  • Input: BT/RCA/OPT/USB/COA; Output: Passive Speakers/Subwoofer/Pre-Out
  • Amp Chip: TPA3255×2; THD: ≤0.03%; SNR: ≥100dB
  • Max Output Power: 165W×2+350W@4Ω
Multiple Outputs
Supports outputs for Passive Speakers, Subwoofer, and a Pre-out, enabling flexible setups for both stereo and 2.1 systems.
Automatic Standby Feature
Automatically enters standby mode after 2 minutes of no signal input, effectively reducing energy consumption and extending device lifespan.
Quick Mode Switching
Easily switch input modes with one click, and settings automatically restore to the previous upon restart, eliminating repetitive adjustments.
Dual 4700μF Capacitors
Features high-quality large-capacity capacitors that enhance sound quality, dynamic range, and stability, extending the amplifier's lifespan.
  • All-in-One DAC Amplifier: The MC351 integrated amp features high-resolution decoding capabilities, supporting Bluetooth, USB, Optical, and Coaxial digital inputs. With its extensive input and output options, you can easily set up a 2.1 home theater or other stereo HiFi audio systems.
  • High Power with Great Sound: Equipped with two high-end Texas Instruments TPA3255 Class-D amplifier chips and a 100-fin heatsink, the MC351 can stably output up to 165W x 2 + 350W power in a 2.1 channel setup. The dual PCBA separated design ensures that the input and output signals do not interfere with each other, providing you with the purest and most impeccable sound quality.
  • User-Friendly Control Design: Supports one-touch switching between 5 input modes and includes bass and treble controls, with central detents for tone defeating, for easy sound customization. It also features an automatic standby function, entering standby mode after 2 minutes of no signal input to effectively reduce power consumption.
  • Vintage Charm: The eye candy round mini VU meter adds a classic retro vibe to your sound system. The needle of the level meter will dance to the music, providing you with both visual and auditory enjoyment. The MC351 is an excellent companion for turntables, allowing you to relive classic tracks.
  • Exquisite Craftsmanship: Featuring an all-aluminum-alloy CNC integrated design and a finely sandblasted metal finish, the MC351 boasts a seamless body with no visible screws, showcasing minimalist aesthetics. The all-metal body ensures durability, and you can enjoy the peace of mind provided by Fosi Audio's 24-month warranty.
  • Output Power:
    165W x 2 + 350W @ 4Ω
  • Terminating Impedance: 4-8Ω
  • Input Mode: Bluetooth 5.3+RCA+COA+OPT+USB
  • Output Mode: SPK OUT+SUB OUT+3.5mm PRE OUT
  • THD: ≤0.03%
  • SNR: ≥100dB
  • Device Dimension: 7.28  x 5.0 x 2.24 inches
  • Sampling Rate: USB24bit/96kHz ; OPT/COA 32bit/192kHz
  • MC351 Power Amplifier x 1
  • 32V/5A Power Adapter x 1
  • User’s Manual x 1
  • 5 stars: 18 (75%)
  • 4 stars: 6 (25%)
DocHouse
Great amp
No better amp beside my mac
Alberto Alfaro Ramirez
Excelente amplificador
Corrijo me calificacion, el amplificador de es de excelente calidad,
la cadena de sonido fue Amplificador Fosi MC351 -- Bocinas de torre Polk Es55, Bluetooth -- Spotify (Via Celular Ipod, mi celular samsung no funciono bien con los 2 canales en el Lef sonaba muy bajito pero era un tema del celular) ya lo cambie y suena bien, excelente amplificador! y de favor si peuden borrar mi calificacion anterior ya que era una falla del celular y no del amplificador.
