Fosi Audio PSU20 Linear Power Supply
- Power Three Devices Simultaneously
- Reduce Noise with 0.1mV Ripple
- Isolate Power Across 3 Channels
- Switch Between 5V, 12V & 15V
With dual DC outputs and one USB-A output, the PSU20 can power up to three audio devices from a single source.
Flexible Compatibility
Supports selectable 5V, 12V, and 15V outputs, making the PSU20 compatible with CD transports, DACs, headphone amplifiers, and preamps.
3 Fully Isolated Outputs
Each output has its own dedicated rectification, filtering, regulation, and protection circuitry to deliver clean, stable power without interference between connected devices.
0.1mV Ultra-Low Ripple
With ripple as low as 0.1mV, the PSU20 helps reduce ripple noise and deliver a cleaner background for high-fidelity audio systems.
Engineered for Stable Long-Term Use
A custom low-noise fan activates at 55°C and operates at just 30dB, while over-temperature, over-voltage, and over-current protection help safeguard connected audio equipment.
Power Input
AC: 115V / 230V
Note:
Power Output
Operating Temperature
-20 ~ 40°C (-4°F ~ 104°F)
Temperature Rise Test
- Fosi Audio PSU20*1
- User Manual*1
- AC Power Cord*1
