  • With treble, middle, and bass adjustments capabilities, combined with central point positioning, you can easily find the perfect balance. Additionally, you can effortlessly defeat all the tone adjustments with just a click on the PURE button.
  • Unmatched Headphone Compatibility: Experience versatile connectivity with the Fosi Audio SK01 Headphone Amplifier Preamplifier 2 in 1. Its input features a 3.5mm line in, while the output offers a 3.5mm line out, along with a 3.5mm/6.35mm headphone jack. Enjoy powerful performance with a max power output of RMS 2400mW@32Ω, catering to terminating impedance between 16-300Ω. Elevate your audio experience with seamless connectivity and exceptional power, all in one compact device.
  • Tailor-Made Audio Experience: The SK01 is a multi-functional audio gear that caters to desktop and portable music playing and tone tuning. The tri-band adjustment allows you to personalize treble, middle, and bass, finding the perfect balance for your preferences.
  • Multi-functional experience: Whether as a powerful headphone amp, a customizable analog preamp, or an accurate equalizer, it effortlessly elevates your listening experience, delivering exceptional sound quality and personalized sound signatures.
  • Long-Lasting Battery: Enjoy up to 6 hours of continuous usage with the built-in high-capacity battery, while the isolated power design rejects interference, providing a pure listening experience without any interruptions.
  • Exquisite Design: Crafted with an aluminum alloy body, the SK01 is both elegant in appearance and touch, adding a touch of sophistication to your desktop setup.
  • What you Get: Fosi Audio Sk01 Headphone Amp x1, User Manual x1,2-in-1 USB Type-A/C to Type-C Cable x1, an 24-month worry-free warranty and friendly customer service.
SK01
Model SK01
Input 3.5MM line in
Output 3.5mm Headphone, 6.35mm Headphone, 3.5MM line out
Amp output maximum power High Gain: RMS 2400mw/ 32Ω,Low Gain: RMS 300mw/32Ω
THD+N 0.001% @ 1kHz and 770mV
SNR ≥108dB
Device Dimension 4.76*2*1.69inch (121*51*43mm)
Net Weight 0.641b/290g
Power Supply 5V, USB Type-C
Use a 5V 1.5A/2A adapter to charge it.
Item Quantity Fosi Audio Sk01 Headphone Amp x 1, 2-in-1 USB-A/C to C Cable x 1, User’s Manual x 1
SK01 User Manual
  • 5 stars: 49 (89%)
  • 4 stars: 5 (9%)
  • 1 star: 1 (2%)
DAVID CANON
Unique on its type
It's a very curious device—built-in battery, tone controls, line and headphone amplifier, and a pretty solid CNC build. I never came to realize just how handy these controls are until I committed to some serious listening. In my case, I like to switch among genres and artists; I don't often stick to a single album. If you do this kind of listening, this is the device for you—it allows you to tailor the audio for your current headphones and tracks on the move. For instance, I considered the TRI I3 a good IEM, especially for recordings that lack brightness, but when they don't, sibilance becomes an issue for me. Pairing this device allows me to quickly adjust it.
DAVID CANON
Unique on its type
It's a very curious device��built-in battery, tone controls, line and headphone amplifier, and a pretty solid CNC build. I never came to realize just how handy these controls are until I committed to some serious listening. In my case, I like to switch among genres and artists; I don't often stick to a single album. If you do this kind of listening, this is the device for you��it allows you to tailor the audio for your current headphones and tracks on the move. For instance, I considered the TRI I3 a good IEM, especially for recordings that lack brightness, but when they don't, sibilance becomes an issue for me. Pairing this device allows me to quickly adjust it.
Delwyn Challoner
Sk01
Great little amp
Del
Sk01
Great little amp
s
scott onsax
fosi headphone amp works well with my laptop and musical applications
clean sound, provides for easy to reach control (volume and tone) of my laptop audio when performing on stage. usb power from the laptop is one less cable problem. 1/4 inch and 3.6 mm in/outs are good design. nice price/value ratio.
s
scott birdwell
Alessandro Albertin
No words! GREAT!!!
Rostislav Korotkiy
Ok.
Broeheem
Little box of dynamite
After too much time suffering from an electrical interference issue at my home that made it impossible to enjoy vinyl records, I discovered that a headphone amplifier required much less power than my vintage Marantz or Pioneer receivers, therefore the resulting hum I was dealing with would be almost indiscernible. I run this SK01 through the FOSI BoxX2 tube phono preamp, then through a Numark stereo 10-band EQ for further tone adjustment, then ultimately into some Audio Techica M50 'phones. I couldn't be any more satisfied. A bonus: With the Numark, which has L/R level controls, I now have balance adjustment, too! If there is ever a "plug in" model of the SK instead of rechargeable, I'll be all over that one.
Broeheem
Ellis Warring
Ellis Warring
Ian H.
Solid Product at a Great Price
Great sound, with the tone controls and loudness options, plus portability make this my go to headphone amplifier. Well worth the money.
Ian H.
Isaac
Amazing!
I use it with AKG K702 and K612 Pro and it is simple amazing. Thanks, Fosi Audio!
Isaac
Amazing!
Cher hing cheong
Good high volume
Cher hing cheong
Good high volume
Edward Ontiveros
Edward Ontiveros
Laura Burchfield
I really like it
I really like this amplifier for my headphones. I like it better than the dongle type because I can adjust the way it sounds. Such an improvement over just plugging headphones into your phone!
Laura Burchfield
I really like it
Paul H
Well-Rounded Headphone Amp & Preamp
Simple device - makes any headphone sound great to the user. I’ve tried HEDDphones on many amps and none have brought them to life like this. Would love to see a balanced version with 4.4mm inputs and outputs, but I cannot really complain as the output and noise level is more than adequate as is. Very impressed by this little unit!
Paul H
Simple device - makes any headphone sound great to the user. I��ve tried HEDDphones on many amps and none have brought them to life like this. Would love to see a balanced version with 4.4mm inputs and outputs, but I cannot really complain as the output and noise level is more than adequate as is. Very impressed by this little unit!
Alex
Very useful
I use it everyday since it was purchased. My favourite feature is a 3 band EQ. Honestly my Beyerdynamic DT990 really missed some bass out of the box and SK01 lets me add more lower frequencies without overlapping with mids and I love it. Maybe a balanced out would a great addition but standard jack is also enough.
Alex
Very useful
Sjjsjdndj x
i like the product
i don't know what to say but the sk01 is the one piece that been missing in my setup
Sjjsjdndj x
i like the product
Martin Greet
Great little amp
The Fosi SK01 is a very capable little headphone amplifier. It is solidly built and has whisper quiet operation. The tone controls are effective, allowing the user to compensate for short-comings in their headphones if necessary. I found the 1/4" output produced a slightly stronger signal than the 1/8", but this might have more to do with the headphones (Sennheiser IE200) than the amp itself.
