Fosi Audio M04 Subwoofer Power Amplifier
Small but mighty! Fosi Audio M04 is a 100w mono-channel class D subwoofer amplifier, with a SUB/PBTL switch you can select a subwoofer bass amplifier or full frequency mono amp, can be connected to an active/passive subwoofer and passive speaker.
The power switch was integrated into volume control, we made it small but supply an in-wall or stand-alone subwoofer the power it needed so you can experience room-shaking low-frequency impact (bass) on movies and music soundtracks.
Input Interface: RCA input
Output Interface: speaker’s output
THD: ≤ 0.02% (1KHz, 1W)
Output: passive subwoofer/speaker
Input Voltage Range: DC 12V - 24V
SNR: ≥ 102dB
Terminating Impedance: 2Ω - 8Ω
Max Power Output: 100watt @3Ω
Input Sensitivity: 600MV
Net weight: 175g
Dimensions (H * W * D): 103 x 57 x 43MM (4.06 x 2.24 x 1.69’’) includes knobs
Frequency Response Range: 20Hz-20KHz(±3db)
Bass Frequency Range: 20Hz-200Hz
Package Includes
Fosi Audio M04 Subwoofer/Mono Amplifier x1
Power Adaptor x1
AC cord x1
User Manual x1
Compare with similar items
Power Input
AC: 115V / 230V
Note:
Power Output
Operating Temperature
-20 ~ 40°C (-4°F ~ 104°F)
Temperature Rise Test
- Fosi Audio PSU20*1
- User Manual*1
- AC Power Cord*1
