  • Input: RCA, Bluetooth, USB, Optical, Coaxial
  • Output: Passive Speakers Output, Pre-Out, 3.5mm Headphone
  • OutputSNR≥100dB; THD≤0.03%; Bluetooth Codecs: SBC, AAC
  • All-in-One DAC Amp: A DAC, amplifier, preamplifier, and headphone amplifier are all integrated into the Fosi Audio MC331. You can easily switch between audio sources with the help of the remote control, ensuring a seamless and enriched listening experience.
  • Amazing Combination: As an integrated tube DAC amp with a VU meter, the visual aesthetics of the 5654W vacuum tubes and VU meter add a nice warm and soft effect to not only the appearance but the sound as well, giving the modern look a retro feel.
  • Setup Flexibility: It supports Bluetooth, USB, coaxial, optical, and RCA inputs, making it compatible with a variety of sources such as computers, phones, CD players, turntables with built-in phono preamps, etc., allowing you to build various systems.
  • Compact Yet Powerful: The MC331 only takes up minimal desktop space but boasts a maximum power output of 105W x2@4Ω, effectively driving your bookshelf speakers. Additionally, it has a pre-out and a 3.5mm headphone output, making it versatile enough.
  • User-Friendly Design: The MC331 comes with a remote control, allowing you to adjust bass and treble from the comfort of your listening chair. Its replaceable tube design lets you customize the sound signature to suit your personal preferences.
  • MAX Power Output:
    105W×2@4Ω
  • Input Mode: Bluetooth +RCA +USB +COA+OPT
  • Output Mode: Passive Speakers Output, Pre-Out, 3.5mm Headphone Output
  • THD: ≤0.03%
  • SNR: ≥100dB
  • Device Dimension: 10 x 2 x 2.7 inches
  • Terminating Impedance: 4-8 Ohm
  • Power Supply: 24V/4.5A
  • MC331 Power Amplifier x 1
  • 24V/4.5A Power Adapter x 1
  • Remote Control x 1
  • User’s Manual x 1
  • 5 stars: 1 (100%)
  • 4 stars: 0 (0%)
Dobromir Dimitrov
I'm really impressed with the quality and craftsmanship of the product. Working as a charm. I have 4 different sets of tube to experimenting to find the best sound for me.
