Input Voltage Range | AC 100V - 240V |
| Output Voltage Level | 650 mV @3mV 1kHz |
| Power Supply | 12V 1.5A |
| Box X3 Phono Preamp | x 1 |
| 5725 Vacuum Tubes | x 2 |
| User’s Manual | x 1 |
