Premium Chipset Infineon IR4322
With eight years of expertise in amplifier design, Fosi Audio has built a global reputation for compact, powerful, and great-sounding amplifiers. The CA30 is Fosi's first car amplifier. It brings our home audio technology and tuning experience to the car audio world- making your in-car listening more enjoyable.
  • SINAD≥80dB
  • THD+N≤0.008%
  • SNR≥100dB
  • Noise Floor≤200μV
Installation Notes
1. The high-level input supports automatic power on/off. When using a high-level input with DC, the REM connection is not required.
2. For dual protection, please install a 60A external fuse on the power cable within 50 cm of the vehicle battery.
3. To minimize interference, route power cables and signal cables on opposite sides of the vehicle (e.g., signal cables on the left, power cables on the right).
4. Please use properly rated cables. Power and ground cables must be AWG #4, and the REM wire should be AWG #16 to #18.
5. Do not connect high-level input and RCA low-level input simultaneously.
6. Multiple speakers can be connected in parallel to a single channel. In stereo mode, total impedance per channel must not be lower than 2 Ω; in bridged mode, not lower than 4 Ω.
7. Observe correct polarity for all power and audio connections to prevent short circuits or damage to the amplifier and vehicle.
8. The CA30 features cooling fins on the top panel. For optimal cooling, please install the amplifier with the fins facing upward, maintain 5–10 cm of clearance, and do not cover the fins during operation.
  • 4 Channel Car Audio Amplifiers: Class D 4-channel design supports stereo connection and bridging for flexible system configs. Infineon IR4322 chip delivers clean, full-range sound to drive your vehicle's speakers with low distortion and minimal heat
  • HiFi Sound Quality: Brings Fosi Audio's home audio technology to the car audio world. Features JRC/ST op-amps with THD+N ≤0.008%, SNR ≥100dB, and ultra-low noise floor ≤200μV—specifications that outperform standard car amplifiers in its class
  • 88% High Efficiency & Bridgeable: Class D design minimizes heat while delivering 100W x 4, and bridgeable mode provides 320W x 2 @ 4Ω for subwoofers. REM wire enables linking on/off with your head unit, while adjustable HPF/LPF crossover (50–250 Hz)
  • Compact Universal Fit: Measures 7.3" x 3.9" x 1.7" to fit under seats or tight spaces. Compatible with 10–16V DC gasoline vehicles, including sedans, SUVs, trucks, MPVs, Jeeps, and vans, for easy installation
  • Smart Cooling & Protection: CNC aluminum finned heatsink keeps temps low for stable, long-session sound. Built-in protection against overheating, short circuits, over-/under-voltage, and reverse polarity; handy LED indicators keep you informed
  • Fosi Audio CA30*1
  • Screws
  • 30A Fuse*2
  • 8-pin Ribbon Cable
  • Wrenches
  • 5 stars: 39 (93%)
  • 4 stars: 2 (5%)
  • 1 star: 1 (2%)
Kenneth
The way I'm so in love with this product
The way I'm so in love with this product I went and bought a second one and currently installing it, what are you waiting for go get yours now.
Love the CA30 amplifier one of the best in the
Love the CA30 amplifier one of the best in the market 😍😍😍😍
Jerry
Excellent
This amplifier for its size, it is amazing. I am currently running 4 x JBL Stadium CS62CF (110W RMS @ 3OHMS) and the amplifier is totally not stressing. The sound quality is very good and setup was a breeze. The clipping LED makes it more easier to setup using a standard 1000Hz signal.
Jerry
Excellent
X
X
I would love to try this product
This product looks and seems very worthy of being of one of the best amps for enthusiasts who want performance and clarity in their car wherever they go.
X
X
Good
Good amp
Joma tha
Good
Good amp
Excellent
Great Sound, excellent performance
Fosi CA30
Very satisfied
Sounds better than some premium entry level equipment
Very good small solution for nice audio !
John
Paid for 3, only recieved 2!
Scam of a company. Their shipping department is full of idiots. Their support requires YOU to prove they didn’t ship the entire order, somehow. I will never shop Fosi again!
Was this a good review for you? Can you stop emailing me now?? You owe me $129 for that amp. Dirt bags.
