Fosi Audio SW10 Active Subwoofer
Black Friday Exclusive Offer
- 10-inch down-firing driver
- Smart DSP, dual EQ, auto power
- LFE/RCA Inputs, expandable, precise control
- Dual bass ports, sturdy noise-free design
Fast, Free Shipping
- Deep and Powerful Bass: The innovative 10-inch down-firing driver design provides a smoother sound dispersion, paired with a 200W Class D amplifier (500W peak power) for stunning low-frequency performance. Whether for movies, music, or gaming, it delivers an immersive and impactful bass experience.
- Stable Design & Rear Dual Bass Ports: Rear dual bass ports provide greater airflow, enhancing low-frequency output for fuller, deeper bass. The 14kg sturdy chassis effectively reduces vibration and noise, helping deliver clearer and purer low frequencies.
- Compact, Modern, and Versatile: With a sleek 14.17 x 14.17 x 15.75-inch design and down-firing driver, the minimalist front panel blends perfectly with modern home decor. Customizable sound for movies and music, perfect for home theater, living room, or studio setups.
- Exclusive Precision DSP Algorithm: Features DRC limiting to prevent overload in dynamic scenes. Built-in dual EQ modes allow sound customization, delicately reproducing the emotions and details of movies and music. Automatic signal detection saves energy by powering the subwoofer on and off intelligently.
- Flexible Connectivity and Control: Supports both LFE and RCA inputs for seamless integration with amplifiers and receivers. RCA output allows expansion with additional active subwoofer or amplifier. Equipped with 0°–180° phase adjustment and a 40Hz–180Hz precise crossover for accurate frequency separation and perfect alignment with main speakers, delivering cleaner, deeper bass.
- Fosi Audio SW10 x 1
- 1.8m Power Cable
- User Manual x 1
