  • Connector Material: Zinc alloy with chrome plating
  • Compatible with: ZA3, ZD3
  • Not compatible with: AES/EBU connectors
  • Premium Construction: Made with nylon braiding, PVC coating, copper foil shielding, anti-pull threads, and oxygen-free copper braiding shielding for superior durability and performance.
  • High-Quality Connectors: Features zinc alloy connectors with chrome plating, ensuring excellent conductivity and corrosion resistance for long-lasting use.
  • Balanced Audio Transmission: Designed for balanced audio signal transfer, it effectively reduces noise and interference, delivering high-fidelity sound over long distances.
  • Versatile Compatibility: Compatible with ZA3 stereo amplifier and ZD3 DAC Preamp, good for professional audio setups like microphones, mixers, and audio interfaces.
  • Compact and Space-Saving: The 0.3M (1ft) length is perfect for tight spaces, ensuring a neat and organized setup without excess cable clutter. Ideal for desktop microphones and compact audio interfaces.
  • XLR Cable*2
  • 5 stars: 81 (92%)
  • 4 stars: 6 (7%)
  • 2 stars: 1 (1%)
Yankele Herrera
This are premium XLR cables!
Got this to connect my ZD3 to my prramp and the result is obvious: more clarity and separation. This cables are extremely well made, heavy and braided. I choose the small ones to fit my preamp and want to avoid cables clutter.
Andrés C.
High-quality XLR cables with a perfect fit
I purchased these XLR cables to connect my Fosi ZD3 DAC to the ZA3 amplifier, and they work perfectly.
The connectors fit securely without being overly tight, and the cable itself feels durable and well made. There is no audible noise or interference, and the balanced connection performs exactly as expected.
Andr��s C.
K.
Fosi Audio XLR
Great XLR cable from Fosi Audio. The build quality is excellent with sturdy connectors and a flexible, durable jacket. Signal transmission is crystal clear with absolutely zero hum or interference. Highly recommended for the price!"
Kendi
Fosi Audio XLR
Pavel Z.
bar code
Hi,
I bought these cables from a local supplier but they were just in a regular white bag. Could you tell me the bar code for this product please?
Thank you
Pavel Zabuty
bar code
Hi,
Thank you
Sanjay J.
Fosi XLR Cable - Solid Built
Built quality of the cable is very good. Don't waste money on sponsored or mentioned by YouTube influncers.
Sanjay Jairathh
Dennis
Great
Great
DGJ
Great
Great
Ralph Parker
XLR cables.
The XLR cables are good. I should have just bought the longer ones. My bad. 😕
Ralph Parker
XLR cables.
The XLR cables are good. I should have just bought the longer ones. My bad. ??
Gerald
No 1 product in
I would say, its an amazing product
George
No 1 product in
S.G.
Excelente construcción
Terminación de lujo. Muy recomendables.
S.G.
Excelente construcci��n
Terminaci��n de lujo. Muy recomendables.
Joe
Well made. Good value.
Salvador
The cable arrived in black not like the picture and the delivery timeline was very long and disappointing.
Igor Mihaliska
Great product.
Customer
Wow, immediate difference noted from my RCA cables!!
Wow, immediate difference noted from my "high-end" RCA cables. Louder immediately and absolutely no noice. Am feeding Schiit Mjolnir from Cambridge Audio DAC. And at such a great price, well done FOSI!!
Ivano Sarra
Fosi Audio XLR Cable
Good quality cables. Connectors are fine, nice colours.
However I didn't find difference with respect to the RCA cables I was using. But I should say that my RCA cables have great quality, so the noise rejection is negligible in my case.
Ivano Sarra
Skvěle zpracované kabely, které jsou navíc dělané na míru k Fosi komponentům. Naprosto geniální.
Customer
Thank you. Perfect
Ahmet YAL?IN
Thank you. Perfect
