  • Excellent sound performance: Low ground noise, built-in output protect the circuit, no buzzing or ringing noise, Audiophile-level sound quality, exclusively designed for the customers who pursue HiFi sound; and safe for your expensive headphones.
  • Stereo and Preamplify: Headphones amp also can be used as a stereo preamp, Parallel 3.5mm and RCA stereo inputs, 6.35mm headphone output, include a 6.35mm to 3.5mm adapter;
  • High-performance: P2 is a Hi-Fi tube headphone amp, 2 X 5725 tubes can easily power high-performance headphones including the HD580, HD600, HD650, K701, K702, Q701, and many more, recommend 32-300ohm headphones
  • Easy replace tube: Tubes can be replaced by JAN 5654W/6j1/6J4/GE5654/6AK5/6*1n/ E180F/6ж9П/EF861/6688 tubes etc
  • Exquisite appearance: Small Compact Size, All aluminum alloy shell and come with an 18-month manufacturer's warranty.
Headphone Amplifier Vacuum Tube Headphone Amp Mini Hi-Fi Stereo Audio with Low Ground Noise Output Protection for Headphones Fosi Audio P2
Model P2
OP-Amp NE5532
Headphones Output 16-64Ohm
Headphone Impedance 32-600 Ω
Input Mode 3.5mm Audio jack, Stereo L / R RCA
Frequency Range 20Hz-20 kHz (± 3dB)
THD ≤0, 03%
SNR ≥ 95db
Input Sensitivity 0.2mV
Device Dimension L99 * W98 * H33 mm
Device Weight 0.25 kg
Operating Voltage DC12V
P2 Headphone Amplifier x 1
5725 Vacuum Tubes x 2
DC 12V Power Supply x 1
6.35mm to 3.5mm Adapter x 1
Compare with similar items:
P1 Pro Bluetooth 5.0 Tube Preamplifier
P1 Vacuum Tube Pre-Amplifier
  • 5 stars: 2 (40%)
  • 4 stars: 2 (40%)
  • 1 star: 1 (20%)
Great little
Great little amp
Ioannis
Excellent device
I am amazed that it has zero noise combined with my scarlett focusrite 16i6 i carnked up the volume and it has literally zero hiss at max levels.
Jeff
Incorrect replacement tubes
Description says you can use E180F, EF861, and 6688 tubes. These tubes are 9 pin! They don’t fit in a 7 pin sockets on a P2! I had a premium pair of Mullard NOS E180F tubes I was going to use in this amp. One of the main reasons I purchased it! Very disappointed in your documentation. You must correct immediately.
TIBOR
Good headphone amp with some base noise.
My Bayerdinamic 990-pro 250 ohm headphones can't drive properly.Very clear, nice sound, but the power of the amp is too low for these headphones.
TIBOR KEKEDI
