IM4 IEM Accessories include 4.4mm balanced cable, 3.5mm cable with microphone, and D2 DAC.
High-purity wire, low signal loss, enhance sound quality—clear treble, full bass, wide sound field.
Gold-plated plug, anti-oxidation, stable transmission; soft wire, anti-tangle, comfortable to use.
Plug and play, no modification needed. Suitable for daily commute, Hi-Fi listening, calls, games.
Specs: Fit IM4 IEM, 4.4mm balanced + 3.5mm with mic + D2 USB-C to 3.5mm DAC.
  • 5 stars: 6 (86%)
  • 4 stars: 1 (14%)
Johan
A bit to expensive, but if you need it ya probably going to get it!
MARKKU
 + IM4 + 4.4mm Balanced cable
Q
Quim Duran
Molt bona qualitat i acabats. Els Fosi Audio IM4 són còmodes, estan ben construïts i venen molt ben equipats.
Pel que fa al so, ofereixen una presentació clara, detallada i agradable, amb bons greus, presents i amb cos però sense tapar les veus. Els mitjos tenen bona definició i les veus sonen naturals, mentre que els aguts aporten detall i sensació d’aire sense resultar excessivament agressius. També m’ha agradat la separació dels instruments i l’escena sonora, especialment escoltant jazz, música acústica i clàssica.
La possibilitat d’utilitzar connexió balancejada de 4,4 mm, cable de 3,5 mm i el DAC els fa molt versàtils. En conjunt, uns IEM molt agradables d’escoltar i amb una excel·lent relació qualitat-preu.
Andrew McCormick
Im not someone who writes reviews, but in this case I'm going to suggest this combination is a winner.
This iem dac combination is by far my top sounding, favourite pair, of iem's I own, and I own many! Also I have made many purchases from fosi audio and i have never had issues, I recommend.
DocHouse
Awesome stuff
Great listening
Ruslan Polshyn
Fosi Audio IM4 , + 4,4 mm Balanced
In the budget segment, this is the best solution right now. If you're unsure which headphones to buy, get these and you'll know where to go from there. With the stock cable, they sound full-bodied, with some emphasis on the low frequencies. I also bought an additional cable, and the sound became more "mature," with more structure to the low frequencies. The signature didn't change much, which is good. Fosi pleasantly surprised me.
Gerry Silverman
Great upgrade
I��m a Fosi fanboy, so naturally I had to get this for my Fosi md3 , and it really makes a huge difference in the sound; it��s much quieter and cleaner with no noise. Also, kudos to the non tangled cable. It��s $36 , and well worth it.
