  • The Bluetooth Stereo Amplifier adopts performance 2pcs texas instrument TPA3116D2 amp chip, dual-channel max output power 50W x2 +100W to get clear audio sound, no pop, no audible noise, dead silent when nothing is playing through it;
  • Speakers full frequency output, By using the custom treble bass knob and adjustable 40-300Hz cutoff frequency for the subwoofer, you'll be able to get the best sound;
  • Supports wireless playback from Bluetooth devices, Bluetooth 5.0 wireless music streaming technology with external antenna make a transmission distance of more than 15m/49ft;
  • Full metallic shell to ensure high quality and durable, advanced circuitry design, built-in speakers protection circuit to ensure Hi-Fi clear and clean sound; With unrivaled sound for the customers who pursue HiFi sound;
  • Upgraded DC power outlet for safe use without sparks, included high quality 24V/4.5A power supply (The plug of the power adapter will match the country of your delivery address) enough to drive most passive speakers and powered/passive subwoofer.
BT30D Bluetooth 5.0 2.1 Channel Power Amplifier with Bass and Treble Control
Detailed description
Model BT30D
Chippest TPA3116D2
Maxpower Output 50W*2+100W
THD 0.05%(@1W)
SNR ≥98dB
Working Voltage 12-24V
Speakers Frequency Response 20Hz-20kHz(±3dB)m
Bass Cutoff Frequency Range Adjustment 20-200Hz
Impedance 2-8 Ohms
Device Dimension L118 x W132 x H35 mm/4.72 x 5.2 x 1.38inch
Input mode Bluetooth/RCA
Output mode Passive Speakers + Passive/Active Subwoofer
Bluetooth Bluetooth 5.0, up to 15m/49ft wireless range without hindrance
Wireless Range Up to 15m/49ft
Fosi Audio BT30D Amplifier 1
24V 4.5A Power Supply 1
User’s Manual 1
Video
Compare with similar items
  • 5 stars: 28 (90%)
  • 4 stars: 3 (10%)
John Duffy
Great amplifier but it destroys my short wave listening
N. Murph
Fosi Audio BT30D Bluetooth 2.1 CH Power Amplifier for my Bose Acoustimass 15 II Home Ent System
Prior to purchasing, I conducted extensive research into which amp would work best for my application which was for final connection to my old Bose Acoustimass 15 II Home Ent System. (Please note that I am only using two of the six satellite speakers as required for stereo sound rather than surround sound). Now having set up and used my new Fosi amp, I am very impressed with it. Easy Bluetooth connection and good control of the sound. The only negative point would be how close together the control knobs are which makes turning them slightly tricky. However, the compact size of the Fosi Audio BT30D is excellent as it doesn't take up much space so I guess this over-rides the slight disadvantage of the closeness of the knobs. All in all, this is a great little amp. Highly recommended.
Christopher Davies - The HiFi Heretic
Punches far above it's size and price!
I grabbed the non-Pro BT30D as my very first Fosi component, to build my wife a lovely 2.1 system for her new tiny Nucbox PC. I matched it with some classic (and old!) British speakers, namely a set of Gale Mini Monitors. I matched those with a (very cheap!) Pioneer passive subwoofer - and I must say that this combination of speakers and amp literally blew my mind.
Listening to some of my favourite tracks to dial in the subwoofer correctly saw me cry four times in the first hour, as the music moved me to tears. This hasn't happened since I was auditioning $100,000 of NAIM equipment in the 1990s! And so, Fosi are doing it all correctly: The sound - the form factor - the look - the individual components - it all adds up to be deeply synergistic, and you will be so incredibly impressed with the BT30D junior, that you will almost certainly rush out and buy a BT30D Pro with the bigger 48-volt power supply.
You will never be disappointed by the little BT30D (non-Pro) and it will make you smile a LOT.
10/10 - Unbelievable value, and stunning performance, in a tiny package.
BT30D
Po meni je ovo jedno od boljih Fosi pojacala...
Steven Samuelson
The little amp that could!
