Operation Guide
  • 5 stars: 33 (89%)
  • 4 stars: 1 (3%)
  • 3 stars: 2 (5%)
  • 1 star: 1 (3%)
James
Perfect for a desktop DAC setup
Nice little setup for most DAC systems and well made.
Looks great too.
My only gripe and the not really major is rubber tips for the bottom of the legs would be nice so your nice table top does not get scratched and the rack has more grip.
Maybe an extra tier would be nice as well? Hint hint
Ryan
Compact, Sturdy, Attractive, and Extremely Functional
I love this rack. It's compact, sturdy, attractive, and extremely functional. The aluminum frame feels strong and well-made, and the acrylic shelves look great while providing excellent airflow through the built-in cutouts. I'm not using USB cooling fans, but it's nice to have that option available.
A couple of tips: remember to remove the protective plastic film from the acrylic panels, and be aware that the feet are a little pointy. I put four 1-inch, 50-durometer Sorbothane discs under mine to protect the surface and provide vibration isolation.
I'm using this rack in my living room system for a DAC, phono preamp, Fosi V3 Monoblock, and Schiit Gjallarhorn. There's even enough space under the bottom shelf for my Apple TV, with a little room to spare.
What I appreciate most is how this rack makes everything look neat, tidy, and intentional instead of just stacking components on top of each other. For around $50, it's an outstanding value and an easy recommendation. I'm already considering buying another one for my desktop setup if I add more gear in the future. Highly recommended!
John
Space between shelves could be wider and taller
Space between shelves could be wider and taller to accommodate fans.
Marcelo Di Iorio
Good quality and stability. Perfect for the V3 Mono and others of similar size.
Yashiko
Fosi Audio 3-Layer Acrylic Rack
Absolutely love it.
Yashiko
Absolutely love it.
Roberto
Great size and fit with fans
works very well with the fans attached above the Fosi monos, very quiet operation and esthetically pleasing, compared to fans sitting on top or below the monos
Roberto A
Nikolai
Good quality
I got this off of a friend and I liked the quality alot
Nikolai Lyraan
Good quality
Cesar
Ajuste perfecto
El ajuste es Perfecto y se ve genial. Les muestro mi escritorio. Recomendado
Cesar
Ajuste perfecto
Chris
Tidy
Tulsi
Fosi Audio Best Products
"I love the build quality—it feels sturdy, durable, and well-designed." Fosi Audio
Massimo Di Mauro
Ottimo
Dean
Great product
Need a small stand to tidy up my equipment and this works great highly recommend
Adriano Scaccia
Beautiful and well-made.
Wesley
Fosi Audio 3-Layer Acrylic Rack for Audio Components
James
Acrylic rack
Havent recieved it yet
SORIN PETRE
Excellent. Solid. Love it!
Ivan
Ivans great buy!!
It so fittingly perfect one of the best deal of my life well spent money!!
Ivan Puccinelli
Ivans great buy!!
f
fede
ok
tutto ok
f
fede fez
ok
tutto ok
Bioguy01
Good idea poor execution
I really wanted to like this rack. My main issue is my ZP3 can only set on top. The ZP3 is too wide to fit between the support posts on the bottom or second level. This needs to be addressed by making the rack wider by 10mm (3/8") between the post locations.
A.B.
Space saving
Rack is sturdy and well made the cooling fans fit well and help cool my V3’s. I will not be worried about over heating them in the summer months. I may need to but another when I start adding to my collection of Fosi products.
