  • Input Mode: MM+MC RCA
  • Output Mode: RCA
  • THD: ≤0.009%
  • SNR: ≥ 92dB
  • Power Supply: 16V/1A
  • BОX X5 Phono Preamp x 1
  • 16V 1A Power Adapter x 1
From €39.00
Active Speakers + Headphone
Bass & Treble Control
≥ 70dB
≤ 0.08%
12V/1.5A
From €69.00
RCA+3.5mm
Active Speakers
≥ 98dB
≤ 0.1%
12V/1.5A
From €59.00
Bluetooth + AUx+ RCA
Active speakers
≥ 70dB
≤ 0.1%
12V/1.5A
From €89.00
RCA+3.5mm AUNo
RCA+3.5mm AUNo
≥70dB
≤ 0.1%
12V/1.5A
  • 5 stars: 100 (91%)
  • 4 stars: 8 (7%)
  • 3 stars: 2 (2%)
Ethan McFenton
Super clean. Well made. The sound rivals digital streams when used with a good stylus and clean record. Best thing I bought for my analog setup.
Guillermo
It works very well!
Meu ��udio
Excelente
O Fosi Box X5 melhorou muito o som do meu toca-discos (eu estava usando o pr�� de phono embutido)!
Infelizmente n?o consegui me livrar do "humming", aquele ru��do de fundo, mas mesmo assim valeu a pena, �� um excelente custo-benef��cio.
O review completo do Box X5 est�� dispon��vel no canal Meu ��udio.
Peregrine
Satisfaction with my Box X5
I purchased the Box X5 phono pre-amp together with the LUNA3 turntable. The Box X5 arrived promptly while I had to wait a couple of weeks for the LUNA3. Once the turntable arrived I unboxed everything. All the components arrived in excellent condition. Installation of the Box X5 and turntable was simple. My only comment is that the ground post is not where I would have expected it, but I��m sure Fosi has their reasons. The RCA cord supplied with the turntable included the grounding wire and there was sufficient length for it to easily bridge the distance to the terminal.
Peter Sus��n
Great quality phono preamp
GibH
Big sound in a small package
This is a great phono stage for its price. If youre looking for just great sound to actively listen to music on your turntable through good speakers, this is it. If you deem yourself an audiophile (you know, the pretentious type), this product still hits way above its weight and produces great sound for you too. Please dont be fooled, this is really all one needs to achieve very, very, good sound from their music (given they have a decent setup). But if you��re searching for exceptional, heavenly, sonic accuracy (which is a farce), a wide soundstage, airiness, and bragging rights, then throw a couple thousand dollars at another phono stage so you can test ad nauseum the quality of your equipment rather than enjoy good music. Fosi X5, Great product.
Daz
Fosi Audio Box X5
Partnered this with a Rega Planar 3 RS and an Arcam A5+, I was floored by what I was hearing! Listening to Tears in Heaven from Eric Clapton Unplugged, I had to listen to it a second time. I was hearing things I��d never heard before and had the sensation they were in the room with me. I can definitely recommend one.
Zlatri
Phono Preamp
Karl Schureecht
What else?
Petter Fredriksen
Works well
Paulie R
Great Phono Preamp
My Audio Technica TT has a built in phono preamp which gets the job done. However, the audio tends to sound low and diminished at times depending on the music style. I bought the X5 to bump the gain just a hair to my speaker amp and man it does not disappoint. It gives me exactly the bump my TT needed. Sound quality is fantastic with a beautiful soundstage. The ground attachment is perfect. I don��t have any hum/static/distortion. I would buy the X5 again and highly recommend it. Cheers!
Chuck
Immaculate!!
Hreinn J��nsson
Antonio Francesco Scanferlato
Elettronica dal suono allineato al prezzo di vendita.
Probabilmente le recensioni troppo entusiatiche che si leggono in rete sono di persone poco esperte o con impianti stereo a bassa risoluzione.
Marco G.
Good phone preamp, perfectly fitting my needs for different gain settings for MM cartidges. Plus it sounds way better than the internal phono preamp of my other amp.
Just connected bur have nor run music through it yet
Olivier Rey
Très bon préampli phono
Stephan Tremblay
John Shenton
Great product.great value
Mike D
Transformer!
The Box X5 completely transformed the sound of my Audio Technica turntable. Everything felt like it was brought to life. Better lows, mids and highs with a broader sound.
Simone Eynard
This phono preamp is really worth every single cent, it does an amazing job! The sound is clear, and really comes to life, I was surprised by the outcome. Would definitely recommend
Wilfried Ringel
I can totally recommend this preamplifier. My Fosi Luna Phono sounds amazing with that preamp.
Jose luis Farace
Prephono box x5
Bojan Konjevic
MM/MC preamp
Awesome prace of tech, minimalistic, the sound is unbealivable ... fast secure shipping. All the best really.
