  • The 48V 5A 10A power adapter supply is specifically designed for use with amplifiers and is ideal for providing reliable power to Fosi Audio amplifiers, such as BT20A Pro, TB10D, ZA3, and V3 amplifiers.
  • Provides a stable and reliable output voltage of 48V for powering your device. Capable of delivering up to 5A/10A of current, making it suitable for high-power applications.
  • Manufactured with high-quality materials, ensuring long-term durability and reliability.
  • Incorporates several safety features, including overcurrent protection and overvoltage protection, to ensure safe operation.
  • The compact and lightweight design allows for easy portability and uses in tight spaces. It can be used in a range of settings, including home, office, or industrial environments.
  • 5 stars: 3 (100%)
  • 4 stars: 0 (0%)
Braden Mixson
Quality build
Seems to be great quality build, and pretty much the only power supply that will work for it. Sadly, haven��t been able to use it. I updated my receiver to a newer one that doesn��t have pre-out for front towers, saving it for when I get another set of speakers for garage??
Meelis Mikson
Fosi Audio 48V 5A & 10A Power Supply Unit
Oscar Delute
quick and fast
