80W Toroidal Transformer
Nippon Chemi-Con Capacitors
High-Reliability Rectifier
4-Core Regulation
  • Versatile Connectivity: Supports both Bluetooth and 3.5mm wired input. Experience high-fidelity, low-latency music anytime and anywhere. Also functions as a desktop Bluetooth receiver and amplifier, making it an ideal partner for HiFi headphones.
  • User-Friendly Design: Designed with you in mind. Compact yet equipped with rich adjustment features and easy controls. Features a rotary volume wheel to prevent accidental operation and easy-to-use gain switch and bass boosting toggle.
  • High Performance: Incorporates the OPA1656 op-amp, perfectly supporting headphones up to 300 Ohms impedance, ensuring clear and clean sound. Crafted by audio professionals with two decades of expertise, you're guaranteed an immersive experience where no musical detail is left behind.
  • Long Battery Life: Powered by a robust 1200mAh lithium battery, the N3 promises up to 10 hours of uninterrupted audio bliss. The isolated power design further ensures consistent and pristine sound quality, letting your music play on without a hiccup.
  • Exquisite Craftsmanship: Beyond its stunning looks, the CNC-machined all-aluminum alloy body guarantees durability with a premium touch. Feel the difference in every interaction and rest easy knowing you're backed by Fosi Audio's 24-month warranty.
Fosi audio N3-2
Fosi audio N3-3
Fosi audio N3
Fosi audio N3-1
Fosi audio N3-4
Model N3
Input Bluetooth, AUX
Output 3.5mm Headphone Jack
Op-Amp OPA1656
Headphone Impedance 16-300Ω
RMS Power 138mW @32Ω 15mW @300Ω
SNR 95dB
Frequency Response 20Hz-20kHz
THD 0.001%
Bluetooth Codec SBC
Power Supply 5V/1A
Battery 1200mAh (Up to 10-hour playback time)
Weight 300g
Dimensions 90x50x12mm
Fosi Audio N3 Headphone Amp x 1, Type-A to Charging Cable x 1, User’s Manual x 1
N3 User Manual
Power Input
AC: 115V / 230V
Note:
Power Output
Operating Temperature
-20 ~ 40°C (-4°F ~ 104°F)
Temperature Rise Test
  • Fosi Audio PSU20*1
  • User Manual*1
  • AC Power Cord*1
