  • Input: USB-C/OPT/COA/3.5MM Microphone; Output: RCA/3.5mm Headphone; OPT/COASampling Rate: up to 24bit/192 kHz
  • Output power: 1000mw@16Ω, 500mw@32Ω, 300mw@64Ω, 150mw@128Ω, 80mw@300Ω;
  • THD: <0.003%; S/N: >110db; Frequency response: 20Hz-20kHz;Recommended headphone impedance: 16-300Ω
  • The upgraded version for Fosi Audio Q4 adds microphone function, K5 Pro headphone DAC amp combo, next-generation audio converter with unrivaled internals, more outstanding performance, and richer audio details. Born for Gaming. K5 Pro stereo DAC headphone amplifier is perfect for your home gaming system, equivalent to an external sound card, suitable for PS5/Computers/PC/MAC/Nintendo Switch/active speakers, etc;
  • K5 Pro USB DAC converts USB Type C/Optical/Coaxial signals to 3.5MM AUX and RCA signals with low distortion and great dynamic range. Unique design: 2-in-1 USB Type C interface charging port and audio input means K5 Pro is compatible with your phones. RCA output can be connected to an amplifier or powered speakers on your desktop. 3.5 MM AUX and microphone interface can drive 16 Ohm to 300 Ohm headphones;
  • K5 Pro headphone DAC adopts the Texas Instruments NE5532 op-amp chip. The circuit design implementing this DAC has been optimized for a low-noise floor and clean sound. Compared to the last generation Q4, K5 Pro has noticeably improved on overall sound quality, so you can get immersed in your music even more easily;
  • Product Specifications: K5 Pro with master volume/bass/treble control and input mode switch. USB Type C/Optical/Coaxial sampling rate: up to 24 bit/192 kHz, THD ≤0.003%, SNR ≥110dB. Output power: 1000mw@16Ω, 500mw@32Ω, 300mw@64Ω, 150mw@128Ω, 80mw@300Ω;
  • What You Get: K5 Pro headphone DAC amp x1, 3.5MM headphone splitter x1, 2-in-1 USB Type A/C to Type C cable x1, User Manual x1, Optical Cable x1, our worry-free 24-month warranty, and friendly customer service.
  • THD: <0.003%
  • SNR: ≥110dB
  • Net Weight: 0.55lb (251g)
  • Power Supply: 5V
  • Fosi Audio K5 Pro x 1
  • USB Type-C cable x 1
  • Optical cable x 1
  • User’s Manual x 1
  • 5 stars: 131 (86%)
  • 4 stars: 18 (12%)
  • 3 stars: 1 (1%)
  • 1 star: 3 (2%)
Alexandre Dos ramos
Très bon Dac, bien puissant pour mon casque 250ohm.
Je m'en sers pour le gaming, très bon.
Mavrichi
Best Entry level DAC ever , runs my fosi audio i5 and my Moondrop Aria's just great.
Have been using it for almost a year, don't really feel the need to upgrade, using it with the fosi audio i5 and it runs them great.
love the fact i can tune the basss and highs on the fly.
Mavrichi Marian
Paul
Portable Powerhouse
I bought this to compare with a Schitt Fulla E to use as a portable usb powered DAC/amp with a WIIM mini streamer on a usb battery bank. The K5 ended up staying with me, and the Fulla E was given away to a friend. K5 has noticeably more output (~4V vs 2V) and tone controls to dial in any headphones. Interestingly, the RCA preamp outputs only appear to be 1V, but there is less noise and less crosstalk. There is some residual noise (hiss) via the 3.5mm headphone output when compared to the Fulla E, but that is probably related to the higher gain of the K5. I would love to see a unit like this with analog (aux) inputs and outputs, and replace the mic input with a 4.4mm balanced output. Until then I feel no need to upgrade
Paul H
Portable Powerhouse
Stefan
Big Thanks for your product
The Fosi Audio K5 Pro is simply fantastic. It delivers clean, powerful sound with impressive clarity and detail, far beyond for its price. The build quality feels premium and compact, perfect for desktop setups. Bass is tight, mids are rich, and highs are crisp without harshness. It’s an excellent DAC/amp combo that brings new life to my HD560S headphones — truly a hidden gem.
Stefan Scorpan
The Fosi Audio K5 Pro is simply fantastic. It delivers clean, powerful sound with impressive clarity and detail, far beyond for its price. The build quality feels premium and compact, perfect for desktop setups. Bass is tight, mids are rich, and highs are crisp without harshness. It��s an excellent DAC/amp combo that brings new life to my HD560S headphones �� truly a hidden gem.
Elliot
Everything very well, delivered after the indicated date, but I don't take long. Sound quality if increase.
Elliot Dibbert
Elenor
I bought well at a good discount rate at a good opportunity. Well compatible for ps5. The power button should be pressed and come in.
Elenor Stehr
Wendell
Good equipment, quality/price is what one expected. I'm testing it with multiple headphones and everything is Ok.
Zora
Fosi K5 Pro... I had some noise problems with a low impedance headset, after I used another one with higher impedance the noise no longer exists... so it became a great dac for gaming 👍🏻 full support from the store... thank you
Shawn
Has surprised Me. If you have good helmets, you will notice a change in brutal quality. I recommend it.
Wendell Ebert
Zora Mraz
Fosi K5 Pro... I had some noise problems with a low impedance headset, after I used another one with higher impedance the noise no longer exists... so it became a great dac for gaming ???? full support from the store... thank you
Shawn Mante
Porter
Connect to Harman Kardon
Not much results
No feeling of improved sound quality ㅠ ㅠ
However, it is easy to adjust and can use fixed headphones
Porter Dietrich
Not much results
No feeling of improved sound quality ? ?
Kasandra
I am new in relation to this type of product, but that left a very good impression for my use. Play and listen to music, I am satisfied!
Kasandra Connelly
Korey
It is great that we have this DAC option with microphone input, a lot of quality, amazing construction and the very attentive seller❤️
