  • Length: 1.2 m (47.24 in)
  • Outer Diameter: 6.5 mm (0.26 in)
  • Connector Type: 3.5 mm to Dual RCA
  • Conductor: 28-strand fine copper with copper foil
  • Shielding: Aluminum foil + copper braided shield
  • Outer Protection: PVC jacket with nylon braid
  • Connector Material: Gold-plated pure copper with anodized aluminum alloy housing
  • Package Includes: 3.5 mm to Dual RCA cable ×1
  • 5 stars: 22 (100%)
  • 4 stars: 0 (0%)
Paul H
Unlock the Tone Controls of ZH3
Quality cables. I use them to send analog signal out of the PO on the ZH3 so that I can use the tone controls with an external amp
Paul H
Carlo De Palma
Benissimo
MARKKU
 + IM4 + 4.4mm Balanced cable
Rodney Bourne
Rodney Bourne
Roman K.
Fosi Audio 3.5 mm to CSA adapter cable
The Fosi 3.5 mm to RCA adapter cable is being used to connect a Fosi Merak CD player via its line-out to a Telefunken 6040 all-analog vintage receiver with 40 W rms per channel. The cable build quality is excellent with gold-palter 3.5 mm and RCA connections. The sound was provided using a pair or Wharfedale refurbished Dovedale two-way speakers, circa 1968, with the massive 12" woofers and famous super 3 midrange/tweeter with huge magnet structures. The sound background was quiet. The resulting music playback is very musical with some finesse. The highs shimmer and tingle. Instruments have some separation and "air" around the sound stage. The brass has the desired bite and microdynamics. Miles Davies trumpet sounds like a trumpet, not shrill or squawky. Very enjoyable listen. This combination is not humbled by larger full-scale CD players. This does require mating to high quality electronics and stereo speakers.
Roman Kruzelecky
Z.A.
ottimo
cavo ben fatto ottimo prodotto
Zannini Andrea
ottimo
Nancy G.
Great Cable
The only other 3.5mm to dual RCA cable I have experience with did not sound as good or connect as well. Fosi cable seems to have better frequency high, mid and low. I do like this cable.
Nancy Green
Great Cable
Shoyab Khan
Shoyab Khan
Nikolai Lyraan
Good
I used this while testing out some audio products at it was very good without making extra sound unlike the bad quality ones I got before.
Nikolai Lyraan
Good
Feng-Hsiang Wu
good
Feng-Hsiang Wu
good
Andrew B.
A great cable that does exactly what it's supposed to.
Andrew Belik
Jeff Clark
Quality Cable
Have been using the cable now for a couple weeks.. the rac ends are solid and grip the posts well. Sound transfer is spot on with no degradation
JC
Quality Cable
