Fosi Audio P2 Headphone Amplifier
Excellent sound performance: Low ground noise, built-in output protect the circuit, no buzzing or ringing noise, Audiophile-level sound quality, exclusively designed for the customers who pursue HiFi sound; and safe for your expensive headphones.
Stereo and Preamplify: Headphones amp also can be used as a stereo preamp, Parallel 3.5mm and RCA stereo inputs, 6.35mm headphone output, include a 6.35mm to 3.5mm adapter;
High-performance: P2 is a Hi-Fi tube headphone amp, 2 X 5725 tubes can easily power high-performance headphones including the HD580, HD600, HD650, K701, K702, Q701, and many more, recommend 32-300ohm headphones
Easy replace tube: Tubes can be replaced by JAN 5654W/6j1/6J4/GE5654/6AK5/6*1n/ E180F/6ж9П/EF861/6688 tubes etc
Exquisite appearance: Small Compact Size, All aluminum alloy shell and come with an 18-month manufacturer's warranty.
| Model | P2 |
| OP-Amp | NE5532 |
| Headphones Output | 16-64Ohm |
| Headphone Impedance | 32-600 Ω |
| Input Mode | 3.5mm Audio jack, Stereo L / R RCA |
| Frequency Range | 20Hz-20 kHz (± 3dB) |
| THD | ≤0, 03% |
| SNR | ≥ 95db |
| Input Sensitivity | 0.2mV |
| Device Dimension | L99 * W98 * H33 mm |
| Device Weight | 0.25 kg |
| Operating Voltage | DC12V |
| P2 Headphone Amplifier | x 1 |
| 5725 Vacuum Tubes | x 2 |
| DC 12V Power Supply | x 1 |
| 6.35mm to 3.5mm Adapter | x 1 |
| User’s Manual | x 1 |
Compare with similar items:
P1 Pro Bluetooth 5.0 Tube Preamplifier
P1 Vacuum Tube Pre-Amplifier
Power Input
AC: 115V / 230V
Note:
Power Output
Operating Temperature
-20 ~ 40°C (-4°F ~ 104°F)
Temperature Rise Test
- Fosi Audio PSU20*1
- User Manual*1
- AC Power Cord*1
