Born for HiFi and Entertainment
The K7 is an all-in-one HiFi DAC and headphone amplifier, developed based on in-depth interviews with hundreds of headphone HiFi and gaming enthusiasts. It supports mainstream digital inputs including USB, optical, and coaxial, and features aptX HD/LL for high-quality Bluetooth audio streaming.
  • Input: Bluetooth, COAX, OPT, USB
  • Output: 3.5mm Single-ended/4.4mm Balanced Headphone Output, RCA
  • SNR: ≥ 121dB; THD+N: ≤ 0.0002%; Noise Floor: ≤6.5μV
  • Input Voltage: DC 12V
  • Versatile DAC Amp: The K7 is designed for both HiFi headphone audiophiles and music lovers. It can serve as a powerful hub for building your desktop audio system. Whether your're enjoying music, gaming or working, the K7 handles it all with ease.
  • Audiophile-Grade Chipset: Equipped with the AK4493S DAC, XMOS XU208 USB processor, and TPA6120 headphone amps, the K7 supports high-resolution decoding up to PCM 384kHz/32bit and DSD256. With up to 2100mW output power, it easily drives demanding headphones.
  • Comprehensive Connectivity: Supports USB-C, coaxial, optical, Bluetooth aptX HD/LL and 3.5mm microphone input. Outputs include 4.4mm balanced, 3.5mm single-ended, and RCA—easily connecting to headphones, powered speakers, or amplifiers for desktop setups.
  • User-Centric Design: Compact yet user-friendly, the K7 features dual large control knobs, five shortcut buttons, and an angled chassis for ergonomic comfort. A high-resolution display shows real-time status, making operation easy and intuitive.
  • Durable All-Metal Build: Crafted from solid aluminum alloy, the K7 features a rugged, wear-resistant chassis with a sleek metallic finish and enhanced electromagnetic interference shielding.
  • Fosi Audio K7
  • USB-A/C to USB-C Cable
  • Bluetooth Antenna
  • Y-Splitter Cable
  • DC 12V Power Supply
  • 5 stars: 80 (94%)
  • 4 stars: 5 (6%)
Bap
Fosi K7
Works great and seems well-built. It made my sound quality better than my old pc sound card. for gaming works a treat and finished my desktop setup well for now at least.
Del
K7 love it
It's a lot smaller than I thought it would be great sound quality on balanced running through USB for music running 3.5 mil unbalanced with microphone for gaming works a treat and finished my desktop setup well for now at least
Marilu Bergnaum
Excellent product, absurd quality, simply the best DAC to have, used together with an edition from
Mavis Macejkovic
Good
Chara Kuvalis
Everything as described. Great addition to the fosi za3
Grover Erdman
Although I received my order after two weeks due to customs clearance delays, I am very satisfied with the product. It seems like an excellent all-in-one DAC/AMP.
Jame Reinger
The sound is amazing, I now have the goal of listening to all the tracks again because I start to hear details that were not noticeable before. You can buy from this seller; the product arrived intact without scratches or dents, and the box was intact.
Brendon Schultz
Everything arrived correctly, I bought it after watching some videos on the internet about this DAC, and taking advantage of the coupons. I recommend the store and the product. Arrived quickly with the J&T carrier. Now just enjoy the sound.
Ranee Fadel
The sound is pleasant, worth every penny and even a bit more!
Also, the tone adjustment for the sound of stationary speakers was helpful.
The adjustment of both bass and treble is quite reasonable.
Due to inconvenience:
1) If the power goes out, it does not automatically turn back on.
2) On some compositions, it tries to play the track faster or vice versa more slowly. They suggested that it depends on Windows settings, the selected type of audio driver, and the sampling rate.
And for 13,000 rubles - it's a complete gift!
Randal Osinski
Amazing dac/amp. Zero complaints
Lisa Hernandez
Game Changing Audio Experience!
The Fosi Audio K7 is my first DAC/amp, and it completely transformed my gaming setup. I can now hear footsteps loud and clear, making it easy to pinpoint enemy locations with precision. The immersive sound detail gives me a real edge in competitive matches, and I absolutely love it!
Adolfo Kuhn
Hi there. I just received it today. Hopefully it will work great. Thank you for the such a good deal.
Naoma Schuster
With the promo code, the price came out to 14600 rubles. This is an excellent amplifier and DAC, even music and videos from YouTube played with new sounds, not to mention the high-quality music, games transformed, sounds that I didn't notice or pay attention to before appeared, even budget speakers and headphones transformed beyond recognition. Before this, the DAC was Asus Strix Raid DLX, the difference is huge in favor of Fosi K7, the sound became more saturated and warmer. I recommend it, especially for such a budget price today.
Inga Mayert
The sound is good and the price is good with the discount.
Oscar of the North
Don't let the word "gaming" fool you, this is proper audiophile quality!
Unboxing the device and holding it on your hand, the thing already oozes quality. Plugging this to my PC and pushing some Hi-Res music through this thing to my Sennheiser headset, I could immediately tell the difference to my Mayflower ARC DAC amp. Especially in UAC2.0 and bypass mode, the soundstage in depth, width and height is extraordinarily spacious, and transparent. Excellent bit of kit, and for the price, it's amazing! If you need a headphone amp for your PC, look no further.
Helene Becker
It feels transparent but the lines are slightly thick.
The bundled adapter is not bad either.
It seems good because it provides grounding when connected to the phone.
There seems to be a downside as it grounds when connected to the PC.
The balance is best when connecting the TV and optical cable.
Massimo Mazzara
Big Sound, Zero Hassle.High-Fidelity Performance and Seamless Integration
At first listen, the total absence of background noise stands out: no hums, clicks, or interference; the sound is not only precise but also surprisingly clean. Voices through the headphones are clear and well-defined, with a reproduction that provides naturalness and detail. The tone control, for both bass and treble, allows fine and pleasant adjustment, enabling you to tailor the listening experience to personal preferences without distorting the sound character.
The Fosi Audio K7 stands out for its refined design and remarkable flexibility, making it a suitable solution for a wide range of listening needs. Thanks to its compatibility with various devices and the complete absence of required drivers or dedicated software, it integrates seamlessly into any setup. Its sound performance, both precise and well-balanced, makes it an excellent choice for entertainment as well as for more technical or professional use.
Super
Mike S.
My masterpiece ?
I have tons of equipment (audiophil) because I want the maximum all time. Switching headphones, using different Dac`s and amplifiers to find the optimum...after using this garbage G6 from soundblaster I was hoping for a long time that a company is taking it more serious than many others. Fosi Audio made it. Not only that I love to use the K7 in gaming, the flexibility and the usage itself...I didn't expect that I will use the bt mode so often. Switching from gaming easily to bt mode and listen music is so nice...the sound is of course not like a e.g. FIIO M15 but for that price is this a masterpiece for me . I love my K7 (KS supporter) and if it's failing I will buy a new one or maybe another new version from Fosi...For years I was hoping that a company is implementing an balanced output...Fosi did it and I'm sooo happy about...setup gaming (squad): beyerdynamic MX300; (solo) beyerdynamic T1 or Fosi i5 ?. I'm in heaven...All the best and thanks a lot for this great product. Best Regards, Mike
Natanael Cruz
5 stars
Good product for sound i recommended
