- Reconstruct multichannel 7.1 surround audio
- Create a spacious, lifelike soundstage
- Perfect pairing with IM4 Open-Back In-Ear Monitor
Fast, Free Shipping
Hardware-level 7.1 Spatial Audio
Fosi's in-house spatial audio algorithm supports native 7.1-channel audio input and reconstructs the sound space to convert multichannel game audio into an expansive 2-channel 7.1 surround, crafting a 360° immersive audio experience.
- MAX Output Power:220mW@32Ω
- Sampling Rates:PCM 32bit/768kHz
- Support Native:DSD512
- Headphone Impedance: 16-300 ohms
- Weight: 16g; Dimensions: 55x20x11mm
No PC software or drivers needed. Fosi's in-house spatial audio algorithm supports native 7.1-channel audio input and reconstructs the sound space to convert multichannel game audio into an expansive 2-channel 7.1 surround, crafting a 360° immersive audio experience.
Even with standard stereo sources, it instantly creates a spacious, lifelike soundstage.
In games with multichannel audio output — such as Delta Force: Hawk Ops and Forza Horizon 5 — enabling 7.1 surround sound delivers precise directional awareness and realistic distance perception, bringing the roar of engines and the intensity of battlefields vividly to life.
- Fosi Audio DS3
- User Manual
- USB-C Cable
- USB-C to USB-A Adapter
- Quick Guide
What accessories are included with the DS3?
The box contains the DS3 dongle DAC/amp, a USB-C cable, a USB-C to USB-A adapter, a quick-start guide, and the user manual—everything you need for plug-and-play listening on phones, PCs, PS5 or Switch.
How do I switch gaming sound effects on the DS3?
In UAC 1.0 gaming mode, long-press both Volume+ and Volume- buttons to cycle through No Effect (yellow) / FPS Effect (blue) / 7.1 Spatial Audio Effect (purple); 7.1 creates a 360° immersive soundstage-no drivers needed.
Can I change digital filters on the DS3?
Yes—long-press both volume keys in UAC 2.0. Filters 1–7 blink once, Filter 8 blinks twice; pick the curve that best suits your headphones and music.
How do I change UAC modes on the DS3?
Plug in to default UAC 2.0 (red LED). Hold any volume key while reconnecting for UAC 1.0 (yellow). Swap back by unplugging and re-plugging the USB-C cable.
How do I toggle high/low gain on the DS3?
Short-press both volume keys together. In UAC 2.0, red flash = high gain, solid red = low. In UAC 1.0, watch the last color: flash = high, steady = low—yellow for no effect, blue for FPS, purple for 7.1.