Using it as a 2.1 for the TV it's much better than the soundbar it replaced. The adjustable bass crossover and separate volume control dials it in perfectly to match the main channels. Bluetooth is flawless and the better speakers that are used the better it will sound surprisingly well worth every penny!
k
krishna Reddy Mittapalli
Excellent
Good audio and excellent sound
Cipola Krisztián
Tökéletesen működik. Nagyon jó, kompakt erősítő.
Ray E
BT30D PRO
This amplifier is solid. Sounds great and looks great. I have it hooked up to left and right channels, a passive sub, and an active sub. Using the 32 volt power supply that came with it and it is strong and loud. I'm glad I bought it. Thanks for a great product Fosi.
ANDREW MACIE
Elvijs Paegle
Very satisfied.
Timothy Maimone
Stan Myers
Great value
Just used for background music, works and sounds great, very easy hookup
William Rogers
Lance Peters
Awesome product! Great service!
Thank you Fosi Audio. The BT30D bluetooth amplifier is one of the best purchases I made in a long while. I moved to a smaller apartment and needed a much smaller amplifier to drive my shelf speakers but did not want to lose any quality in sound. Wow the BT30D packs a quality punch. Wife is happy I am not taking up much space with my HiFi system, and I am happy with the quality sound! Win, win situation. Also I am glad I bought direct from Fosi Audio as I paid much cheaper and was kept up to date with the transit route of my package. It was a peace of mind purchase and will recommend anyone to do so. Well done Fosi Audio! Another very happy customer!
Watt Phuket
Great sound
t
tommaso alabiso
Well done guys sturdy and powerful only thing I would add some frequencies on the panel for the sub freq selector I know it��s small but would help
Nicholas Studebaker
Fosi BT 30D. (Not the pro)
There is a lot to like about this powerhouse amp. Actually everything, with the exception of an unsatisfactory explanation of how the frequency knob functions, namely, there are no units of measurement marked around the knob (example: 30 Hz, 50 Hz, 70 Hz) to know where the crossover is being set. Over all great amp.
Lior Friedman
I'm very pleased. Works perfect
g
guillaume huguenard
Love the sound, but not enough power!
Scott Breidenbach
Just as advertised!
The mini amplifier works perfectly for my purposes.
Troy Loomis
Awesome
Love that I can replace my big old receiver for this little Bluetooth gem. Love it!!!
Eric Thomas
Fabulous Product
Not only are your amps the real deal in terms of power delivery, but the small size allows me to tuck them away just about anywhere and my life has changed now because this has taught me the value of bluetooth!
Forget wires, just hang a TV on the wall and bluetooth the audio into these superb amps. Best of all there is no delay in the audio meaning there are zero lip sync issues. I wish I could say that about my MUCH more expensive Denon receivers, argh!!
And finally, maybe it's my imagination, I now own four of these and they always seem to arrive ahead of the expected delivery date. Please... don't spend more money than you have to, these absolutely rock!!!
Daksh Mall
Fosi Audio BT30D Bluetooth 5.0 2.1 Channel Power Amplifier with Bass & Treble Control
A. Kopel
Nice
This amp gives a lot of value for money.
it is great for my home office where I listen to some background music from time to time.
It is basic. For this price I'm satisficed. Additional functionality could be nice like:
1. auto sleep.
2. auto recognition of S/W and there's not any - ignore crossover frequency automatically (I did it manually).
All in all, the pricing is in the sweet spot for me. Any cent over 75$ requires tax and handling cost in my country. So, yeah, works for me :)
Ruben Torres
Very good and tiny!!! I used this for my TV and it is way louder than my soundbar!!! I have a matrix surrounded setup that sounds great for little money!!!
Ruben Torres
Very cool and tiny!!!
I'm blown away!!! This amp sounds good and it's small enough to hide behind a TV.
Miki Jino
Great product thank you
Niklas Berglund
For right application
Yeah it's a low cost Amp.
Sound quality is better then expected and base and treble controls works fine.
Bas output feels a bit boosted down low.
Tested it on a lot of woofers 5"to 18" and I delivers good sound.
Bluetooth connection is fast an stable.
Missing a digital input, but for this price you can't get everything.
Power output is the biggest problem, don't expect it to deliver allot of power,
No party Amplifier !
but at the right place it's a nice Amp.
I'm using one in my kitchen and one in my office, and one outside in the garden.
Realy like it but twice the power would be awesome.
