  • Small USB DAC headphone amplifier with optimized HiFi audio architecture ensures High-Resolution sound quality. The portable USB DAC DS1 is compatible with various systems like Android/iOS/Windows/Mac, compatible with the latest devices: phones/computers/tablets/laptops/audio players, etc. Wonderfully versatile when commuting in the home, office, or gaming.
  • DS1 adopts ESS Technology ES9038Q2M DAC Chips supporting DSD 512 and 32Bit/768kHz PCM, features best-in-class specifications, and high-power outputs capable of supporting the most demanding of headphones with impedance above 200Ω.
  • Low Noise Floor Clean Sound for True High-Fidelity. DS1 features abundant power with a high signal-to-noise ratio, low distortion, and almost 0 noise.
  • 3.5MM+4.4MM Dual Headphone Outputs are both Powerful enough to easily drive most headphones. The traditional 3.5mm single-ended headphone output is widely compatible with most headphones, and a 4.4mm balanced headphone output for a more detailed audio experience. Specifications: THD+N<0.0006%, output power up to 220mw, SNR>120dB, Noise<1.6UV.
  • What You Get: DS1 USB DAC Headphone Amp x1, Type-C to Type-C cable x1, USB-A to USB-C Converter x1, user manual x1, our worry-free 24-month warranty, and friendly customer service. NOTE: The new version of the DS1 headphone amp optimized the volume control which is independently controlled from the audio source device.
DS1
Model DS1
Terminating Impedance 16-300Ω
Input Mode USB Type C
SNR ≥120 dB
Sampling Rate 32bit/768kHz
DSD DSD64/128/256/512
DAC Chipset ES9038Q2M
Material Tin Alloy
Device Weight 38g
Fosi Audio DS1 x 1
Type-C to Type-C cable x 1
USB-A to USB-C Converter x 1
User Manual x 1
  • 5 stars: 56 (90%)
  • 4 stars: 6 (10%)
Mark F.
Great for price
This dac is a little older but its solid, not just in its construction but its performance. First of all its made of a sold block of some sort of metal so it gives it a little heft for such a small size. 4.4 and 2.5mm plugs offer balanced and unbalanced outputs. Both give decent loudness through my 150ohm headphones. I think nowadays it could use a little more power but to retain your hearing its better this way lol. I tried it with the pc and with a lightning usb 3 dongle adapter for my iphone. Both sound good and i hear the clarity and separation that normally you'd need your old vinyl to hear. Easy to operate, 60 volume steps, Holding volume button switches to uac1 mode. Holding both vol up and down switches between high and low gain modes in both uac2 or uac1 modes. Flashing led means its in uac1 mode. Solid led colors in uac2 mode. Anyways if you want better sound, but dont listen more then a few hours at a time then these are great. They do use phone power or tablet power so you will need to keep track if you do listen for hours. If on a pc it charges so no worries. Anyways great little device.
Mark F.
Great for price
Shoyab Khan
We had never heard a sound like that before.
It's a lot of fun, and the quality is also good. Thank you so much!
Shoyab Khan
NJK
Great little amp
small, powerful, great for smaller audio stuff
NJK
Great little amp
Reynaldo Ruiz Flores
Windows 11 24H2
Roman Fedorenko
Best headphone dac
Hello,that is one best headphone dac,I've been using it with my Ikko obsydian H10 oem headphones and a Neutron player mostly listening to flac files,and sound is amazing,dac has separate volume control with lots of output power,tested it just for fun with Macbook pro and IPhone 16 pro Max,everything works flawlessly,if you want to get best music listening experience,this dac is for you.
Roman Fedorenko
Best headphone dac
Michael Nixon
Fosi DS1 DAC Headphone Amp
Amazing how the DS1 made the sound so clear and easy to hear all the instruments being used in the music. It continues to improve with time. Thank you Fosi Team
Michael Nixon
c
craig stodola
Paired with the DCA Noire X
I bought this little DAC/AMP for roadtripping with my DCA Noire X headphones and iPad Mini running Apple Music. I also use the same set up bedside for late night music listening so I don't disturb my better 7/8ths.
I'm using the 4.4mm balanced input.
I'm using this little DS1 Dongle to drive my Noire X with my iPhone 16 as I type this review. I love listening to latin and world music - have the "Oy" from the Gypsy Kings playing - which can sound really congested and muddy on a crappy audio rig. I'm getting beautiful detail, clarity, dynamics, separation. Even presents the nuanced details in music that can be impossible to hear on more expensive home speaker rigs. Plenty of bass oomph when the music calls for it. I can crank the volume to fairly painful levels without distortion. Not recommended, but you do you.
The one bugger could be....this little amp will suck the power out of your smartphone pretty quickly. That should be obvious. You might get a good 90-120 minutes of playback give or take, depending on your volume setting. I don't listen to my music terribly loudly - prefer to keep my hearing performing well long term (me doing me). ...If you need longer playback, I think it's better paired with an iPad/tablet or a laptop. The iPad Mini is sweet spot. :)
For a good two hour listening session in your favorite chair in your home, coffee shop, wherever you need keep pretty quiet and not disturb other while still want outstanding high fidelity, this is hard to beat.
I love this little dongle - I would highly recommend if they have the power to drive your headphones (double check the specifications).
Craig Stodola
Mahmoud
Best thing ever
Mahmoud Elshehawy
Best thing ever
Robert
Works great 👍
Robert Mettetal
Works great ??
Customer
Great product
Works like a charm
Rene Chacon
Great product
Works like a charm
Sean McNamara
Great unit
Feels well built, is small, sleek, and makes my 250ohm DT770's sound great. No noticeable noise. I am happy with my purchase.
Shawn
Great unit
n
neil lambert
The build quality seems strong. I bought it as I liked that it has an independent volume control (which is more subtle than the volume on my iPhone) and this works well.
n
neil
Gary
Makes a noticeable difference
I initially just wanted the Fosi Audio IM4 Open-back in-ear monitor, as I saw the YouTube reviews were good for its price. Then curiosity got the better of me and I got the DS1 Headphone Amp and boy was I glad I got them. The difference without and with it plugged in is remarkable. It was definitely worth the add-on. They sound is so superior and clear compared to my other earphones. Highly recommended and super quick delivery too after pledge.
