  • Input: 3.5mm AUX, Optical, Bluetooth. Output: 3.5mm Pre-Out, Passive Speakers+Subwoofer
  • Rated Power Output: 4.1 Channel: 30w*4+60W*1 @4Ω; 5.0 Channel: 30W*5
  • Max Power Output: 50Wx5 @4Ω
SUB/CEN Channel Mode Switch
In FLAT mode, the SUB/CEN channel outputs full-range audio signals, while in SUB mode, it outputs low-frequency signals from 20 to 300Hz.
Ambient Light Strip
Input modes are color-coded for easy use: blue for Bluetooth, orange for AUX, and red for OPT, to enhance the intuitiveness of operation.
Multi-Functional Remote
Provides functions like device power on/off, input mode switching, one-touch mute, etc., offering greater convenience.
Full-Aluminum Alloy Chassis
Constructed with a full metal casing, CNC machined, finely sandblasted for a simple yet durable and rugged design.
  • All-in-One Amp: A mini amplifier that integrates DAC and power amplification. This stereo amplifier supports up to 5 channels output, switchable between 4.1 and 5.0 channels. It features Bluetooth, AUX, and optical digital inputs, along with pre-out and support for up to 5 speaker outputs.
  • Multi-Scenario Solution: Ideal for pairing with outdoor speakers or wall-mounted speakers, perfect for setting up 2 to 5-channel audio systems in environments like patios, cafes, restaurants, bars, etc. It can also serve as a home theater or desktop HiFi system amplifier, meeting your diverse needs from indoor to outdoor settings.
  • Enhanced Immersion: Take your sim racing and home theater experience to a whole new level! By pairing with bass shakers, its sufficient power output and bass boost help significantly enhance the realism of racing simulator games. When watching movies at home, the vibration feedback can also help you experience your movies in another dimension, making every movie feel more realistic like being in a cinema.
  • Effortless Operation: Featuring a comprehensive user-friendly design with a built-in power supply, accompanied by remote control, supporting bass and treble tone adjustment, a multifunctional central knob for volume control, powering on/off and mode switching, LED mode indicator ambient light, etc. Enjoying music has never been easier.
  • Elegant and Durable: Continuing Fosi Audio's tradition of an all-aluminum alloy body design, the CNC unibody construction and fine metal sandblasting process highlight a minimalist aesthetic. The full metal body ensures durability, and you can enjoy Fosi Audio's 24-month guarantee for every unit.
  • Channel : Bluetooth 4.1 CH Amp
  • Input : Bluetooth + 3.5mm AUX + OPT
  • Output : 3.5mm Pre-Out + Speaker Out
  • SNR : ≥88dB
  • THD : ≤ 0.03%
  • Terminal Impedance : 4-8Ω
  • Rated Power Output : 30w*4+60W*1
  • MAX Power Output : 50Wx5 @4Ω
  • Work Voltage: AC 110V - 240V
  • Product Dimensions : 6.1 x 7.2 x 2 inches
  • HT4S*1
  • Power Cord*1
  • Bluetooth Antenna*1
  • 3.5mm Auxiliary Cable*1
  • Remote Control*1
  • HT4S User Manual*1
  • 5 stars: 14 (67%)
  • 4 stars: 7 (33%)
Will Bergan
Compact Bluetooth Speaker Amp
If you're looking for a solid bluetooth capable speaker amp to run some outdoor speakers (amp is kept indoors of course), look no further than the HT4S. Works a treat!
Jaime Eduardo Arciniega
Multi use
Hooked it up to my turntable via aux, television via optical and the Bluetooth is open for my phone or any other device running a 2.1 system for now provides great power and makes my turntable sound amazing which is also going through a fosi p2 phono preamp. Control could be better but I can��t complain makes switching inputs a breeze
Très bon ampli.
Testé avec des Bass shaker pour le simracing (4 TT25 et 2 BST-2), très bien.
Mon usage mais fait maintenant partir sur le V3 et BT20A Pro
Zachary Flippin
Extremely easy to hook up, also was very impressed with the amount of sound it puts out. You cannot beat the value. ??
Keith Robinson
HT4s
Great Bluetooth/amplifier for my needs, perfect for outdoors and vasatile as an indoor amp. Very pleased with this purchase simple and easy to set up and it looks good. Highly recommend this unit.
Ivan Rostas
Great value
A unique, well built and practical solution to a number of specific applications. It��s now driving 4 garden speakers and buried sub. Nothing out there with such quality components.
Stephan Lutter
J.S.
HT4S for Bass Shaker Amp
Using it to power 5 bass shakers and works excellent!
Dan Hoier
WOW
I am beyond impressed, using this on a pair of KEF Q150s, they have never sounded better.
Ed Emler
Fosi HT4S as Expected
I wanted a stereo digital integrated amp with a phono input, 1 line input, 1 optical input, bluetooth, headphone output and subwoofer output with a remote but had to settle for this HT4S. It's a solid performer that sounds good. It's a fine, fine product. I don't like the orange knob. It should have been silver gray. Better yet make that big knob opaque and put a color changing LED light behind it and let the customer choose the color of the light they would like on the volume control knob. As soon as I can find the integrated amp I mentioned earlier for $300 or under, I'm selling this one on ebay and buy the other.
Ricardo Jimenez Urcid
Great product!!
Great product and even better support, can't recommend enough
SteveRSA
Clean sound
Clean sound.
Great for movies, Youtube, and music.
Optics still needs to be tested to see if audio quality is 'fuller'
Bluetooth signal strength is impressive. A proper 5m distance with two walls between device and amp. Not a beat missed.
Manoj M Nair
Good
Power is bit low or not i donno, some audio i feel low output even at full volume
Subramanian s
Very good
Very good
Rron Maloku
Living room ceiling speakers
????Very weak power,
????Came a week or two late,
????Perfect build quality,
????Small and stylish,
????Remote control,
????Connectivity toslink,aux,bluetooth.
n
nilsa cortes
Fosi Audio HT4S Bluetooth Amplifier for Outdoor Speakers, 4 Channel Power Amp for Bass Shaker with Remote Control
Godzila
HT4S from my POV
Best in class 5.1 channel Amplifier.
Kendall Durgan
Works great. I connected an active subwoofer and a working feeder. I put high quality speakers and the sound is excellent
Brian D.
Nice Little System!
I hooked this up to the 4 Advent speakers that I have hooked up in my office. Sounds great - lots of power! I don't have a sub-woofer installed so can't comment on that. The only reason I gave it a 4 instead of a 5 is that it was a bit challenging to connect my speaker wires. I have 16 ga. monster cable and there is limited space to connect the wires and the holes are small. I basically had to re-cut and twist each wire so that it would fit in the hole. The connector holes are not as large as a typical receiver. Sounds Awesome though!
Anup Ravi
HT4S from my POV
'- Pros :
Top notch Build Quality
Easy to setup and use
Connectivity options are good
Stereo amplifier
-Cons :
Feels expensive
No dolby support
Every time need to turn on the device manually'
Peter Schneider
Very neat compact and clean amp, easy to use
For my specific application, the HT4S is the ideal solution: It replaces an older analog Home Theater 5.1 setup with an active subwoofer which was always used in dual stereo mode (rear speakers duplicating the front speaker signal). The HT4S saves a lot of space and is much easier to use than the old amp with dozens of unused connectors and buttons. The color indicator bar is easy to grasp, and the remote control has all the necessary functions. I just would have preferred cinch connectors instead of the 3.5mm jacks for the analog ports. The manual and the description could be a bit clearer about the limitations (no "true" surround sound), and how exactly you should set up an active subwoofer to avoid trial and error.
