80W Toroidal Transformer
Nippon Chemi-Con Capacitors
High-Reliability Rectifier
4-Core Regulation
Power Three Devices Simultaneously
With dual DC outputs and one USB-A output, the PSU20 can power up to three audio devices from a single source.
Flexible Compatibility
Supports selectable 5V, 12V, and 15V outputs, making the PSU20 compatible with CD transports, DACs, headphone amplifiers, and preamps.
3 Fully Isolated Outputs
Each output has its own dedicated rectification, filtering, regulation, and protection circuitry to deliver clean, stable power without interference between connected devices.
0.1mV Ultra-Low Ripple
With ripple as low as 0.1mV, the PSU20 helps reduce ripple noise and deliver a cleaner background for high-fidelity audio systems.
Engineered for Stable Long-Term Use
A custom low-noise fan activates at 55°C and operates at just 30dB, while over-temperature, over-voltage, and over-current protection help safeguard connected audio equipment.
Power Input
AC: 115V / 230V
Note:
Power Output
Operating Temperature
-20 ~ 40°C (-4°F ~ 104°F)
Temperature Rise Test
  • Fosi Audio PSU20*1
  • User Manual*1
  • AC Power Cord*1
  • 5 stars: 5 (63%)
  • 4 stars: 2 (25%)
  • 2 stars: 1 (13%)
Istvan Rudasics
Overheating - Safety Concern - Returned
I connected only 2 low-power devices: an AVM Fritz!Box 5530 Fiber (approx. 10W) and a QNAP QSW-1108-8T-R2 switch (max 12W). So total load was around 22W.
The Fosi device got burning hot within a short time, way too hot to touch. This feels unsafe and inefficient. I have returned the device. I cannot recommend it.
Andreas Neelsen
Gut verarbeitet, schnelle Lieferung, angemessener Preis. Kann ich empfehlen!
Vielen Dank nach China
Barry Ong
Fosi Audio PSU20 Linear Power Supply
I used it to power my Fosi ZH3 and S3. It helps simplify the connection to power, One plug less and so far seems pretty good.
DocHouse
Block of energy
The powerhorse of Fosi near to corefusion
John Lim
Beverley Dyck
Multi inputs
Good variety of inputs and sound quality for the price.
Jerome Enriquez
Great Product, Noticeable Difference in my System
I have this powering my LAIV Micro Dac, before and after comparison, i can say that now I can hear more instrument separation and definition and owing to a lower noise floor the soundstage got expanded noticeably. Thanks Fosi Audio for yet another great value product!
Daniel Park
Fosi Audio PSU20 Review
I hooked up PSU20 to Fosi ZD3 DAC and Fosi X5 Phono preamp - both take 12V DC. For Fosi ZD3, I can sense minor improvement in noise floor (I was using iFC 12V adaptor before). For phono premap, I don't think I get sense any difference from the generic SMPS power supply that came with the unit.
The PSU20 is heavy, and I like the versatility for the output options - dual out with 12V, 15V and 5V options. I might upgrade my phono amp that takes either 12V or 15V, and see if the PSU20 makes any difference.