Dennis
Very good sound quality!
I purchased 2 of them for my Lexus. before i installed them I ended up putting both of them in my sons car on some cheaper DS-18 coaxial's. They sounded great. So I purchased 3 more for my car and installed them on some CDT component sets and they have a very old school class AB sound and clarity. They were small enough to put all 3 under the passenger seat. I wish they would build a 4 channel 800 watt version.
Dennis Forbes
Cvt
Turning on cause another amp to go into protect mode.
Setup: Goldhorn 810 pro rca to Fosi CA30 and Sony XM-1ES.
The sound is clean and nice. Unfortunately I found a rare compatibility issue that made me resold this nicely sound amp to a friend. My Sony XM-1ES is an overprotective subwoofer amp that will go into protect mode if it detect any abnormal in the power system. And making my Fosi CA30 and the Sony turn on via remote signal at the same time from my Goldhorn trigger exactly that protect mode.
Scenario:
1) Connect both Fosi and Sony remote and rca cable to Goldhorn then turn on. -> Sony go into protect mode.
2) Connect both Fosi and Sony remote cable to Goldhorn but leave out either RCA cable on Sony or Fosi -> turn on normally.
3) Connect both Fosi and Sony RCA normally but use time delay relay on Sony's remote signal so that Fosi turn on first, 2 seconds Sony turn on later -> both turn on fine. No protect mode on Sony.
So my only conclusion (especially from scenario 2) is that when turn on. Fosi send something (noise ground short or whatever) back through the RCA to the DSP. That ground are normally shared among all RCA ports so that made its way to Sony subwoofer amp and trigger protect mode. If Fosi turn on first, then Sony later. Then both works fine since Sony isn't doing its check right when Fosi send something to RCA ground. It's unfortunate. And I hope Fosi improve the turn on sequence to be cleaner later.
Cvt
Scenario:
Harry
Very Impressive
This replaced a very expensive Zapco 204dSQ amplifier that was rated at 150x4 rms. The sound quality is excellent and I have zero noise or turn on/off pops. I will say the potentiometers on the gains are very sensitive and dialing in the gain required what seems like millimeter adjustments and many people having issue with sound likely have the gain set wrong. Dynamic and Powerful and tiny with zero added noise. Who can ask for more? I can, turn this amp into a 600 watt Mono block next.
Harry
Very Impressive
Luca
Great
Good sound
Good price
At a ridiculously small size
Highly recommend
Luca Gentle
Great
Good sound
Good price
Highly recommend
David
Great compact amplifier!
I was sceptical because of the low price but i learned a lesson after watching the detailed power Tests of the Fosi ca 30 on YouTube made by Audiokeller. He did a second video with a superb sound demo tested under same circumstances like older legendary class AB amplifiers and I was shocked 😳 I had to buy it and did not regret it - a bargain ! Well done Fosi , hope you will continue car audio amplifiers and produce a subwoofer amp 😊 fingers crossed!🤞
David M
I was sceptical because of the low price but i learned a lesson after watching the detailed power Tests of the Fosi ca 30 on YouTube made by Audiokeller. He did a second video with a superb sound demo tested under same circumstances like older legendary class AB amplifiers and I was shocked ?? I had to buy it and did not regret it - a bargain ! Well done Fosi , hope you will continue car audio amplifiers and produce a subwoofer amp ?? fingers crossed!??
p
paul
Great sounding amp
I was a little sceptical at first as it was Fosi’s first car amp. To be honest its a great compact amp, that sounds far better than it should at this price point,
p
paul jones
Great sounding amp
I was a little sceptical at first as it was Fosi��s first car amp. To be honest its a great compact amp, that sounds far better than it should at this price point,
p
pliurzis
4 awg
Power and ground cables must be AWG #4 . 🤔🤔🤔
This size can handle 150A . Why so big ?
p
pliurzis
4 awg
Power and ground cables must be AWG #4 . ??????
Rosalie
Six days to greece. Very nice. I’ ll test in a few days and i’ ll buy another one.
Rosalie Spinka
Six days to greece. Very nice. I�� ll test in a few days and i�� ll buy another one.
