Seamless, Skin-Friendly Earcups.
Dense foam and premium PU leather enhance bass performance, while breathable fabric ensures long-lasting comfort.
  • 5 stars: 31 (84%)
  • 4 stars: 4 (11%)
  • 3 stars: 1 (3%)
  • 2 stars: 1 (3%)
Aggelos Kasiaris
Really good material and best for winter (due to sweating easy). Excellent material and the bass got upgraded for my ears. Really good price.
David M.
Super high quality and very well packaged.
These earpads are great, and it is good to have an extra set.
David McManus
Paul H.
Low End Improvement
These improve the bass response. If you’re not completely satisfied with the bass in the stock pads this may do the trick.
Paul H
Low End Improvement
These improve the bass response. If you��re not completely satisfied with the bass in the stock pads this may do the trick.
Laurent Schauls
Good replacement ear pads
With these earpads the music has a bit more bass, the only negative point is because they are not ventilated you tend to sweat a bit more. So there is a compromise
LS
Carlos Carlos García
i5 Replacement Earpads(no ventilation holes) for i5 Planar Magnetic Headphones
Carlos Carlos Garc��a
l
lorenzo vivarelli
The perfect solution
Even if they are not ventilated, comfort is guaranteed without problems, they do not affect the listening result at all. Lorenzo Vivarelli - Suono - Italy
l
lorenzo vivarelli
ANKIT BAKSHI
Unfortunately too bright
The upper mids are too forward for my taste. 8-12Khz needs to EQed down to make it bearable. I think this will work well with tubes. The bass focused pads do increase noticeable bass but does not lower treble. Headphones are somewhat comfortable. The stock cable is very very stiff and too thick and heavy for 2025.
There are definite areas of improvement. Lower mids felt distant and fuzzy.
Marco Cailli
Fosi i5 pads
The non-perforated pads for the Fosi i5 headphones fit perfectly." From a sonic point of view I did not notice any particular differences. It is true that I made comparisons with the other tunnels before the end of the break-in, but the sound did not seem to change alternating between the two pads.
The only thing I can highlight is the high temperature of the ears when using headphones in the heat of this summer. But the same thing happens with perforated pads.
Marco Cailli
Fosi i5 pads
Bhupinder Singh Dhaliwal
Replacement Pads
Great to see that replacement earpads are included in the package as well as two good quality cables, one 4.4 and one 3.5mm. The replacement earpads without any perforations seem to add a little more bass.
Customer
Very pleased with the headphones
Happy to have them but haven’t tried out yet. I’m very happy with the headphones overall though
Regards
Emmett
Bhupinder Dhaliwal
Replacement Pads
Emmett Dolan
Happy to have them but haven��t tried out yet. I��m very happy with the headphones overall though
Regards
Emmett
Russell Taylor
Sudden Realisation
What seemed like pointless feedback changed when I saw the words "no perforations". This got me thinking. What could this possibly achieve. Apart from sweaty ears that is? It had to be an improvement to the sound but what. The ring update to prevent bass leakage had me think that bass might permeate the ear cushions through the hundreds of perforations, which make the cushions slightly more transparent to lower frequencies. Only one way to find out, swap the ear cushions/pads. Bingo! A subtle increase in bass power and unless I'm imagining it, a slightly deeper bass extension. Not a huge difference but definitely notable. There may be a tiny trade off around 850hz where certain tones on some tracks sound a little bit more shouty or harsh. Those frequencies being more likely to be reflected toward the ear, instead of being partly absorbed by the perforations. This could increase treble harmonics very slightly improving transients. Overall an excellent upgrade. Well thought through. Can the i5 be improved? You just did improve them...
Phil Brown
A Treat for the Ears
I purchased the Fosi Audio i5 Headphones complete with the replacemnet earpads via the Kick Staert campaign and have thoroughly enjoyed using them. With the new ear pads not only do I have the pleasure of listening to the sparkling highs and revcealing midtowns, but can also really appreciate the deep but natural bass. Thoroughly recommended.
Russell Taylor
Sudden Realisation
Phil Brown
Matthias Henning
Great earpads
Great bass without causing inner ear pressure
Vokoun Martin
Super headphones
The headphones are amazing. After unpacking them, I was surprised by the size, but after putting them on and especially after connecting them to my A&K SP2000P, the concert began. The headphones can also be used with a portable player without any problems.
Matthias Henning
Great earpads
Andrejs Krivosejevs
Fosi Audio i5
Super.
Mardare Liviu
Yes ventilation holes
I like them more with ventilation holes, they sound more round. The pads without holes sound more empty but I guess each with their own.
Vokoun Martin
Super headphones
Andrejs Krivosejevs
Fosi Audio i5
Super.