Fosi Audio MC351
Soy nuevo en esto del audio, compre mis bocinas Polk ES55 y compre es amplificador, las bocinas suenan regular una bocina, la del lado izquierdo no suena casi nada, la del lado derecho suena bien pero no me suenan con sonidos brillantes, nitidos ni equilibrados como en la sala de audio en que las escuche, no se si la potencia del amplificador es poca a la que necesitan los altavoces de torre, o igual que aflojen en unos meses las bocinas o bien no se usar el equipo amplificado Fosi! pero me parece buen amplificado ya pondre otras bocinas perod e estanteria technics que estaban arrumbadas. ya hi les dire como suena el amplificador y esas bocinas
s
shiva shanker prasad
I am using this product since last few days with so many input options like, bluetooth, Co axial, USB and RCA. I have not tried Optical input yet. Today I used USB with MAC and Apple Hi resolution lossless music using MIDI. Also with 48 V power supply. Sound quality is excellent. But there is some heating issues in Amplifier. I think its design should be improved like ZA3.
s
Today, I received this amplifier directly from Fosi Audio after 12 days of eagerly waiting for it. I am using it right now and posting my feedback as well. The sound quality is good. Presently, I am listening to sound on my two old bookshelf speakers from SONY. I have not attached a subwoofer yet, but the sound quality is still excellent. The Bluetooth functionality is working fine.
Fosi Audio products are good for specific uses at a low cost. The build quality is robust, and I think it will be a reliable companion for a long time. I am already having ZA3 balanced amplifier by Fosi Audio. I have purchased it to listen Audio CDs by connecting it with coaxial cable from output of Sony Blue ray Player. Also my old Passive Subwoofer of 180 watt can be connected. This will be complete 2.1 setup for stereo listening. I found this product very useful when you do not want a big setup and still want to listen quality sound. I wish Fosi Audio would also come up with other products like a CD player and a turntable. . Best wishes to Fosi Audio and thanks for making such good products.
William Sims
Exactly what you expect
The device is exactly what you see online and fits the description. I will add that the design looks very nice on my bookshelf.
A S
See what you value
Good but I feel like it was a bit expensive for what it provides.
Garin Hatch
Pretty decent
It's a little under powered compared to its published rating, but overall I'm reasonably pleased.
Sleek looking device. Bluetooth works well. Have yet to experiment with the DAC but looking forward to it.
Farzad Davari
Everything is good just have big problem , this amp don��t have a remote control for volume
Alberto Valentin
Smooth, awesome power
Night and day difference with my older less powerful amp I replaced. Sonic quality is simply amazingly better
JC
Great little amp
The Fosi MC351 is a great little amplifier. It looks awesome and it has plenty of power for normal listening. The overall build quality is impressive
Byron Kirkland
Great
Naman
Beauty & the Beast
A beastly machine in a spectacularly compact size.
Arjun Roy
Good sound, just missing a crossover filter on the speaker output
Good sound, just missing a crossover filter on the speaker output. But otherwise, no concerns.
Jose Fernandez
Keep up the excellent designs !
Excellent piece of equipment with great performance.
Craig
Fosi Audio MC351
Wow, this is a nice little unit. I've seen a lot of praises for the ZA3 and this unit with the Bluetooth was a pleasant surprise. Great sound quality and a nice touch with the meter. You have to rock it a bit to get it to move, but that's OK. Very cool and versatile.
Petros B
As expected
Jim Mussen
Great amp
The amp is a great little workhorse
Wonderful build and great sound
I did have to burn in a bit, at first I thought it dud not have the power I needed, but it soon started to sound better and better.
It also arrived much sooner than I had expected
Victoria Smagina
Very nice!
Thank you guys, all of you team, you made really interesting and good things!!
Stephen Bull
Lovin the sounds
Solid sound that provides hours of entertainment. Does exactly what it says on the box�� well.
Michael Lucci
Fosi Audio MC351 2.1 Channel Integrated Amplifier with DAC, VU Meter and Bluetooth
s
Minor problem in volume knob
After almost one month use I am noticing some noise from speakers while switching off the amp. I think vol knob needs replacement. Its design may require improvement.
Alex Tassos
Great amp
Good power, nice size and very quiet. Replaced a Hafler class A amp with this and no regrets.
Theodore Gager
