  • Noise suppression: Through the combination of filter capacitors and inductors, the power filter effectively suppresses conducted and radiated interference, reducing the impact of electromagnetic interference on devices.
  • Power purification: Filters out high-frequency noise and harmonics from the power supply, providing a stable and clean power signal, and enhancing the performance of audio and video equipment.
  • Device protection: Reduces the impact of power surges and spikes on devices, extending their lifespan.The
The DC filter not suitable for BOX X5
  • 5 stars: 70 (86%)
  • 4 stars: 6 (7%)
  • 3 stars: 3 (4%)
  • 2 stars: 1 (1%)
  • 1 star: 1 (1%)
Paul
Nice DC filters
I use these with all of my Fosi gear, it actually works. The noise level is noticeably lower when the volume level is cranked to max (with no music playing). I appreciate this inexpensive upgrade for the power supply
Paul H
Nice DC filters
Michael
This is excellent.
Periodically, I used to experience a light buzzing sound with my xduoo xd05 pro when using my linear power supply. I don’t have no clue why it emits but when I physically touch it with my finger, it goes away. Well I don’t have time for that. I bought this and no buzz whatsoever. In fact, it sounds clearer and much better. Not sure if it’s placebo but I don’t think so. Buy it!!!!
Michael S.
This is excellent.
Periodically, I used to experience a light buzzing sound with my xduoo xd05 pro when using my linear power supply. I don��t have no clue why it emits but when I physically touch it with my finger, it goes away. Well I don��t have time for that. I bought this and no buzz whatsoever. In fact, it sounds clearer and much better. Not sure if it��s placebo but I don��t think so. Buy it!!!!
h
hiwata
Very cost-effective product
I use it with ZA3. I measured what effect this product has. The second photo is without it, the noise is 180mVpp. The first photo is with it, the noise went down to 80mVpp.
In my environment, I was able to reduce noise by more than half. I think this is a very cost-effective product.
h
hiwata
Philipp
Smooth trebles more contour in bass
It’s not a big investment and so I gave it a try. I’ll keep them. I bought two. For each device because I listen with two monos ZA3. Music coming from ZD3 with op amp Burson v7 vivid.
Philipp Noller
It��s not a big investment and so I gave it a try. I��ll keep them. I bought two. For each device because I listen with two monos ZA3. Music coming from ZD3 with op amp Burson v7 vivid.
ok
Brian
fantastic service fantastic product well built quality
Don
goofy not to buy
My first thought simply was at this price point, I'd be goofy not to buy the Fosi power filter. So I did. Along with my MC331 the filter truly improved the crispy high end of my inexpensive ribbon tweeters. I'm happy
Audio enthusiast
Works exactly as described definitely notice a difference
Karsten Langwald
Super Filter zum gutem Preis - klasse!
Terry
Fosi Audio DC Power Filter
Warren
Jean-Pierre
Schwer zu bewerten
Im Rating gebe ich dem DC Power Filter „nur“ 3 Sterne. Nicht weil die DC Power Filter schlecht wären, sondern weil die klangliche Wirkung schwer nachvollziehbar und zu bewerten ist. Klanglich schädlich sind diese DC Power Filter sicher nicht. Allerdings, bringt der Einbau von den Burson Vivid V7 /Classic Op-Amps in den ZA3 (mono) Endstufen eine eindeutige klangliche Verbesserung. Sehr empfehlenswert.
Daniel
Fosi Audio DC Power Fileter Review
Application of the DC filters to 48V 5A PSU for Fosi ZA3 mono blocks made some audible difference. Lower noise floor. For its price, it is definitely worth it.
Nice
Nuno Alexandre Ferreira
Test it with oscilloscope, and it really decresse noise and ripple tension.
Jeff,
I have only tried one filter so far, on a ZA3. The results are very pleasing, with the ZA3 sounding much smoother, clearer and purer. I am yet to try my second filter, but will get to that with my V3 Monos soon. A good product, and purchase.
Filter review
The filters brought detail and more depth and warmth, not an ee just my opinion
Gary Abramowicz
Filter review
Good quality and an improvement in my chain.
Igor
Powersupply filter
It improved sound. Sound is more natural, high tones are not so bright any more. I use it with my zd3 dac.
Igor Praskac
Powersupply filter
Dave
I have purchased 7 of these EMI/RFI DC filters. They easily reduce noise by half. I use most on SMPS (10A 48V) that feed 300W+ class D amplifiers.
Dave Michalak
