Fosi Audio Amplifier Remote Control
Before Purchasing:
Please check your old remote (DA2120C or DA2120A). If the power button is red, this means it is the old version, and it does not match the current black button version.
Only the black power button version is available now.
If you don’t see your remote model in the product options, please select other remote and write a note with the model you need when you place the order.
