  • Each package contains a pair of fully tested and matched vacuum tubes (2 PCS).
  • 5654W vacuum tubes for T20, P1, P2, Box X2Box X4. Substitute for 7-pin 6AK5/6AK5W/6Zh1P/6J1/6J1P tubes. It can also directly replace WE-403A/403B/EF95 and ordinary 5654.
  • 6J1, 6CB6A, 6Ж3N, 6J5, 6Ж5N tubes are compatible with audio devices such as BOX X2, BOX X4, P3, GR40, MC331, and T20X MKII.
  • Note: Replacing the wrong type of tube may damage your amplifier. If you are not sure this 5645W can be used as a replacement for your audio device, please check with your amplifier manufacturer.
  • It has a fuller, wider sound stage. The treble is smoother and the bass is a little bit tighter. And you can hear some details that you did not hear before while listening to more complex music.
  • Every package you get goes through our careful packaging. With 18 months warranty. If you have any questions, please feel free to contact us.
Vacuum tubes such as the 5725 and 6J1 are products of a specific historical period, carrying strong historical significance and unique tonal characteristics. Having long been discontinued, all available units are carefully preserved vintage stock, making them non-renewable and rare collectibles.
Minor signs of aging on the tube surface—such as slight scratches, faded markings, or yellowed mica—are normal. We guarantee that every vacuum tube sold has undergone basic testing to ensure proper functional performance.
Given the uniqueness and scarcity of these products, all sales are final; no returns or exchanges will be accepted once purchased. Please do not place an order if you do not accept these terms.
  1. All vacuum tubes have been fully tested and strictly matched.
  2. These vacuum tubes are compatible with audio equipment including BOX X2, BOX X4, P3, GR40, MC331, T20X MKII, etc.
  3. Using an incorrect vacuum tube model may damage your amplifier. If you are unsure whether these tubes are suitable for your audio device, please confirm with the amplifier manufacturer.
  • 5 stars: 21 (91%)
  • 4 stars: 2 (9%)
Richard Crandon
Great preamp for my turntable
I connected the Fosi between my AT LP120XUSB table and a Yamaha HTR-5960, not really expecting any difference in the output to the Polk tower speakers and 14" Polk sub, but I was amazed at the difference in output from albums I'd been playing from the 1970's.
Not only was the sound amazing at 45db setting, but I heard things on the tracks I'd never heard before.
I researched tubes for the Fosi and found an upgrade that everyone who bought one raved about. I decided to change them out and I was again pleasantly surprised by the output from the Fosi.
Who knew such a small device could make such a difference in sound?
Definitely deserves a 5 star rating.
James R.
Have to giving my glowing review of these upgrade
Have to giving my glowing review of these upgrade tubes. The tubes that come with Box X2 (5654W), I would always here a crackling in the mids-hi range in frequency coverage. These have totally fixed that problem. The entire frequency range that is amazingly defined.
Martin Binnekade
Good replacement good fit great sound quick delivery good package
Mikal W.
Great set of vacuum tubes!
I was able to change it my previous 5725W tubes with these 5654W tubes and the sound is awesome!
Dave Bausher
Sonic improvement
Replaced the factory tubes with these and it made a sound improvement I could here! Thanks.
Matthew C.
Fantastic!
They work great, good sound!
Willy Schlaghecke
Nice tubes.
To my ears they improved the sound quality on my X2
Jakub H.
My opinion
Hi Fosi,
The device sounds great, but the biggest drawback for me is the lack of an option to select the output signal. Both the RCA and headphone outputs are active at the same time. A switch between RCA and headphone output would be very useful. Possibly an option to have both active simultaneously as well, although I think that might not be necessary.
Cory Laskowitz
X2 upgrade tubes
Great upgrade. Deeper richer sound.
Julian
Very good
Happy customer
Robert R.
Wow the difference is measurable and huge
I wasn't sure exactly what to expect from this tube upgrade. I was pleasantly surprised! Strained vocals are now smooth. You can really hear the music fill the room. A worthy upgrade! Completely sealed my faith in using tubes to enhance the listening experience
Paul Furlow
I was happy with my purchase took a little time to get , very professional packaging and nice quality;it’s build
Customer
5654W Matched Tubes For The Fosi Audio GR70 Tube Headphone Amp Color My Sound Impressed
I love the GR70 Head/Pre Amplifier and Fosi has the best price for matched 5654W vacuum tubes. Now I have replacement tubes in the event I need them.
Than You Fosi Audio
John
Frederick Eckert
Reliable neutral warm sounding tubes
I've purchased these tubes for backup on Fosi model # MC331 . WOW ! I can't believe the quality of sound & versatility MC331 model offers ! The unit sounds great as a stand alone device ( with a decent set of speakers ) or used as a pre-out for an old school solid state integrated amplifier. You could very easily spend 20 times as much & not get such satisfaction !
CoiriespOurry ZamoorspOurryCM
No Review
I have not received the order yet
Douglas Homer
Shipping was a tad long
but they got here!
Q
Quincy Asbury
Nice Upgrade
So far the "Tubes" sound as if the music is more full and richer....
Grizz
Tube Roll
As was mentioned previously, I also feel these tubes tame the upper frequencies. I like that they are shorter than the stock tubes too. I started to use this preamp after letting it sit for quite some time. I'm using it on a Yamaha R-N303. The receiver has a built-in phono stage but I needed to move my turntable away from the speaker area so I hooked up the Fosi Preamp and I am using a longer RCA cable to the receiver.
I was really surprised how much better this preamp performed. When I saw that there is an "upgrade" for tubes, I decided to give them a try. I'm happy with it.
Zlatogor Minchev
valves_tubes_change
M KRISHNA REDDY
excellent
super
Jay Fraser
Continued Excellence....But One Question....
Fosi continues to deliver on customer service with fast, free shipping and great communication when I do have questions. The new tubes arrived quickly, but I have one question. Printed directly on the tubes it says, "Made In U.S.A." but the label on the box says, "Made In China". Which is it? Thank you.
Martin Ludvik
GE tubes 5654W
Definitile good thing to upgrade stock tubes. GE 5654 sounds audibly better!!!
Stephen Kincaid
Tube tastic
What’s the difference? Tubes made my speakers, sound, glorious with a warm feel and a deep, harmonious sound lovely
